285x75x18 tire setup
Discussion in 'Wheels & Tires' started by Nubby, Mar 18, 2022.
  1. Mar 18, 2022 at 12:56 PM
    Nubby
    Nubby [OP] New Member
    AZ
    2021 TRD Army Green
    I wanted to share on my current setup since I’ve learned a bunch from others on this site. I’ve been bouncing back and forth on a couple different tire options but finally landed 285x75x18 Toyo AT3’s. My current setup is 6112’s up front, stock in the back (for now). Absolutely no rubbing full wheel lock. Here are a few pics for those interested in this setup. Just got the tires today so will update once I’ve had a chance to play in the rocks/dirt.
  2. Mar 18, 2022 at 12:58 PM
    biebs96
    PA
    Looks great. It’s not as common of a size on this site, but several of us run it, including me.
    How’s the ride? I know my improved when I upsized to these.
  3. Mar 18, 2022 at 3:30 PM
    Nubby
    AZ
    2021 TRD Army Green
    Love em! What is your suspension setup?
  4. Mar 18, 2022 at 4:05 PM
    biebs96
    PA
    Bilstein 5100 on the middle setting, one in rear lift (not necessary, but I liked the rake)
    Nubby[QUOTED][OP] likes this.
  5. Mar 18, 2022 at 4:09 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Looks great. Well done
    Nubby[OP] likes this.
  6. Mar 20, 2022 at 6:54 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    I see you removed the front mud flaps, did you try with them installed?
  7. Mar 20, 2022 at 11:08 PM
    Nubby
    AZ
    2021 TRD Army Green
    Actually took them off when I got the truck so wouldn’t be able to answer that.
    skylinekin[QUOTED] likes this.
  8. Mar 21, 2022 at 5:03 PM
    ObiJuan
    ObiJuan New Member
    Xong
    2021 Army Green Tundra Limited
    Have you tried parking inside your garage? Im trying to do the same set up, but I park in a 7 foot ramp at work and don't know if it will fit.
  9. Mar 21, 2022 at 6:47 PM
    biebs96
    PA
    I can measure the overall height on mine tomorrow
  10. Mar 21, 2022 at 8:23 PM
    Haulmode
    Haulmode New Member
    2021 CM SR5 Cement
    Bilstein 5100, Falken Wildpeak 285/75r18, Demello Rock Crushers, Tech12Volts Sound
    I'm running this size tire, with 5100's at middle setting. Found it works well on the trails so far. After alignment I had to heat and push back the rear part of wheel well plastic, but could be due to extra castor (2.8 degrees). What sold you on the Toyo's?
  11. Mar 21, 2022 at 10:29 PM
    Nubby
    AZ
    2021 TRD Army Green
    This was a big deal for me as well. I actually fit w 1” to spare.
