Getting far fewer miles on a full tank - ideas?
Discussion in '2.5 Gen Tundras (2014-2021)' started by JKelRamsFan, Mar 9, 2022.
  1. Mar 22, 2022 at 11:34 AM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Thanks for the explanation - makes more sense now. Maybe it's just condensation you're seeing at start-up and I hope no oil smoke. I have to believe though that a loose timing chain tensioner can't be helping your engine performance. It could affect your mileage as your engine is working harder.
    I have family down in Savannah - great city!
    All the Best.
  2. Mar 22, 2022 at 11:52 AM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Yea the startup smoke is likely water vapor, as I see water dripping out the pipes often.
    I am sure the lose tensioner is not helping my engine but it's not jumping timing or doing anything the ECU can not compensate for within parameters.
    Yea we were visiting family in Beaufort SC and staying in HH and visited Savannah to site see.
    Savannah is beautiful and old, but downtown parking is a nightmare like every city lol.
    Badknees[QUOTED] likes this.
  3. Mar 22, 2022 at 11:59 AM
    Badknees
    Badknees New Member
    Just curious, but how does the ECU compensate for a loose timing chain? Retard/advance the timing? I'm certainly no expert, but I can't see how it can react fast enough for erratic/unknown chain tension changes and even if it tried to, it would be too late and off correction anyhow. Then again, I'm no expert.
    Best.
  4. Mar 22, 2022 at 12:06 PM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    This might be a long shot but have you had your brakes and calipers inspected. The age and mileage and areas you take your vehicle would seem suspect to check for rust around the rotors or possibly stuck calipers slightly grinding to cause some MPG loss. Like I said, a shot in the dark but worth looking into as well as tire pressure and alignments.
  5. Mar 22, 2022 at 12:15 PM
    Seafury
    Agent K
    SC Low Country
    Unless the chain jumps teeth causing off timing it really doesn't do much at all.
    But yes, as you said correctly the ECU can adjust timing (within limits) and as you may know computers tend to be really fast :thumbsup:
    If it jumps a tooth (or more) I could be fooked, which is the real worry here, along with damage to the chain itself and the housing/mount for the tensioner due to all the slapping around.
    I really need to get it fixed but don't have the $2k+ to spare right now and have not even begun looking for a qualified master tech I can trust to do this open heart surgery right the first time.
    I have the experience, skills, and tools to do it myself, but I don't have a driveway, or garage in my shity townhouse, and have no desire to work on cars anymore ever.
    I don't even have the motivation to push my front plastic wheel wells forward to stop the rubbing in reverse from my new 34" tires :oops:
    Doing my own front pads and rotors a few weeks ago was hateful and took 3 days before I felt right again physically.
    Most of which probably has to so with working on the fricken ground and being out of shape for this crap, not to mention over 40.
    My swollen nutz (on the truck) didn't make it any easier having to hammer and pry the socket on and off every lugnut either.
    I'm out of shape and maybe sick and dying of cancer or something but whatever :burnrubber:
  6. Mar 22, 2022 at 12:22 PM
    Seafury
    Agent K
    SC Low Country
    Thats good advice right there, nice work!
    I did check all this already, and per my above post recently replaced and lubed front pads and rotors.
    Something dragging was one of the first things I looked into as it is more common then people realize.
    My truck however has almost no rust and its mainly on the TRD exhaust which will need to be replaced in the coming few years probably.
    Even though the 1st owner lived in VA beach, the truck must have been garage kept and not driven much.
    I became the second owner after buying it from carmaxrip-off in Feb 2019 with about 53k miles.
    It's been on the beach in OBX for a week twice, and spent a week in Hilton Head SC/Savannah GA, otherwise lives outside in Northern Va.
    Working from home I also don't have to drive in the snow and salt much, but do go out for a joy ride in any decent snow event.
    Gotta get my donuts in to keep my figure :rofl:
    g6t9ed[QUOTED] likes this.
  7. Mar 22, 2022 at 2:04 PM
    Wallygator
    I just went from 14.2 mpg to about 16.3 mpg by adding air to my tires. Have Falken wild peak atw3's load range E that were at around 38 psi. Put 52 psi in the front and 55 psi in the rear. Sidewall states it can goto 80 psi. I think it rides better on the road with more air in it. Of course off road not so much.
  8. Mar 23, 2022 at 6:04 AM
    Seafury
    Agent K
    SC Low Country
    Higher air pressure in your tires will help mpg some yes.
    But as a trade off your E rated tires will wear out early and unevenly.
    Air pressure is based on vehicle weight and load.
    E rated tires are overkill and not designed for our Tundra's so anything over 35-45psi pushes the tire shape into unwanted territory for wear/lifespan.
    Higher psi also puts more load on your suspension and significantly reduces ride quality.
    I am already running the high end with an always unloaded truck and 45psi.
    There are threads on this issue you can research for more information, but don't run that kind of pressure unless you are loaded down/towing heavy etc.
    Wallygator[QUOTED] likes this.
  9. Mar 23, 2022 at 4:53 PM
    Wallygator
    Thank you for the advice. A little background. I carry a lot of weight. Vehicle has all my gear, recovery gear, tools, and camping gear 24/7. Plus the skids, fridge, other mods, it's pushing 6500 lbs rolling.
    Honestly one of the best mods I did right away was put E's on it.
    The tires are rated up to 80 psi. I run around 36-38 since getting the tires and now mid 50's due to fuel costs.
    This is the first time in two years I have pumped them up past 40 psi. I will monitor them closely for cupping, etc.
  10. Mar 24, 2022 at 4:43 AM
    Seafury
    Agent K
    SC Low Country
    Your welcome.
    Your weight will certainly help with high psi for sure.
    I may still want to keep it under 50, based on what we have seen here from tire reps recommending psi to us, but keep an eye on it and see how it does.
    Better mpg is always good, but not at the cost of $1400 tires :thumbsup:
