Roadmaster Active Suspension
Discussion in 'Suspension' started by Boisefly, Mar 21, 2022.
  1. Mar 21, 2022 at 11:20 AM
    Boisefly
    Boisefly [OP] New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Anybody running this product? I am getting tired of the sag when loading up with camping and work supplies.
    Do you suggest the HD or standard version?
    Thanks.
  2. Mar 21, 2022 at 11:27 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Heard it works great for towing. Just do a quick search and you'll find lots of info.
  3. Mar 21, 2022 at 11:58 AM
    2mchfun
    Yep, I run the HD. Buy it! You can't go wrong!
    r1-superstar and Boisefly[OP] like this.
  4. Mar 21, 2022 at 12:21 PM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    I have the standard and it works great
    ^^^ he’s right can’t really go wrong.
    2mchfun and Boisefly[OP] like this.
  5. Mar 21, 2022 at 12:31 PM
    Boisefly
    Boise, ID
    Right on. I don't tow heavy loads so I think the HD would be more than I need. Just ordered the standard system. Thanks for the replies!!
    2mchfun likes this.
  6. Mar 21, 2022 at 12:34 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Buddy just bought the HD. We are slapping it on sometime this week.
  7. Mar 21, 2022 at 4:05 PM
    FlightMedicRN
    FlightMedicRN New Member
    2020 Super White Crew Max- TSS SR5
    Interior chrome delete- AJT Designs, S&B Cold air intake, 10" BAMuffler exhaust system, color-keyed bumper covers, LED fog lights, TuffSkins interior inserts, black exhaust tail pipe and tip, Peragon tonneau cover.
    I have the RAS-HD for the past year and regularly tow a 27' TT. I bought the HD because I'd rather "over do it" with the heavier loads I pull/ carry. I previously had Sumo Springs only but added the RAS-HD after their was still a bit of sag and I wanted true support for the suspension and leaf springs. Porpoising has disappeared since adding the RAS-HD and towing has been much more pleasurable.....I also always tow with a WDH.
  8. Mar 21, 2022 at 8:00 PM
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    Mine just arrived today.
    Went with the HD as I only wanted to buy once and can adjust as needed.
    Will be installing mine at 1mm spacing and see from there.
    I tow a small 20ft TT about 3500lbs then all my gear in the bed.
    It sags quite a bit. and from the reviews I've read and research I've done.
    I think this will solve my issues. Also I tow this trailer without a WDH.
    r1-superstar likes this.
  9. Mar 22, 2022 at 10:33 AM
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
    Has anyone used this system with the Ironman Foam Cell Pro suspension? I've been thinking about getting this but was wondering if anyone has the same type of setup.
  10. Mar 22, 2022 at 10:42 AM
    2mchfun
    I use it in conjuction with HD suspension upgrades such as Dobinson's HD 5+2 leaf packs and Yellow Sumo Springs as well. My truck sags very little with over 3k in the bed.
    Chucho and Explorer[QUOTED] like this.
  11. Mar 23, 2022 at 10:30 AM
    Boisefly
    Boise, ID
    How much did it increase your lift in the rear when fully unloaded?
  12. Mar 23, 2022 at 10:30 AM
    Boisefly
    Boise, ID
  13. Mar 23, 2022 at 10:40 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    There are quite a bit of folk running the RAS. If you use the search function you will find loads of info.
    I have the HD version.
  14. Mar 23, 2022 at 10:41 AM
    r1-superstar
    DB
    UTAH
    You will have a 1" lift with the SD or HD set at 25%. 40% will gain you another .5" or so.
    Boisefly[QUOTED][OP] likes this.
  15. Mar 23, 2022 at 11:25 AM
    2mchfun
    I installed an entire new HD rear suspension simultaneously, so I have no b4 and after lift comparison data. I just know the cheap ass literally made in Mexico components were total garbage and I'm glad they are history! Tundra might be assembled in America, but it is far from made in the U.S.A.
  16. Mar 23, 2022 at 12:47 PM
    FlightMedicRN
    I believe it increased the lift in the rear about an 1" or 1 1/2"
  17. Mar 23, 2022 at 1:40 PM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    I know when my bed is some what empty it raised the rear just over an 1” or so when I have a load in the back it’s pretty much level I installed it because my rear end was sagging now it’s perfect. Hopefully this helps
  18. Mar 23, 2022 at 2:12 PM
    Boisefly
    Boise, ID
    Thanks guys.
    2mchfun likes this.
