Tundra width (with mirrors)
Discussion in '2.5 Gen Tundras (2014-2021)' started by PA452, Mar 28, 2022.
  1. Mar 28, 2022 at 8:19 AM
    PA452
    PA452 [OP] New Member
    2021 Tundra SR5 CM TRD O/R
    Anyone know what the overall width of a 2.5gen Tundra is with mirrors extended? I keep finding 80", but I think that's excluding the mirrors.
    Thanks
  2. Mar 28, 2022 at 8:30 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Roll down the windows and take a tape measure to it. I'm curious to know.
    Taco-Spike likes this.
  3. Mar 28, 2022 at 8:41 AM
    PA452
    I'm actually not going to be able to check for a few days at least. My question is related to garage door sizing.
  4. Mar 28, 2022 at 8:50 AM
    Kanobi13
    Kanobi13 New Member
    Would def get a garage door more than 80"
    Terndrerrr and texasrho83 like this.
  5. Mar 28, 2022 at 8:55 AM
    Kanobi13
    Kanobi13 New Member
    107" extended would go more than 9' if you could as would be tight fit
    TundraMidwesterner likes this.
  6. Mar 28, 2022 at 9:01 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    I found 97" to 100" just looking around but I'd have to double check. I know I cant fit in an 8 foot wide door without folding one mirror in. 9 ft wide door or larger would be best for a single car door option.
  7. Mar 28, 2022 at 9:18 AM
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    I can get in my 9’ door with mirrors out, but usually fold them because I can. Actual opening is around 104” if I recall correctly and I have maybe 3-4” clearance on each side with mirrors out.
  8. Mar 29, 2022 at 6:40 PM
    PA452
    Thanks guys. Think I'm going with 10' doors.
    texasrho83 likes this.
  9. Mar 29, 2022 at 6:47 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  10. Mar 29, 2022 at 6:49 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I've measured mine at 96" mirror tip to mirror tip with standard NON towing mirrors. Perfectly the same width as most standard travel trailers. Very convenient :thumbsup:
  11. Mar 29, 2022 at 6:51 PM
    Taco-Spike
    Two Trucks
    Win
    2mchfun and texasrho83[QUOTED] like this.
  12. Mar 30, 2022 at 2:31 AM
    sbtownsend7
    sbtownsend7 New Member
    2021 Barcelona Red Tundra Limited
    Nothing.....YET
    I went with 10' doors simply because I didn't want it to be too close when I park in the garage. I have tow mirrors on mine, but do not have them extended. I think 9' would work, but would be much tighter.
