Lighting placement....which looks better?
Discussion in 'Lighting' started by Tundra234, Mar 20, 2022.
  1. Mar 20, 2022 at 5:56 AM
    Tundra234 [OP] New Member
    Now I'm thinking, which looks better? Leave them behind the grille or remove the bar in the bumper and space them out there?
    des2mtn likes this.
  2. Mar 20, 2022 at 6:06 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    I like the stealth look...picture 1.
    SPP
    Wallygator likes this.
  3. Mar 20, 2022 at 6:10 AM
    Double DC
    Double DC New Member
    2005 DC & 2021 DC
    I vote for #1 as well. Just looks a bit cleaner - which I prefer.
  4. Mar 20, 2022 at 6:12 AM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Looks better without. What is the purpose of them? Your s8 plus the 5 other lights don’t already give enough output?
    1lowlife likes this.
  5. Mar 20, 2022 at 7:12 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    More lights can get you unstuck faster :p
    1lowlife, pvn.beluga and des2mtn like this.
  6. Mar 20, 2022 at 1:40 PM
    I had them on my 2013 so I wanted to find a spot for them since they were expensive.
    cctxquicksand[QUOTED] likes this.
  7. Mar 20, 2022 at 2:28 PM
    cctxquicksand
    What about using them as ditch lights and maybe some chase lights?
  8. Mar 20, 2022 at 3:14 PM
    Not in the grille. Make the ditch lights 2 straight and 2 angled to the side.
  9. Mar 20, 2022 at 4:28 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Pic #1 definitely looks better.
  10. Mar 22, 2022 at 12:27 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    also for 1
  11. Mar 23, 2022 at 1:53 PM
    009m
    009m New Member
    2010 Black Tundra Platinum
    Tuner, cold air intake, catback exhaust
    Top one for sure, the pods in the grill seem a little overkill, keep it simple man.
  12. Mar 23, 2022 at 2:37 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I don't know much about lights, but I would keep them behind the grille and point them at an angle towards the sides of the truck. Essentially working as Ditch lights but hidden behind the grille. Your lower bar provides enough coverage directly in front of the truck. Your s8 will throw light a ways down the road so those behind the grille can hit the areas to the left and right and give you almost full visibility in front of you.
  13. Mar 24, 2022 at 10:51 AM
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    2010 SR5 & 2021 TRD Pro
    Top one. Keep it clean.
    ...and you can always sell the extras.
    WVI likes this.
  14. Mar 26, 2022 at 6:21 PM
    So I took the lights out. I didn't like the one touching the grill or the cooler. After putting it back together, the grill is being a pita with alignment. The gap where it meets the bulge is twice the size on the drivers side. Now the body lines are not lining up with the bulge either. I also do not like the gaps between the grill and surround on the sides. It actually broke 1 clip mount on one side of the surround....I had to JB Weld it. I spent all day messing with it and I'm really pissed off with the whole install. I will most likely order another OEM Sport honeycomb grill and throw this one a way. A waste of $800.
  15. Mar 26, 2022 at 6:31 PM
    19 Cement Lmtd
    19 Cement Lmtd New Member
    2019 Cement Tundra Limited TRD Off-Road
    Leveling kit w/2 in. lift, aftermarket wheels, and tires
    Pic #1. It is a much cleaner look.
  16. Mar 26, 2022 at 6:33 PM
    See post above your reply.
  17. Mar 26, 2022 at 6:54 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    That sucks, I had it when stuff like that happens. Glad I'm not the only one who's OCD gets the best of them.
  18. Mar 26, 2022 at 6:57 PM
    I don't know if it would sell it on here or not. Maybe someone with more experience with this type of grill would mess with it.
  19. Mar 27, 2022 at 12:02 AM
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    Man... that sucks about the grill. Maybe it just was not meant to be. Hopefully you're not pissed at all of us who provided the feedback. ;)
    As far as the grill, maybe upgrade to the newest TRD Pro. :boink:
    Also, I just remembered that my friend has those lights on his '16 TRD Pro and it actually looks pretty clean with the '16 TRD Pro grill (assuming you would like to keep the lights). If you want, I can try to snap a picture today or Monday.
  20. Mar 27, 2022 at 5:42 AM
    Now that I'm thinking about it, someone else on here had their Trex grill cause issues as well. If I recall, it broke the clips and sagged. I think it puts too much stress on the weak mounting points on the surround.
  21. Mar 27, 2022 at 2:34 PM
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    This is what my friend did on his 2016 OEM grill.
    TucsonTundra1794 likes this.
  22. Mar 27, 2022 at 2:41 PM
    Not bad. I'm still pissed off at the whole mess. I'm half tempted to sawz all the thing in half and send pics to Trex.
  23. Mar 27, 2022 at 2:45 PM
  24. Mar 27, 2022 at 2:53 PM
    2mchfun
    Just an idea, have you considered a Nightshade Ed. Grill?
  25. Mar 27, 2022 at 2:58 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    That grill was $800 o_O
    I vote for ditch lights, and OEM Grill.
  26. Mar 27, 2022 at 3:02 PM
    Yes and it's going in the trash as soon as I remove it.
  27. Mar 27, 2022 at 8:10 PM
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    I would cut it into many pieces and ship it back to them. The more pieces, the cheaper the shipping (you'll be able to use a smaller box). Hey, maybe you'll get your money back. :notsure:
  28. Apr 1, 2022 at 7:56 AM
    Borgunit
    Borgunit New Member
    JR
    Ohio
    2013 Black Rock Warrior
    Pic 1 all the way
  29. Apr 1, 2022 at 9:20 AM
    Lol...you're late haha. I took that grill out and went back to stock.
  30. Apr 1, 2022 at 10:03 AM
    Borgunit
    Borgunit New Member
    JR
    Ohio
    It's like that a lot of the time. I don't know if I like it until I see it on my vehicle
