Shocks part number
Discussion in '2nd Gen Tundras (2007-2013)' started by alexusw, Mar 21, 2022.
  1. Mar 21, 2022 at 7:40 AM
    alexusw
    alexusw [OP] New Member
    2007 Desert Sand Mica Tundra LTD
    Does anybody know the part number for the light blue shocks that come stock on the 2007 Tundra with TRD off-road. It’s hard to tell but when I look from the other side it has Toyota Bilstein and it’s completely blue. With this truck having over 200k miles, it doesn’t look like the shocks has been replaced. It’s still tight, and recently started having a light squeak when going over speed bumps and only speed bumps. So I was thinking that it could be the ball joints. It drives fine over small bumps and all other road imperfections but with speed bumps I can hear it squeak. I have attached a picture showing the shock that’s in the rear.
  2. Mar 21, 2022 at 7:51 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Those may be Toyota's TRD or 'offroad' shocks.
    Although not the exact same thing as stock, Bilstein 4600s are very similar.
    I would shop around for the best price.
    Bilstein B6 4600 Monotube Gas OEM Shocks Set for 2007-2021 Toyota Tund – Shock Surplus
    @Roman could give the Toyota shock part numbers.
    My guess would be these for offroad shocks, but you'd need to verify.
    Not sure why 2 or 4 wd rear and/of front CM or DC would have different part numbers.
    front
    CM
    2007-2019 Toyota Tundra Shock Absorber 48510-09R30 | Toyota of Cool Springs vParts
    DC
    2007-2019 Toyota Tundra Shock Absorber 48510-09R10 | Toyota of Cool Springs vParts
    rear
    4wd 2007-2013 Toyota Tundra Shock Absorber 48530-09N50 | Toyota of Cool Springs vParts
    2wd 2007-2013 Toyota Tundra Shock Absorber (Left, Right, Rear) 48530-09N20 | Toyota of Cool Springs vParts
    Roman and alexusw[OP] like this.
  3. Mar 21, 2022 at 8:00 AM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    I recently replaced mine and got them from Rock Auto (Bilsteins).
    alexusw[QUOTED][OP] likes this.
  4. Mar 21, 2022 at 9:48 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    There's four different part numbers for TRD Off Road shocks depending on your particular truck. Shoot me your VIN, and I can look up the correct ones you'll need if you want OEM.
  5. Mar 21, 2022 at 12:05 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
