Transmission fluid
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hambone01, Mar 15, 2022.
  1. Mar 17, 2022 at 12:34 PM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    No it’s not, it’s only at participating southeast dealers and it’s only for about a week.
    pursuit2550[QUOTED] likes this.
  2. Mar 17, 2022 at 12:37 PM
    pursuit2550
    pursuit2550 New Member
    I missed the southeast part and he’s in the west coast. Oops by bad.
    EatSleepTacos[QUOTED] likes this.
  3. Mar 17, 2022 at 1:27 PM
    Rocko9999
    Rocko9999 New Member
    Cat piss for sure.
  4. Mar 17, 2022 at 4:10 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    With free shipping I don't care if it's coming from the moon
  5. Mar 17, 2022 at 5:33 PM
    TTund16
    TTund16 New Member
    Thanks. I don't see myself doing anything else other than drain & fill. drain and fill on all other cars as well and no issues!
    WILLINH likes this.
  6. Mar 17, 2022 at 5:44 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Not directly related but what the heck. I used permatex transmission RTV to reseal the transmission pan on my 2001 Lexus. Within days a drip developed, then drips, then blah blah blah. Went got the Toyota brand, it was successful for 18 years, used it. Zero drips. So no everything isn't the same even if it says it meets the spec. Reason had to reseal the pan was I had to replace a solenoid, filter kit came with a gasket that started leaking after 9 months.
  7. Mar 17, 2022 at 7:04 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Typically leaks after replacing a pan gasket are due to uneven torque on the pan bolts and or over tightening. I owned many Fords and dropped the pan at 30k, changed the filter if a paper one, and refilled. The torque specs were in inch lbs. I believe it was either 120 or 144. Regardless it was pretty light. The cork gaskets were more prone to leaks than the reusable rubber ones.
  8. Mar 17, 2022 at 7:21 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Did they actually ship it to you? I have had dealers refuse to ship ATF and Induction service kits since they are considered HazMat.
  9. Mar 17, 2022 at 7:26 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    I can’t say that I have tried, but that’s surprising to hear. I don’t see anything listed on that webpage so worst case they’ll just cancel the order and refund you, but seems unlikely.
  10. Mar 17, 2022 at 7:33 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    It makes no sense since they will ship engine oil. This isn't the only Toyota dealership that has told me this. Also had it happen with a Subaru dealer.
  11. Mar 17, 2022 at 7:42 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    Surprised no one said AMSOIL
  12. Mar 17, 2022 at 7:54 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    I was going to buy one in the name of science but failed to realize the free shipping is only on orders over $75. Would’ve made that quart of ATF $30 delivered, so for now we’ll continue to wonder.
  13. Mar 17, 2022 at 8:46 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I have bought WS on Amazon and no problem with shipping. I have never bought it locally. I also buy pool chemicals online.
  14. Mar 18, 2022 at 4:12 AM
    pursuit2550
    I was on the wrong dealer page and yes I was getting charged a hazmat may fee. If I recall it had a haz mat symbol. Even my dealer had the fee till I switched to pick up.
  15. Mar 18, 2022 at 7:22 AM
    CTundraForMe
    CTundraForMe New Member
    The dealer I order from won't ship touch up paint either. :/
  16. Mar 18, 2022 at 7:37 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I used an in-lb torque wrench with the gasket, with the shit permetex and with the Toyota sealant. Not a single drip weep or drop with the Toyota sealant. Sometimes OEM do know the most as they are the only ones that have to warrant for 3 years/36K miles. Sometimes it isn't the installer its just a shit product.
  17. Mar 21, 2022 at 9:45 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    I did the same when installing my trans cooler, just got two quarts from Amazon but it was more expensive. I plan to do a a couple drain/fills as PM in the future would like to source it cheaper than Amazon.
    I could live with a reasonable fee, however I have found that dealers flat out refuse to ship it. I'm sure there a some that will, but I have not put in the effort to find one yet.
