Brake Caliper Kit for 2021
Discussion in '2.5 Gen Tundras (2014-2021)' started by Katsu0, Mar 18, 2022.
  1. Mar 18, 2022 at 9:57 PM
    Katsu0
    Katsu0 [OP] New Member
    2021 Magnetic Gray TRD Sport
    Does anyone know if a 6piston front and 4 piston rear kit exists for a 2021? Wanted to swap out calipers only and will do the rotors later... TIA
  2. Mar 18, 2022 at 9:59 PM
    What the!?
    What the!? New Member
    2017 Pro
  3. Mar 21, 2022 at 4:29 PM
    Katsu0
  4. Mar 22, 2022 at 9:54 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Well not sure you'll find a kit only for calibers as the size needed to run the caliber may need more rotor surface area. Alcon makes a full front and rear kit that we just did on my old mans tundra. Fits under a 17" also.
  5. Mar 22, 2022 at 10:08 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    The ST60 front works on stock rotors, the rear need 380mm rotors cause the spacing of brackets, I have the front with factory rotors.
  6. Mar 24, 2022 at 2:57 PM
    Katsu0
    Has anyone installed brake parts from R1 Concepts?
