17" 2005 tundra wheels/FJ wheel ?
Discussion in 'Wheels & Tires' started by handwerk, Mar 21, 2022.
  1. Mar 21, 2022 at 6:07 AM
    handwerk
    handwerk [OP] New Member
    Anybody know if the FJ Crusier 17 "x 7.5" "wheel has the same off set/backspace as my 2005 OEM 17" x 7.5" wheels?
  2. Mar 23, 2022 at 7:37 AM
    Hummer
    Hummer New Member
    2023 Tundra CrewMax Limited 10K miles
    Studs Baby, Studs!
    Yes, both offset and backspace are the same so the wheels will fit perfectly. The tires from the FJ, 285/70R17, were too large to fit on the Tundra so they're up for sale.
    I wanted a second set of wheels for snow rated tires for easier seasonal changes. I mounted new Nokian Hakkapeliitta LT3 studded tires. Awesome traction made in Finland. It gives my trusty Gen 1 Tundra a new look.
  3. Mar 23, 2022 at 7:39 AM
    Welcome from NY.
  4. Mar 23, 2022 at 9:38 AM
    handwerk
    Hummer where were the 285's rubbing or causing problems?
  5. Mar 23, 2022 at 11:40 AM
    Hummer
    Hummer New Member
    Studs Baby, Studs!
    I didn't attempt to mount them as they were obviously too large without modifying the truck suspension which I'm not interested in. I want plenty of space within the wheel wells so I can mount four-wheel chains when necessary. The folks at Discount Tire told me the 285/70 tire was 0.79" wider and 2" taller than my 265R65 17 tires.
