Toyota SUCKS!
Discussion in '2.5 Gen Tundras (2014-2021)' started by bensky, Mar 30, 2022.
  1. Mar 30, 2022 at 5:58 PM
    1UP, Wallygator, normagene and 10 others like this.
  2. Mar 30, 2022 at 6:07 PM
    bensky
    bensky [OP] PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    The issue: Signals turn signals too dim
    Me: Takes to vehicle to Toyota dealer to fix the problem.
    Dealer: They are defective and not as bright a service managers 2017 Tundra. They contact Toyota for a solution. Toyota has no solution nor do any of the lead or master technicians. Dealer suggests replacing bulbs and contacting Toyota customer service.
    Me: I’ll replace with LEDs. They need resistor built in so expensive VLEDS are best option. I buy and replace.
    There is no f-ing way you would have known to check the output from the connectors in the harness. Nor did anyone at the dealerships service department.
  3. Mar 30, 2022 at 6:11 PM
    bensky
    Ben
    Utah
    And you figured that out all by yourself? Or, you saw a post on here of someone who figured it out? This was long before anyone had figured it out. Easy to criticize when you already had the solution. I did not.
  4. Mar 30, 2022 at 6:16 PM
    Mr Badwrench
    Mr Badwrench New Member
    "I realized long before the official recall that the lights were too dim and replaced them with much brighter LEDs."
    It's "under review" because you have thrown them a curve ball. You have modified the truck.
    Black Wolf and Cpl_Punishment like this.
  5. Mar 30, 2022 at 6:17 PM
    Could they have not checked the voltage? (Presuming it would alert?)
    JLS in WA likes this.
  6. Mar 30, 2022 at 6:20 PM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Shouldn't this issue be resolved by the dealership if they told you to switch out the bulbs?
  7. Mar 30, 2022 at 6:20 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Well still haven’t addressed this issue. Probably because it has never been a issue
  8. Mar 30, 2022 at 6:24 PM
    1794TX
    Steven
    N.TX
    '20 1794
    They're not slow walking the claim because their customer service is sub-par. Nobody there will sign off on reimbursement for a repair that doesn't fall in Toyota's recall. It's not a write-off, because a bulb wasn't at the crux of the problem, wires were. It won't get comp'ed because what if everyone runs out and gets $175 worth of bulbs to fix a $15 wire problem, and then asks for the comp which would then have precedent set?
    They'll try as hard as they can to outwait you on this, to avoid voicing the hard no. But I'll buy you a donut if it's not a hard no.
    I hope you can find a happy place. You've got a nice truck that's a lot less imperfect than any other truck brand.
  9. Mar 30, 2022 at 6:26 PM
    Jack McCarthy The jackass who owes me for a stripper tab
    I could see Toyota reimbursing you but only for the cost of their replacement bulbs based upon the dealer recommendation if it’s in writing, not what you paid for the upgrade.
    Cpl_Punishment likes this.
  10. Mar 30, 2022 at 6:36 PM
    Oerterg
    Oerterg New Member
    2020 MGM sr5 sport crewmax 4x4
    You also didn't fix the problem and still need the fix done. you just put in different bulbs.
  11. Mar 30, 2022 at 6:48 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  12. Mar 30, 2022 at 6:53 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    So you think that your claim is the only one the world's largest auto manufacturer is dealing with or that they should bump you up to the top of the list for some reason?
    ToyoMafia likes this.
  13. Mar 30, 2022 at 6:57 PM
    2mchfun
    Well OP, I think you might just need to pack your oldest boots full of "mud" and visit your local showroom. Explain the situation and ask them to call corporate on your behalf. While they are on the phone, leave plenty of "evidence" everywhere, maybe test a seat position or 3. Repeat the process everyday until resolved. Pretty sure it won't take more than a week.
    Wes_heppy, Piki, Mater and 2 others like this.
  14. Mar 30, 2022 at 7:02 PM
    THIS ^^^^^^
  15. Mar 30, 2022 at 7:07 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    So you are upset because Toyota didn't repay you for your aftermarket LED bulbs? :facepalm:
  16. Mar 30, 2022 at 7:39 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Man, I get you’re pissed. But, Toyota doesn’t suck and generally does right by consumers. A dim bulb is a pretty small issue.
    I probably would be frustrated myself so I get it. Your thread title isn’t going to gain you a ton of support because it’s inaccurate.
    Wes_heppy, Hoff, Bubberdawg and 4 others like this.
  17. Mar 30, 2022 at 9:36 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Kinda like Mercedes owners?
  18. Mar 30, 2022 at 10:02 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    I always thought Mercedes owners sat in the back and let their dog drive. Pretty much every one I pull up to at a stop light looks like this..
  19. Mar 31, 2022 at 12:11 AM
    Blue By U
    Blue By U New Member
    Folks nowadays think something is owed them for someone screwing up. The last thing I would ever do is go to the dealer to fix anything. If your thinking lead you to $175 lights to fix the problem, shame on you.
    Terndrerrr and Cpl_Punishment like this.
  20. Mar 31, 2022 at 12:35 AM
    #50
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Boom. Toyota doesn’t suck, and you didn’t spill their coffee on your crotch.
    If you want to read about real citrusy issues with trucks, checkout the forums for domestic brands.
  21. Mar 31, 2022 at 3:22 AM
    #51
    Adam New Member
    What do you think happens when a company says free money? People come out of the woodwork to scam them...at the expense of the legit submittals. They have all these layers to go through be cause they have been f'ed in the past...repeatedly. You bought the lights when there was no fix out there and decided that was the best decision for you. Them coming out with a possible avenue for reimbursement is a bonus. Don't look a gift horse in the mouth.
  22. Mar 31, 2022 at 3:42 AM
    #52
    Bammer
    Monroe, CT
    I could start a Go Fund Me page ?
  23. Mar 31, 2022 at 5:01 AM
    #53
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    I blame the dealership, not Toyota. The dealership should have known to add more Blinker Fluid...:)
  24. Mar 31, 2022 at 5:25 AM
    #54
    Where is an acceptable place to look at a gift horse? Asking for a friend……
  25. Mar 31, 2022 at 5:43 AM
    #55
  26. Mar 31, 2022 at 6:00 AM
    #56
    Kung
    KG, VA
    Serious question - did you know/realize when you discovered this issue that there's a recall on the bulbs?
    I ask this because the very first thing I do whenever I have an issue is sit down and look to see if the issue is a recall, covered by a TSB, etc.
    Cpl_Punishment, gosolo and Black Wolf like this.
  27. Mar 31, 2022 at 6:02 AM
    #57
    Mohoman
    Mohoman TTC 165
  28. Mar 31, 2022 at 6:08 AM
    #58
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    This seems like if your truck had a factory issue with shock mount bushings—just the bushings—and you replaced your entire suspension with new coilovers and rear shocks and then expected Toyota to cover the bill.
  29. Mar 31, 2022 at 6:21 AM
    #59
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    This is one of the most accurate statements on this thread. Toyota will still need to "fix" the problem. Your band aid temporary fix, they don't owe for. In my opinion.
  30. Mar 31, 2022 at 6:51 AM
    #60
    2mchfun
    There is a thread about the headlight recall and replacing them with LEDs and getting reimbursed. Nobody whining there because it isn't titled "Toyota SUCKS". Instead they are all trying to learn how to cheat the system. Really funny to see how a title affects blood pressures and brings out the haters.:crapstorm::humble:
    r1-superstar, Mater, Sumo91 and 4 others like this.
