4wd Coils on 2wd?
Discussion in '1st Gen Tundras (2000-2006)' started by Konniekay91, Mar 24, 2022.
  1. Mar 24, 2022 at 7:24 PM
    Konniekay91
    Konniekay91 [OP] New Member
    Konrad
    2006 Toyota Tundra SR5 Doublecab
    Hey guys! I know that this whole forum is plagued with suspension talk
    But for arguments sake, what would happen if I put 4wd coils on my 2wd DC?
    For context, I recently slapped on some Billy 4600's and the trucks booty is now a half inch higher (or more) than it was on factory shocks, and the ride in the front is pretty damn harsh here on Tucson roads. I do have new yota LBJ and LCA'S coming in, (mine are roasted) but the 360mm springs are tempting to get an extra bit of height in the front. I just don't want to do a whole leveling kit....yet.
  2. Mar 24, 2022 at 7:31 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You might gain a little lift, something around an inch. Double cabs are heavy so hard to know how much.
    @jImmegart had 4x4 coils on his 2wd access cab.
    jImmegart and Konniekay91[OP] like this.
  3. Mar 24, 2022 at 7:35 PM
    Konniekay91
    Konrad
    And that's really all I'm looking for, I tow enough that the rake doesn't bug me, but I can see the excessive dip in the front.
  4. Mar 24, 2022 at 7:46 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Your rear got higher? That doesnt make sense
    Konniekay91[OP] likes this.
  5. Mar 24, 2022 at 7:48 PM
    Konniekay91
    Konrad
    That's exactly what I thought. But those old boys were B.L.O.W.N. and it blew my mind.
  6. Mar 24, 2022 at 10:36 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Yep. New Bilsteins have a pretty good charge to them. Thing about it, is it will settle as they wear...
  7. Mar 24, 2022 at 11:11 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I only know springs by weight, but the 2WD and 4WD are within 50 lbs of each other, sure.
  8. Mar 25, 2022 at 2:40 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Did the DC’s get the progressive springs the early TRDs got? Beefier springs would make the ride harsher.
  9. Mar 25, 2022 at 12:19 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Did you do the 4600’s on both front and back or just rear?
  10. Mar 26, 2022 at 2:53 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Ya, I used to had double cab 4x4 trd bilsteins on the front of my ac. Ill post a picture of before and after but I dont have the actual numbers. Was alittle less or equal to an inch.
  11. Mar 26, 2022 at 10:55 PM
    Konniekay91
    Konrad
    Both. But I also attribute it to the truck still needing a bit of help. The ride in the rear is pretty harsh, the fronts, well ... I'll know more after the LCA and LBJ's. The DC's had the Bilstein springs that have since been discontinued, hence why I was opting for the 360mm 4wd springs.
  12. Mar 29, 2022 at 6:45 AM
    Acatlin96
    Acatlin96 amateur breeze shooter
    Austin
    Central Coast, CA
    2003 AC SR5 V8 4WD TRD
    I bought used coils from an AC, V8, 4wd and put them on my AC, V6, 2wd. I don’t think they ride too harsh, I think they’re firm in a good way and feel planted. I gained roughly 1.5 inches I believe. I personally don’t think the weight difference between 2wd and 4wd coils will make a huge difference, but I’m also not well versed in suspension feel.
