  1. Mar 26, 2022 at 6:07 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    NUDRAT[OP], bmf4069 and chrisb like this.
  2. Mar 26, 2022 at 7:20 AM
    Drive the GTI out here for "save Ironman 2022" and I'll buy it. We'll get you a plane ticket back. :D
    Darkness[QUOTED], chrisb and GODZILLA like this.
  3. Mar 26, 2022 at 8:51 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    https://www.instagram.com/reel/CbczLt6g81C/
  4. Mar 26, 2022 at 8:56 AM
  5. Mar 26, 2022 at 12:04 PM
    alb1k
    Left Coast
    It's good
    So the recommended gear break-in is done. I have a oil change to do, and another, because.
    4.88 / 275/70/17 (32.2-4?) Thing is quick. Zero economy. 3000rpm at 70MPH
    chrisb, KNABORES, bmf4069 and 3 others like this.
  6. Mar 26, 2022 at 12:07 PM
    Happy belated @Tundra2 !
    Weird. Are you sure they sent the right part? I'm working with Eric right now because Toyota had a bunch of parts mislabeled with the wrong number. He re-ordered twice, and is now reaching out to Toyota for an inventory check.
  7. Mar 26, 2022 at 12:08 PM
    Hell yeah, send audio clip.
    I might've said this already, but that front end needs to come down an inch, maybe new springs? Or the rear needs to come up an inch. I think the latter may look better, the former may require rolling the fenders (you mentioned rolling fenders on something but I dunno what it was)
    bmf4069[QUOTED] likes this.
  8. Mar 26, 2022 at 12:53 PM
    Sunnier
    Sunny
    San Diego, CA
    Fyi, 1st gens tend to accommodate 16” or 17” wheels, so I urge caution if you’re thinking of going larger. The offset isn’t just for clearing the body mount and exterior panels, but control arms, brakes calipers, what not.
    5N0W808[QUOTED] likes this.
  9. Mar 26, 2022 at 1:07 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Real 70mph or according to the speedo?
  10. Mar 26, 2022 at 1:22 PM
    alb1k
    Left Coast
    It's good
    It's speedo 70, but I checked it with gps speed a while back so maybe 73MPH
  11. Mar 26, 2022 at 1:27 PM
    I think the new turd gens are 17”s
    Sunnier[QUOTED] likes this.
  12. Mar 26, 2022 at 3:00 PM
    I'll get a few clips next weekend.
    Trans juice change helped, but not completely. It's still hard to get into 1st and 2nd, and if you wrap it out in 1st, it just straight up won't go into 2nd until it slows down. I'm afraid the clutch wasn't done right. It'll grind going into gears sometimes as well.
    shifty`[QUOTED] likes this.
  13. Mar 26, 2022 at 3:12 PM
    The part number on the bag matches the receipt and online. My gas tank filler neck has threads. The old gas cap has threads. The one they sent is a completely different design and just has two notches. Won't screw in or turn. Very odd.
  14. Mar 26, 2022 at 3:40 PM
    I didn't realize how much shit I had in my shed.
    I got it all cleaned out and added some shelves. I cleared out a corner to put in the 20 ton press. I don't have anyone to help me put it together so I figured me and the TX boys can assemble it. I think we're about ready for "save Ironman 2022" aka "panhandlemonium".
    chrisb, KK6PD, NUDRAT[OP] and 6 others like this.
  15. Mar 26, 2022 at 4:16 PM
    I figured I'd get the press Thursday after work, then start disassembly on the truck. We can put the press together on Friday. Or if I can do it by myself on Thursday I will.
  16. Mar 26, 2022 at 4:20 PM
    I've gotta get these POS rear axles pressed right. I'm hemorrhaging diff juice out the seals.
  17. Mar 26, 2022 at 4:32 PM
    The pile grows. The pile yearns. It hungers.
    chrisb, txagg, Darkness and 3 others like this.
  18. Mar 26, 2022 at 4:57 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    It gets confusing. Before I corrected my speedo the bigger tires sent the speedo down, but the gears sent it up, so it would say I'm going 65 but I was really going 60. I curious what your real speed is, I don't know the 5 speed final ratio.
  19. Mar 26, 2022 at 5:05 PM
    alb1k
    Left Coast
    It's good
    the nav apps are really good 1 would say +/- 1-2 MPH. Ill try it next time i'm on the freeway. I bet if I was 4.56 with these tires it would be fairly accurate. But I'm very happy with 4.88
    Darkness[QUOTED] likes this.
  20. Mar 26, 2022 at 5:07 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Track your gas mileage a bit. It might not go as bad as expected. 3k rpm is where the torque reaches peak so it might be about as efficient as before.
    Maybe test when gas drops below $6 a gallon haha.
    bmf4069 and alb1k[QUOTED] like this.
  21. Mar 26, 2022 at 5:11 PM
    alb1k
    Left Coast
    It's good
    Yeah I should, as soon as I get done with hot starts and general hot-rodding. :)
  22. Mar 26, 2022 at 5:17 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I feel that. After mine broke in I was having a a hard time staying out of it. Every stop light was like a 0-60 test.
    chrisb, Sunnier and alb1k[QUOTED] like this.
  23. Mar 26, 2022 at 5:23 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    This heater must have been pushed to the limit
  24. Mar 26, 2022 at 5:33 PM
    daveeasa
    I’m quite curious how it’ll shake out on this one myself.
  25. Mar 26, 2022 at 6:58 PM
    alb1k
    Left Coast
    It's good
    I was wrong, it hit it a bit on the way home from work. 2750 RPM 70 Speedo
  26. Mar 26, 2022 at 6:59 PM
    Why can I not just buy these tires? What the fuck is discount tires problem? I DONT GIVE A FUCK ABOUT IF THEY FIT. Fucking people and they're bullshit. It's so fucking annoying.
    It tells me this if I hit suggested vehicle or whatever.
    Darkness likes this.
  27. Mar 26, 2022 at 7:02 PM
    alb1k
    Left Coast
    It's good
    It's a company counsel bullshit thing. Enter a truck they are recommended for. 350 Super Duty or something
    5N0W808 likes this.
  28. Mar 26, 2022 at 7:03 PM
    alb1k
    Left Coast
    It's good
    That looks like someone found a way to sit on it.
    chrisb likes this.
  29. Mar 26, 2022 at 7:04 PM
    I'm pretty sure no truck comes with the size I'm after.
  30. Mar 26, 2022 at 7:06 PM
    alb1k
    Left Coast
    It's good
    Well, you know what I mean, Fiat then, lol
