T-Case Fluid Change
Discussion in '2.5 Gen Tundras (2014-2021)' started by pvn.beluga, Mar 27, 2022.
  1. Mar 27, 2022 at 6:26 AM
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    For those that have done their t-case fluid change, did you use regular Teflon tape to wrap around the drain and fill plug? How far in did you screw in the plugs?
    And how the heck are you supposed to be able to torque those plugs down to 26 ft/lbs?
  2. Mar 27, 2022 at 8:10 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    I put Teflon tape on the plugs a couple of threads from the end and just tightened plugs a little bit, did not torque them. NPT threads are not really designed for tightening to a specific torque. The plugs were not that tight from the factory. The case is made of aluminum so you don’t want to make them super tight.
    AZBoatHauler and pvn.beluga[OP] like this.
  3. Mar 28, 2022 at 3:40 AM
    Bammer
    Monroe, CT
    No teflon tape required, torque to spec.
    Hugemoose likes this.
  4. Mar 28, 2022 at 4:44 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Practice 26 lb-ft on something else. Thereby "calibrating" your wrist. Then install and snug up the plug.
    26 lb-ft isn't very much past hand tight.
    Oey12 and Terndrerrr like this.
  5. Mar 28, 2022 at 5:52 AM
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    What he said. No teflon tape, just torqued to spec.
    Bammer[QUOTED] likes this.
  6. Mar 28, 2022 at 6:31 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    I wire brushed threads and put on teflon paste. Not sure I would want to torque to 26lb though
  7. Mar 28, 2022 at 6:35 AM
    jeller75
    jeller75 New Member
    Joshua
    NC Mountains
    2017 CC Platinum Pro 4wd
    Another for Teflon tape, no torque needed.
  8. Mar 28, 2022 at 6:40 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    If 26 ft-lbs is spec, then that's what it was before the swap. Set your torque wrench to 26 ft-lbs with a socket on it, and twist on the socket with your hand. It's not much at all.
    I'm about to drain and fill mine. I'm less comfortable guesstimating it.
  9. Mar 28, 2022 at 7:29 AM
    parkerbows
    Jack
    I did do that no way was mine 26 more like 15
  10. Mar 28, 2022 at 7:50 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Just did mine this weekend, used some permatex thread sealant. Definitely was not very tight, didn't wrench on it at all. Stopped once I felt it snug up. No leaks yet after 100-mile test drive.
    pvn.beluga[OP] likes this.
  11. Mar 28, 2022 at 7:54 AM
    parkerbows
    Jack
    Yeah my torque wrench really doesn't work well in reverse. But I marked it and cracked it loose put torque wrench at 26 and it would have went way past original mark. Just wanted to get an idea because it was really loose when I took it off
  12. Mar 28, 2022 at 8:46 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    I'm planning on changing the transfer case and differentials shmoo in the next week or two. I got the permatex thread sealant for the transfer case plugs. Teflon tape should work fine, and with mailable threads (aluminum) and holding back unpressurized shmoo, mildly torqued bare NTP threads should also work fine.
    I like the thread sealant because it also acts like a low strength thread locker.
  13. Mar 28, 2022 at 9:59 AM
    RickPlatinum2020
    Rick
    Eastern PA
    Thread sealant paste also a good option. Key is not to overtighten. Would not recommend putting plug in dry, tape or paste is way to go.
  14. Mar 30, 2022 at 6:09 AM
    737fixer
    737fixer New Member
    Not sure what year your truck is but 2014 and up is a different transfer case and torque should only be 18ft/lbs. Even at 18 you will feel like your going to break something but please don't go to 26ft/lbs. I'll include the Techdoc from Toyota. Just for reference it says to alwaysScreenshot (63).jpg replace the two plugs with new but have no idea why. I ordered a couple out of curiosity and they come with a pretty thin almost clear thread compound on them.
    Terndrerrr and WILLINH like this.
