Tundra rusty bracket replacement
Discussion in '2.5 Gen Tundras (2014-2021)' started by Drw814, Mar 20, 2022.
  1. Mar 20, 2022 at 2:42 PM
    Drw814
    Drw814 [OP] New Member
    Drew
    2020 TRD off-road doublecab voodoo blue
    Hello all, I noticed some surface rust on one of the brackets at the rear of the truck. Looks like the hardware Toyota used to mount it has rusted over this past New England winter. I am going to remove the bracket and replace the hardware with stainless. I will most likely wire wheel the surface rust off then coat it in something to prevent it from re-occurring. I am just wondering what this bracket is called? It’s just in front of the driver side rear wheel well.
  2. Mar 20, 2022 at 3:45 PM
    Drw814
    Drew
    That was one option, I just can’t seem to find the bracket online. No idea what it’s actually called. I have tried exploded parts views and can’t find it.
  3. Mar 20, 2022 at 8:25 PM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    I'll look at mine this week. I also hate rust. should you determine the part number please post.
  4. Mar 26, 2022 at 2:53 PM
    Drw814
    Drew
    Had some free time today so took care of this. Removed the bracket, it is a 2 piece with the top piece acting as a clamp. Wire wheeled all the rust off, clear coated it and installed with new stainless hardware. See pics attached:
  5. Mar 26, 2022 at 4:03 PM
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    Looks great!
    Drw814[OP] likes this.
  6. Mar 28, 2022 at 5:52 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I had an exhaust pipe hanger on my truck for some reason rusted. everything else perfect, could see it from wheel well. looked like crap. sprayed some liquid film on it and it no longer looks rusted been in tons of rain and dirt and as far as I am concerned arrested all corrosion. about 3 seconds to spray it on.
  7. Mar 28, 2022 at 4:24 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Seems Toyota uses some very cheap quality uncoated nuts and bolts on the underside of these trucks. After the 1st winter and some look like they are 10 yrs old already..Not cool. I try to spray Fluid Film on all i can access
  8. Mar 28, 2022 at 4:28 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    This is what I love to do!!
