Backing a trailer with tailgate down.
Discussion in '3rd Gen Tundras (2022+)' started by Toyota1234, Mar 24, 2022.
  1. Mar 24, 2022 at 6:27 PM
    Toyota1234
    Toyota1234 [OP] New Member
    Jack
    2022, army green limited, off road, DC
    All right. Everytime I think I figure out how to keep the truck from randomly emergency braking while backing a trailer up in tow haul mode with the tail gate down it will randomly decide it’s going to hit something and slam on the brakes. Has anyone figured out how to prevent this?
  2. Mar 24, 2022 at 6:29 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    not a good idea backing a trailer up with tailgate down. Byebye tailgate sooner or later.
    Hummer, Tileguy, SC4333 and 7 others like this.
  3. Mar 24, 2022 at 6:36 PM
    Solv3nt
    Solv3nt New Member
    Oregon
    2021 SR5 Off-Road 4x4
    Driver side grab handle, Genuine Cooling System Transmission cooler package, Max Modular Bed Rack, White Knuckle Off-road sliders, undercover ultra flex tonneau cover
    Yeah, my experience has been that the tailgate will hit the jack.
    Seafury likes this.
  4. Mar 24, 2022 at 6:42 PM
    Toyota1234
    Jack
    Never going to happen unless I were to jack knife and not notice. But that won’t happen. Because my tailgate is down and I can see everything..
    Tundrastruck91 and Sunnier like this.
  5. Mar 24, 2022 at 6:54 PM
    Sunnier
    Sunny
    San Diego, CA
    There may be a fuse you can pull? This is one of those 2022 fancy gadget things; my 2017 doesn’t have anything like that that locks up when I back up with the tailgate down.
    2mchfun and Tundrastruck91 like this.
  6. Mar 24, 2022 at 8:00 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Next thread "Where do I get a replacement tailgate because I jammed mine into my trailer tongue jack?"
    Not sure, but maybe you can go through the settings and turn off rear parking assist.
    Hummer, Hella Krusty, Wahayes and 7 others like this.
  7. Mar 24, 2022 at 8:12 PM
    Toyota1234
    Jack
    Non issue. But yes that’s what I’m wondering. I have turned off a lot of setting but still it does it.
  8. Mar 24, 2022 at 8:23 PM
    tropro
    tropro New Member
    Troy
    MN
    2022 Blueprint Platinum
    There is a button by your left knee that turns off break assist. I have to turn mine off when I park in the garage because the truck thinks I'm going to hit the wall. Maybe this will work for you?
  9. Mar 24, 2022 at 8:24 PM
    TTund16
    TTund16 New Member
    How does the car know how long the trailer is to apply brakes?
    Or does it use the rear bumper sensors to prevent you (the rear bumper) from hitting something. Like my '16 beeps if I get close to an object but doesn't apply brake!
    So if the truck is going by the rear bumper proximity sensors and not the real end of your trailer, then maybe the tailgate down interferes with the sensor. Just a guess.
    Also why tow-haul mode when backing up? I would turn that off to eliminate super sensitivity of the gas pedal.
  10. Mar 24, 2022 at 8:31 PM
    Toyota1234
    Jack
    that sounds like the button I’m looking for. I’ll have to check that out tomorrow thanks !
  11. Mar 24, 2022 at 8:33 PM
    Toyota1234
    Jack
    Idk just adding information. It’s slamming into the brakes because it senses the trailer as a object I’m going to hit. But when it does it, it seems very random. You would think in tow haul it would turn off something like that.
    TTund16[QUOTED] likes this.
  12. Mar 24, 2022 at 8:39 PM
    TTund16
    TTund16 New Member
    very good point about the possibility of tow-haul mode turning off that feature when backing up!
    sounds like it doesn't know or care that you have a trailer and it's not smart enough ...
    if that's the case, I'm guessing moving left for right when backing up can prematurely trigger the proximity sensors since you get closer to an object (right or left end of your trailer).
    I've seen Ford commercial with backup cameras showing everything when towing and thought Toyota is doing the same thing now.
    Toyota BSM for example can't handle towing. That's why Toyota tow mirrors don't or didn't come with BSM. Toyota doesn't spend much time on some advanced electronic features like American trucks do.
  13. Mar 24, 2022 at 9:11 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Genuinely curious, why back up with the tailgate down?
    Wahayes likes this.
  14. Mar 25, 2022 at 4:31 AM
    nuclear
    nuclear New Member
    Not an issue for me since I have a larger boat, but I know for people with small jon boats or jet skis it is preferred because without doing so it can be very difficult to see what the trailer is doing.
  15. Mar 25, 2022 at 5:38 AM
    2mchfun
    Fwiw guys, some trailers have really long tongue lengths and also folding jacks so hitting the tailgate is not always a concern. If the trailer is small, there may not even be a jack at all, and a 4' wide trailer is difficult to see in the mirrors. Carry on!
    Maharisc and Sunnier like this.
  16. Mar 25, 2022 at 6:01 AM
    WasAChevy
    WasAChevy New Member
    So what exactly is the process for hooking up and pulling (including backing) a trailer? I have not gotten that far yet.
  17. Mar 25, 2022 at 6:17 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    On my 2018 when I am backing up with the tailgate down I get random proximity warnings when nothing is there (like it temporarily senses the tailgate) maybe yours is doing the same and applying the brake. Is the camera useless when backing the trailer? Kinda seems like that was its purpose
    TTund16 likes this.
  18. Mar 25, 2022 at 9:02 AM
    Toyota1234
    Jack
    When the tail gate is up I can’t see the wheels or most of the boat which makes a tight back up job more difficult. Specially when my boat is off the trailer and I can’t see it at all with the tail gate up. If I just open the tail gate I can back up around anything very quickly without issue because I can see everything.
  19. Mar 25, 2022 at 9:10 AM
    Toyota1234
    Jack
    You can use the camera but it’s very counter intuitive to me and much much slower then just turning my head and looking out the back window. I launch a boat about 40 times a year and am very good at it. When I’m at the launch I want to do my business as fast as I can and get out of the way. I don’t want to be one of those guys that’s spends 5 minutes trying to use his mirrors to back down a boat holding up the launch line.
    then when I get home I have to back my trailer around a 90 degree corner up a driveway that it barely fits up. Again, being able to see my wheels while looking through the back window is huge. Not a problem with the tailgate down but the emergency brakes coming on a time or two every time is a huge pain.
    For you guys that have never backed a boat trailer with the tailgate down allowing you to see everything you should try it.
    Leo's first and 2mchfun like this.
  20. Mar 25, 2022 at 9:17 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    unless i missed it mentioned...doesn't yours have cross traffic alert. it may be breakin because of that setting? i'm not 100% sure if it would apply breaks in that situation, but just a thought to see if it would help ya.
  21. Mar 25, 2022 at 9:49 AM
    Toyota1234
    Jack
    I’m pretty sure this is the button I need to push to turn off this system. Thanks I’ll give it a try next tow.
  22. Mar 25, 2022 at 10:42 AM
    tropro
    tropro New Member
    Troy
    MN
    yep, that's it!
  23. Mar 25, 2022 at 10:57 AM
    ArizonaKevin
    ArizonaKevin New Member
    Kevin
    Have you tried backing up with the tailgate down and no trailer attached? Or tailgate up trailer attached? I'm curious as to the variable that is causing it to stop, is it the trailer, or the tailgate, or combination.
  24. Mar 25, 2022 at 5:49 PM
    Mobeyk
    Mobeyk New Member
    That's why I installed a rear camera up at my third brake light. When I back up I see everything in that camera.
  25. Mar 26, 2022 at 11:09 AM
    gj953
    gj953 New Member
    East Coast
    2023 1794 Hybrid TRD OR Blueprint
    See pages 19 and 299 for how this switch PKSB (Parking Support Brake) works in the owners manual.
  26. Mar 26, 2022 at 12:06 PM
    Toyota1234
    Jack
    Good question. Now that you mention it that sounds like a thing that has happened.
  27. Mar 26, 2022 at 9:38 PM
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    Take a look at pg 302 in the owner's manual (302 in the Canadian version so may be on a slightly different place in the US version) regarding the PKSB (parking support brake). One thing I read is that if you are using a 7-pin on your trailer, the PKSB will automatically be switched off along with the rear sensors. If you are using a 4-pin, you have to do it manually using the button found near the driver door.
    TTund16 likes this.
  28. Mar 27, 2022 at 5:38 AM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    I use a 7 pin truck connector that connects to a 4-pin trailer connector and the RCTA shuts off, but the PKSB did not.
  29. Mar 27, 2022 at 7:06 AM
    ThePolak
    Hmm. Maybe it needs to sense load on the reverse pin on the 7 pin which you wouldn’t have on a 4 pin /7 pin adapter. Either way that’s a pain because I have 4 pin connectors on my trailers and was hoping an adapter would do the trick.
  30. Mar 27, 2022 at 11:38 AM
    Toyota1234
    Jack
    I am using a 4 pin trailer with 7 pin converter also. It’s just easier to connect.
    I think it does need to sense the 7 wires. Not just the plug.
    dekeman likes this.
