Worst mpg 8.5!!!
Discussion in 'General Tundra Discussion' started by CamaroSsToTundra, Mar 22, 2022.
  1. Mar 22, 2022 at 11:42 PM
    CamaroSsToTundra
    CamaroSsToTundra [OP] New Member
    Ohio
    2018 Tundra
    I have 2018 tundra with 7 inch lift and 37/12.50/20 Falken wildpeak tires with 20x12 -51 wheels. I was not paying attention earlier but I just noticed other day my mpg is pretty bad. I know tundra has worst gas mileage. But 8.5mpg is pretty bad. I just switched to 37s 6-7months ago. I had 35s before and gas mileage was like 11 or 12. What should I do bring back the little better gas mileage? Should I switch to 35s or regear or something?
  2. Mar 23, 2022 at 12:01 AM
    AZBoatHauler
    So.Arizona
    What mpgs are you looking for? Me trying to calculate the added rotational mass of 20x12 wheels with 37” tires…
    excelw, Sumo91, ToyoMafia and 7 others like this.
  3. Mar 23, 2022 at 12:15 AM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    May be atleast 11 or 12mpg
  4. Mar 23, 2022 at 12:18 AM
    AZBoatHauler
    So.Arizona
    I get 12ish with 34s on stock TRD OR 18” alloys. I do run a full set of skids and sliders.
  5. Mar 23, 2022 at 12:20 AM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    Yeah I think it’s tires.
  6. Mar 23, 2022 at 2:23 AM
    1eyedclyde
    1eyedclyde New Member
    Clyde
    NewCastle CO
    21 SC Pearl Platinum
    Re gear time!
  7. Mar 23, 2022 at 4:41 AM
    Lower it back down and put smaller, lighter, narrower tires on it. Gas mileage will magically improve. Or, keep it the way you want it and get a cheap beater to commute in.
    Oey12, snivilous, Black Wolf and 2 others like this.
  8. Mar 23, 2022 at 5:00 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    This is the real answer. Don't overthink it.
    I'm all stock on wheels & suspension (don't mind the 9psi Blower) and I get 17mpg avg driving like an adult.
    Yes, I get wayyy less whenever I hit PE/open loop. But I tend to drive like a paw-paw.
  9. Mar 23, 2022 at 5:14 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    If you’re going by the dash, your computer thinks you’re on the stock 275/65R18s.
    A 37” tire is 15.3% larger in circumference. So your 8.5 mpg corrected for tire size is 9.8 mpg. Still…not great. But with a 7” lift, 37s, and factory gearing, you may as well be dragging an open parachute behind the truck everywhere you go.
    I’m at 14 combined in my ‘21 with a 2” lift and 285/75s.
  10. Mar 23, 2022 at 5:56 AM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    Yeah I think I need to go back to 35 inch tires.
    Terndrerrr likes this.
  11. Mar 23, 2022 at 6:05 AM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Or a more reasonable lift
  12. Mar 23, 2022 at 6:21 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Normal, there is no issue. 7 inch lift and 37s, why would you even consider MPG running such a setup?
    Smaller lighter tires or regear to 5.29s will help MPG, but you will need to spend $ for that which negates the MPG improvement you will see....its still costing you $$$.
    Regear is costly , you will never recoup the cost of the regear in MPG savings. You built the truck as you wanted, and 9-10MPG with your setup is completely normal. You may see 1MPG improvement dropping back down to 35s. But again, you may not recoup the cost of changing to 35s in the minor MPG improvement. It would take a LONG time to get back the $1500 in tires with 1-2 MPG improvement. Regear costs even more, doubt you would recoup the cost in MPG improvement over several years.
    Oey12, Sunnier and Bammer like this.
  13. Mar 23, 2022 at 6:32 AM
    2mchfun
    3" lift, 35's, lots of armor, heavy foot, stock gears, getting about 11-12 so you really won't gain a bunch. Life is too short, just enjoy the ride.
    CamaroSsToTundra[OP] likes this.
  14. Mar 23, 2022 at 6:34 AM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    Haha I was enjoying until this gas prices sky rocketed
    2mchfun[QUOTED] likes this.
  15. Mar 23, 2022 at 6:35 AM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    That’s kinda true but with 35s I was getting mpg in between 11-14mpg
  16. Mar 23, 2022 at 6:38 AM
    frichco228
    Frank
    Virginia
    it is what it is, costs $ to have a big truck. Your truck looks great however. When the stock EPA is 13/17, getting 10ish with that lift and 37s is really not bad at all.
  17. Mar 23, 2022 at 6:45 AM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Change your driving habits. Don’t get on the gas so much, ease into acceleration and coast when you can. Not much anyone can tell you, sorry but complaining about mpg with your setup is a little silly.
  18. Mar 23, 2022 at 6:49 AM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    I already started driving less. I hope these gas prices will go down soon.:spending:
  19. Mar 23, 2022 at 7:21 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    echo pretty much what almost all the others said above.
    also, check your tire size difference to your mileage difference. when i went to 325/60R20's, the difference was pretty close to 10%. which means my speed was off 10%, as well as my driven miles. recheck manually, and you'll prob see higher than what the cluster is showing you. i think i was getting about 1-1.5 better mpg than what the cluster was telling me. but when i did my lift, i knew that a big lift n tires meant bigger gas bills, bigger expenses, bigger haters, etc, etc.
  20. Mar 23, 2022 at 8:09 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I put a cold air intake and throttle body spacer on and got about 1.5 mpg increase. Then I put new wheels and 295/70r18 tires on. I lost about 3 mpg. So, I’m in the negative for mpg from stock to where I’m at now. Now I’m at around 13 mpg on average.
  21. Mar 23, 2022 at 8:15 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Don't sugarcoat it, that's a synonym for driving slow as fuck :rofl:
  22. Mar 23, 2022 at 8:40 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    slower.
    so slow that I now need to throw some $'s at the stock stereo.
  23. Mar 23, 2022 at 8:56 AM
    TundraLLama
    TundraLLama New Member
    Massachusetts
    2015 Black Platinum Tundra
    Color matched mirror caps and door handles TRD dual exhaust TRD shift knob TRD Pro FOX shocks Spray in LINEX bed liner TRD 18” wheels FOX TRD Pro suspension Michelin 275/65r18 LTX AT2 Soft top Roll up bed cover Go Rhino RB10 running boards TRD Pro LED blackout headlights TRD Pro LED blackout fog lights TRD Pro grille AJT DESIGN blackout vent/shift/cup holder Wireless charging tray Remote starter Upgraded alpine speakers, amp, dual sub box. Rear underseat storage.
    Falken Wildpeaks are a heavy tire compared to other ATs. I have Falkens 275/70 r18 with TRD pro fox suspension on my 2015 and get 12.6. I was gonna switch to Toyo at3s which are considerably lighter during the pandemic but they were out of stock. Lord knows what they cost now.
