2022 Skid Plates Coming SOON from RCI!
Discussion in '3rd Gen Tundras (2022+)' started by RCIoffroad, Mar 30, 2022.
  1. Mar 30, 2022 at 1:52 PM
    RCIoffroad
    RCIoffroad [OP] New Member Vendor
    Josh
    Hey everyone just wanted to post some teaser pics of the new 22 Tundra Skid Plates that will be launching in the next week or two! These are pre-production pictures so there will be some minor tweaks but we are extremely happy with the overall product. Also, note this set has optional Catalytic Converter Guards installed. More details coming soon, let us know what you think!
    PS. Rock Sliders, diff skid, and fuel skids, are just around the corner...
    ihV1btRnApgK_fXskWfgsxtfpPMJW8XA52sP51fx_d19b023712f2abd3333e95b40434e235f973c560.jpg
    SrHD0rsUvsLIy1N5eFWfSemrv7H1hbMgAK_DAoKK_bddcdc5db6be53fd85114a43020de9b7658c5fec.jpg
    T13lvOuU4o7fD80jnhu28soIGrNk7fxZwMfCfze9_40e757eb9dbeea4d371617d9b9a6d88a5192c21a.jpg
    Tundra'25, AZTundra, pdiddy and 10 others like this.
  2. Mar 30, 2022 at 1:57 PM
    AustinTexas
    AustinTexas New Member
    looks good
    1. can you give an estimated cost for what is shown.
    2. will it need to be removed for oil change
    3. will it use existing holes or will we need to tap new holes
  3. Mar 30, 2022 at 2:14 PM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    Are those carriage bolts on the cat shields or just hex heads?
  4. Mar 30, 2022 at 2:28 PM
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    Pretty thin for skid plates, no?
    Tundra'25 likes this.
  5. Mar 30, 2022 at 2:38 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Crazy if you’re thinking 10ga steel is thin. I’m sure it’ll be the same material as the 2.5 gen Tundra skids.
    @RCIoffroad for the 2.5 gens engine and transfer skid, are you guys going to do an addition to protect our cats with the transfer skid?
  6. Mar 30, 2022 at 2:50 PM
    ThePolak
    Oh steel! I thought it was aluminum and that looked pretty thin for aluminum.
  7. Mar 30, 2022 at 3:05 PM
    They are already working the cat plates for those that already have the tranny plate. It will be a bit on addition.
  8. Mar 30, 2022 at 3:11 PM
    RCIoffroad
    Josh
    Approximately $800 for the set pictured above which includes the cat guards that are roughly $150. There will also be an identical looking 1/4" thick aluminum option starting around $800 W/O cat guards.
    Will not need removed for oil change. Filter is accessible via front access panel, and drain plug accessible through a hole on passenger side of front skid plate.
    Entirely bolt on into existing locations and compatible with OEM electric air dam
    Acedude likes this.
  9. Mar 30, 2022 at 3:13 PM
    RCIoffroad
    Josh
    You weren't supposed to see that ;) The production version is carriage bolts but we made a mistake and cut round holes in this one, so had to use hex bolts.
    Acedude and jgoliath[QUOTED] like this.
  10. Mar 30, 2022 at 3:23 PM
    RCIoffroad
    Josh
    Cat guards are already designed for the 2nd Gen and will launch hopefully end of next week. They will require drilling holes to work as a retrofit on existing skid plates, but starting in a week or so we will begin cutting the holes into all skid plates so it is a direct bolt-on.
    Moe2o4, TXTundra2722 and 2Tall like this.
  11. Mar 30, 2022 at 3:27 PM
    RCIoffroad
    Josh
    Yep, these are 10ga (.135") steel in this pic. There will also be a 1/4" aluminum option.
    We use 10ga steel because it is a good balance between strength, weight, and cost, and drastically tougher than OEM skids (if present). A Tundra can certainly dent and ding 10ga but for 90% of buyers they are the ideal solution and won't weigh the truck down.
  12. Mar 30, 2022 at 3:27 PM
    Slicer97
    Slicer97 New Member
    Giddings, TX
    2022 Tundra SR5 TRD Off Road
    So the skid plate will work fine if you already have a cat guard in place (unbolt the front of the cat guard, line the holes up, and rebolt?)?
  13. Mar 30, 2022 at 4:07 PM
    RCIoffroad
    Josh
    Do you mean a different brand cat guard? Yes you should be able to overlap them with our front skid plate
    Slicer97[QUOTED] and ryanwgregg like this.
  14. Mar 30, 2022 at 4:26 PM
    Tho4x4
    Tho4x4 New Member
    2024 Tundra Limited Hybrid OR
    Are the Cat Guards compatible with the TRD skid plate?
  15. Mar 30, 2022 at 4:31 PM
    RCIoffroad
    Josh
    Yes they should have no issues at all with the TRD engine skid
    bigjuice likes this.
  16. Mar 30, 2022 at 4:45 PM
    Tho4x4
    Tho4x4 New Member
    Thanks !
  17. Mar 30, 2022 at 5:24 PM
    jgoliath
    I’ll gladly take this one off your hands so you don’t have to look at those round holes anymore!
  18. Mar 31, 2022 at 6:09 AM
    mass-hole
    mass-hole New Member
    Maybe you should integrate tow hooks into the skids :rofl:
    4wd TRD PRO likes this.
  19. Mar 31, 2022 at 7:44 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    What do they weigh including cat shield. Steel and aluminum?
  20. Mar 31, 2022 at 9:28 AM
    RCIoffroad
    Josh
    Approximately 90lbs for the steel set with Cat Guards, 65lbs for the aluminum set with Cat Guards
  21. Mar 31, 2022 at 9:32 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Hopefully I can order a set with the current sale once you guys cut the holes for the cat shields and they are a bolt on! Guessing the site will be updated when you guys are doing the holes before you ship them or when are you able to buy them with the cat holes?
  22. Mar 31, 2022 at 2:37 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    From the photos it looks like you can still access the rear passenger cats. Or is that just the angle of the photo? Waiting to see how the coverage will be for the 2.5 gens
    Moe2o4 likes this.
  23. Mar 31, 2022 at 2:38 PM
    Moe2o4
    Moe2o4 New Member
    Corey
    Ya can't wait to see the coverage for the 2.5 gens as well!
  24. Mar 31, 2022 at 2:44 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    That's what I am waiting for so I can either get the full rci or just rci for the engine and vahalla for the rest.
    Moe2o4[QUOTED] likes this.
  25. Mar 31, 2022 at 2:44 PM
    Moe2o4
    Moe2o4 New Member
    Corey
    Ya I'd like to order a full set before the sale ends mid april!
