XTREME TRUX FENDER FLARES
Discussion in '2.5 Gen Tundras (2014-2021)' started by kmeindin, Mar 28, 2022.
  1. Mar 28, 2022 at 11:21 AM
    kmeindin
    kmeindin [OP] New Member
    Ken
    2021 Tundra Trail - Cement
    Lomax Cover, Adarac Rails, Yakima Bike Racks, Undercoat, 3M PP, Step
    Hi, Anyone ever installed these Xtreme Trux fender flares ? I have a 2021 Tundra Trail SR5. Looks like I would have to take off the factory mud flaps and maybe install some other mud flap. I like that they only come up 2.25" on the side. Would I need to put some clear protection film down first where the edge of the flare meets the painted body ? Some feedback on how they fit would be great.
    https://www.ebay.ca/itm/233573912183
  2. Mar 28, 2022 at 2:23 PM
    Deacon Blues
    Deacon Blues New Member
    2018 Tundra TRD Off Road
    "Junior to the white courtesy phone please...paging Junior to the white courtesy phone..."
    junior[QUOTED] likes this.
  3. Mar 28, 2022 at 2:27 PM
    2mchfun
    I don't think these are the same. Marker reflector???
  4. Mar 28, 2022 at 2:29 PM
    2mchfun
    I think I have the same flares made by EAG. Also think I paid a whole bunch less like under $20020211120_085609.jpg
    Terndrerrr likes this.
  5. Mar 28, 2022 at 2:39 PM
    2mchfun
    OP, I just did a quick google EAG fender flare Tundra and confirmed under $200. They are decent, nice low profile as well. I cut my front flap along the mold line to maintain body/cab mount coverage, don't need debris in the gap. PM if you need a photo.
  6. Mar 28, 2022 at 2:40 PM
    kmeindin
    Ken
    These look like the same flares. They go up the side about 2.25 " ? Did you install them ? Do they work OK without mud flaps ?
  7. Mar 28, 2022 at 2:41 PM
    2mchfun
    Yes ×3
  8. Mar 28, 2022 at 2:45 PM
    2mchfun
    IMO, these are perfect for rims with a +30mm offset.
  9. Mar 28, 2022 at 2:57 PM
    kmeindin
    Ken
    When I look for the EAG ones is says they fit up to 2020 ? One guy on this forum said he couldnt get them to fit. that there was a big gap on the body on the back ones
  10. Mar 28, 2022 at 3:39 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Thanks! They are the exact flares. I added the fender marker :thumbsup:
  11. Mar 28, 2022 at 3:42 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    OP, these flares have been great for a year and a half. They are a bit finiky to put on, but tightening the bolts carefully and slowly will allow you to put them on evenly. Try to avoid zapping in the mudflap screws with a drill or itll pull it too far in on that part.
    Definitely add some clear paint protection film underneath.
    The gasket they come with kinda sucks, its rounded. I opted for more of a "wiper style" like bushwackers ship with that provides more forgiveness if there are parts of the flare that aren't super even: https://www.amazon.com/gp/product/B08CRMWR7H
    2mchfun likes this.
  12. Mar 28, 2022 at 3:57 PM
    kmeindin
    Ken
    Thank you. They look good. I like the smaller flares. Do you have mud flaps installed ? It's hard to see in that picture.
    2mchfun likes this.
  13. Mar 28, 2022 at 4:18 PM
    2mchfun
    You have to remove the factory flaps, like I said above, I kept the inner part of my front flaps for a good reason.
  14. Mar 28, 2022 at 4:21 PM
    2mchfun
    Can you please provide a close up of the marker reflector?
  15. Mar 28, 2022 at 4:32 PM
    2mchfun
    OP, just noticed you have a cement truck. There is a thread titled "building with cement", he put em' on, and that's where I learned of them as well. Just in case you want to see the look...
  16. Mar 28, 2022 at 4:57 PM
    kmeindin
    Ken
    Thank you I will have a look
    2mchfun likes this.
  17. Mar 28, 2022 at 10:11 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    I’ll just echo exactly what @junior said as I also have these exact flares and went the same route (without the marker). I removed my flaps because from what I can remember the oe flaps won’t work with these guys since they contour onto the body. I’m sure there are others out there that are more minimal that can be tacked on
    kmeindin[OP] likes this.
  18. Apr 6, 2022 at 1:50 PM
    kmeindin
    Ken
    I ordered the fender flares, the wiper style rubber gasket material and the 3/4" X 100' clear door edge paint protection film. Now I just have to figure out how to install them. Also see what mud flaps I can get to work with them.
    2mchfun, junior and RegGex like this.
  19. Apr 6, 2022 at 3:41 PM
    kmeindin
    Ken
    Anyone try using the 3/4" clear paint protection tape ? Can you bend it around in a curve without it kinking ? (lays flat ?) Did you mount the flares first and mark the edge somehow so you know where to put the clear paint protection film.
  20. Apr 6, 2022 at 4:00 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    I think thats about what I have... Might even be 1/2". Its an annoying process but mount them up fully, trace edge where they sit with a dry erase marker (faster than blue tape) and allow yourself to be okay with some margin of error as the flare wont go on exactly the same depending on how tight the screws are in each spot.
  21. Apr 6, 2022 at 5:24 PM
    kmeindin
    Ken
    Good idea marking with erase marker !! I guess mark out about a 1/4” from where they sit. Then I could install the clear tape to the edge of the line. Then it would end up a little higher than the flare edge.
    junior likes this.
  22. Apr 6, 2022 at 5:26 PM
    kmeindin
    Ken
    Did you cut the factory mud flaps off so the top part stays and you put the flare over it. Then mount a rubber mud flap with heavy duty self taping metal type bolts
  23. Apr 6, 2022 at 9:41 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    My factory mudflaps are completely gone so I can't help ya there!
  24. Apr 6, 2022 at 10:11 PM
    kmeindin
    Ken
    So it works OK with just flares and no mud flaps ?
  25. Apr 6, 2022 at 11:18 PM
    2mchfun
    Pretty much, unless you get creative.
  26. Jul 6, 2022 at 5:51 AM
    kmeindin
    Ken
    Finally received and installed the X treme Trux fender flares and some rubber mud flaps. Screwed everything on with black self tapping screws on the flares and self tapers and washers. I really like the look. I got the custom rubber edging for it and put down clear tape first.
    junior likes this.
  27. Jul 6, 2022 at 5:53 AM
    kmeindin
    Ken
    Some more pictures. Thank you for the help !!! I really appreciate it
    Silver17 and junior like this.
  28. Sep 17, 2022 at 12:05 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    This turned out pretty nice! I was looking into some flare options and like the low profile ones. Would you happen to have a link to the mudflaps that worked with these?
  29. Sep 17, 2022 at 3:00 PM
    kmeindin
    Ken
    Silver17 likes this.
  30. Sep 17, 2022 at 3:05 PM
    kmeindin
    Ken
    I asked a guy at a local truck accessories shop before I ordered them off ebay and he said he couldn't get them. He could only get the wide Bushwacker ones. Then once I received the Xteme Trux ones off ebay I didn't have time to install them myself so I asked him to install them. He said he could now get the Xtreme ones. He did a better job installing them for me anyway.
