  1. Mar 18, 2022 at 7:18 PM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    12 week wait is over.
  2. Mar 18, 2022 at 7:39 PM
    imcalister
    imcalister New Member
    Scott
    Van Alstyne, TX
    2020 Tundra CM Attitude 5.7L 4x4
    I guess not done…..but ordered!
    Jpd0144, batman900, Yzed608 and 2 others like this.
  3. Mar 18, 2022 at 7:40 PM
    Taco-Spike
    Two Trucks
    Nice loot
  4. Mar 18, 2022 at 7:44 PM
    imcalister
    Scott
    Van Alstyne, TX
    Thanks! Figured WTH. It’s a birthday present! Lol. Can’t stand chrome either. End caps will be next.
    Taco-Spike likes this.
  5. Mar 18, 2022 at 7:45 PM
    Taco-Spike
    Two Trucks
    I tell myself the same thing on my b day. TREAT YO SELF
    RegGex and twotrack like this.
  6. Mar 18, 2022 at 9:52 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    hey do you know if you can rewind live fm radio like you can to an extent in the stock models? I’m looking at that head unit myself. I think new models are around the corner however..
  7. Mar 18, 2022 at 10:02 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    this is the mod I want more than anything I have seen on this site, it should have came first before any of my other mods. Does this void the warranty?? I need to know how to do this
    (I get the concept, but as I saw another commenter ask, is there a harness? Which switch pod..)
  8. Mar 18, 2022 at 10:23 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Spring break activities, new: drilled/slotted rotors, ceramic pads, steel braided brake lines, rims(20/10/-19), tires(35/12.5/20), Dura coated tires, Dura nano coated rims
  9. Mar 18, 2022 at 10:29 PM
    Luna Pandorum
    Luna Pandorum Make footsteps, never follow them.
    2021 LR Tundra Turd Pro CM
    Suspension, 35s and various things to interior
    So I've seen a harness for the rear window but haven't seen anything for the other buttons, when I wired mine I removed the pins from the plug then removed the pins from the wires then solder the new 20 gauge wire to that, ran the new wire the correct distance then put the pins back on the wires and then pins back in the switch. I tried my best finding both male and female version of the plug but didn't have any luck.
  10. Mar 18, 2022 at 11:22 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    The hitch.
    SAGE63[QUOTED] likes this.
  11. Mar 19, 2022 at 2:40 AM
    raspy87
    raspy87 New Member
    Andrew
    RI
    ‘19 DC SR5 Cement
    Just out of curiosity does exterior include head/fog light bulbs as well?
  12. Mar 19, 2022 at 4:36 AM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Southeast toyota dealers are having a sale right now that could save you a bunch of $$. Not sure if its too late to cancel your order. Check out Village Toyota Parts in FL for savings examples. Free shipping as well.
  13. Mar 19, 2022 at 5:36 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Im gonna blame you when my wife catches me painting my engine cover. :rofl:
    WBW, snowman19[QUOTED] and Taco-Spike like this.
  14. Mar 19, 2022 at 6:37 AM
    RobertD
    Robert
    DFW, Texas
  15. Mar 19, 2022 at 7:31 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
  16. Mar 19, 2022 at 7:36 AM
    tundratoofun
    Glendale
    Beast
    Ok that does it!! So I scuff, prime, coat and clear? No prime? No clear? Krylon for plastic?
    BlueRibbon4x4 likes this.
  17. Mar 19, 2022 at 7:53 AM
    RobertD
    Robert
    DFW, Texas
    Get the VHT plastic paint. I used the silver as a base for the blue but sprayed it straight to the engine cover after I thoroughly cleaned. I used rustoleum gloss clear at the end but you definitely want the VHT high heat paint on the plastic since the engine gets hot.
    booya69 and BlueRibbon4x4 like this.
  18. Mar 19, 2022 at 8:16 AM
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    Spring training special delivery:
  19. Mar 19, 2022 at 8:23 AM
    Jayprestonky
    Jayprestonky New Member
    Central Kentucky
    2018 Tundra TRD
    Removed chrome bump and grill surround and installed color matched. Probably one of the easiest mods I have done so far!!
    Helo, mgm16trdpro, pvn.beluga and 6 others like this.
  20. Mar 19, 2022 at 9:14 AM
    Orracle
    Orracle New Member
    Canton, GA
    Took mine to the range.
  21. Mar 19, 2022 at 9:44 AM
    -MRibz-
    -MRibz- New Member
    San Diego
    2020 Crew Max 4x4
    AJT goodies came in. Started with the key, used one of my non OEM keys, unfortunately they are shaped differently, I had to grind down the key to make it fit, its pretty solid but I'm not 100% comfortable with it, I may throw in some epoxy to fill in the gaps and make it a little more solid.
    All pro bed stiffeners, factory bed mat and bed rails
    Meso red 4x4 ring.
    Got the long RAM arms, to my surprise they are metal rather than plastic. The length is perfect.
  22. Mar 19, 2022 at 10:46 AM
    Ron_Pro
    Ron_Pro New Member
    California
    2020 Tundra TRD Pro CrewMax
    Installed the UPTOP Overland AFS Truss bed rack, 2 RotoPax’s, and recovery boards.
  23. Mar 19, 2022 at 11:13 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I just private message someone here that said they were interested in my seat jackers. If I don’t here from him by tomorrow they will be posted for sale. I have said this before and others have said I’m only 5’5 and when I removed the driver side and sat back in the seat I felt much better without them. Everyone is different and feels much different for others.
    mgm16trdpro[QUOTED] and SAGE63 like this.
  24. Mar 19, 2022 at 12:13 PM
    PermaFroxt
    PermaFroxt New Member
    Vito
    20 Platinum
    lil bit
    Went with the Pro mats, I like the rubber texture vs thermo plastic. Plus 5100s center position ready for AT3s 275/65 20 next week. They'll mount on the fresh powder'd Platinum wheels
    marc32, mgm16trdpro, Jpd0144 and 2 others like this.
  25. Mar 19, 2022 at 12:44 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
  26. Mar 19, 2022 at 1:22 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Just kidding
    Wallygator, Patch999, CBrider and 9 others like this.
  27. Mar 19, 2022 at 2:40 PM
    Taco-Spike
    Two Trucks
    :eek:
    DiamondW and jclem65 like this.
  28. Mar 19, 2022 at 2:54 PM
    snowman19
    snowman19 New Member
    Scott
    Cypress, Texas
    2019 White Tundra CM
    Katskin leather seats, painted engine cover, fuse box cover, Rigid 30" light bar in bumper, Method 605 wheels, Bak roll up bedcover, Rhino lined grill surround and bumper caps
    303 Graphene Nano Spray coating is done…happy with results, pretty simple to use. Getting ready to do FRAC mod, paint calipers, 3 switch panel and moving some switches inside…that’s another weekend.
  29. Mar 19, 2022 at 3:15 PM
    Beer Man
    I sell a wide variety of beer lmao, this is what pays the bills tho
  30. Mar 19, 2022 at 3:19 PM
    Taco-Spike
    Two Trucks
    FIFY :cool:
    Beer Man[QUOTED] likes this.
