Best Looking Tires for 2022 Tundras
Discussion in '3rd Gen Tundras (2022+)' started by Bman95, Mar 14, 2022.
  1. Mar 29, 2022 at 11:04 AM
    #91
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    74 lbs for the stock limited OR setup (20” all black wheels with Falkens) per another post a few weeks back.
    Not sure if the platinum wheels are more or less but this setup is right in the ballpark and looks good.
  2. Mar 29, 2022 at 3:13 PM
    #92
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    I second that question. Would love to no more on this size as well. I am leaning close to this: 285/60R18 120T XL Nitto Ridge Grapplers [47.64lbs]. Michelin stock I believe in 265's are around 37lbs]. Some are saying we do not need the E rated tires and I was looking to go larger but not so large that I am adding 100lbs of rubber, for example.
  3. Mar 29, 2022 at 4:11 PM
    #93
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    RSG Off Road did two 2022 Tundra builds with a 2" leveling kit on 285/75/18 Falken WildPeak A/T tires.
    I used their 2022 Double Cab build as the inspiration for my truck.
    osu1978[QUOTED] likes this.
  4. Mar 29, 2022 at 4:17 PM
    #94
    Buellride
    Buellride New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    Cooper AT3 XLTs 295/70R18s, NO level, NO rub (@full lock right/left and reverse)
  5. Mar 29, 2022 at 4:23 PM
    #95
    bigjuice
    WA State
    2024 Terra TRD Pro
    Great looking rig…are those fuels?
    What offset are you running (if you don’t mind)?
  6. Mar 29, 2022 at 4:34 PM
    #96
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    Fuel Vectors I think.
  7. Mar 29, 2022 at 4:48 PM
    #97
    Buellride
    Olympia
    THE BOULDER
    Fuel Vectors +19 offset. Thanks for the comment!
  8. Mar 29, 2022 at 8:24 PM
    #98
    tropro
    tropro New Member
    Troy
    MN
    2022 Blueprint Platinum
    I have 34.10 on fac 20's no lift no rub and now have factory flaps. All good. IMG_20220320_163551.jpg
    oxlsu40 likes this.
  9. Mar 29, 2022 at 8:25 PM
    #99
    autcash
    autcash New Member
    Signal Mountain, TN
    2022 SR5 4x4 Celestial Silver 2020 SR5 4x4 Cement Grey
    Black Rhino Odessa wheels 295/70/18 Coopers
    I second this set of tires! Good looking truck!!
    Buellride[QUOTED] likes this.
  10. Mar 29, 2022 at 8:38 PM
    #100
    sparky412
    sparky412 New Member
    SW Pennsylvania
    22 SR5 OR CM 6.5 MGM
    Here is stock setup 18s 69.5lbs
  11. Mar 30, 2022 at 2:50 AM
    #101
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    Although it would add 1,000 lbs more load capability...
  12. Mar 30, 2022 at 6:03 AM
    #102
    Mrconnsmythe
    True dat. If you are hauling, fair enough. Largest item I would haul anywhere is a 5x8 utility trailer :rofl:! No need for an extra 1k load capacity.
  13. Mar 30, 2022 at 10:28 AM
    #103
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    Ya never know. The honey might give the OK for a camper, or a boat, or an ATV.... My 5' x 10' utility, which never sees more than 1,500 lbs, just moved 3,344 lbs, putting who-knows-what strain on the 3,500-lb trailer axle. I knew the load was heavy 'cause I loaded it, but didn't think it was that much.
