2004 use '00-03 or '05-06 Service Manual?
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, Mar 17, 2022.
  1. Mar 17, 2022 at 2:27 PM
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    I can find PDF's of the 2000-2003 and 2005-2006 factory service manuals. Is there a particular factory service manual for 2004 double cabs or should I use one of these two?
  2. Mar 17, 2022 at 2:31 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  3. Mar 17, 2022 at 2:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm not sure if I've ever seen a 2004 specific manual, but your engine is non-vvti, yes?
    If so, and if all else fails, I would opt for the earlier manual as there is more in common with your truck with those year models than later.
    @empty_lord may know for sure
    DarkMint[OP] likes this.
  4. Mar 17, 2022 at 2:35 PM
    DarkMint
    Ben
    Yes, non-VVTi. I was thinking the same. But I don't want to miss out if there's a dedicated 04 manual :D:D
  5. Mar 17, 2022 at 2:35 PM
    DarkMint
    Ben
  6. Mar 17, 2022 at 2:43 PM
    You can get the Haynes manual at the public library or a one day subscription to TIS and spend your day drinking and downloading each few pages of the manual. You can then print it all out or find an app to join it all together.
  7. Mar 17, 2022 at 2:44 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I bought a Haynes for the corolla thinking it would be similar to the FSM. It wasn't in depth like the FSM is. Didn't list torque specs, didn't give trouble shooting advice. A waste of 30 doll hairs.
  8. Mar 17, 2022 at 2:57 PM
    I got Haynes and Chiltons manuals I picked up for under $5, used, on scAmazon. Like @Tundra2 mentions, they're a good baseline, but FSM has more precise details. Sometimes Haynes or Chiltons will have interesting unofficial tricks to work through things which you won't see in the FSM.
    If it were me, knowing the 4.7 went VVTi in '05+, I'd probably aim for the '03 FSM instead of Haynes or Chilton.
    DarkMint[OP] and Tundra2 like this.
  9. Mar 17, 2022 at 3:05 PM
    When the manuals go for $400/set and the first affordable manual is the Haynes when buying the truck new, you generally pick that up. I don't think the TIS thing came out till at least 10 years later.
  10. Mar 17, 2022 at 3:17 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The Haynes is worth the investment.
    To answer your question, I would lean on the early years version since your motor/trans and everything else is indetical to an 03 or very close. If you need electrical schematics for body items (lights and interior stuff, not mechanical stuff) maybe the 05 book would come in handy since the DC was not available in 03.
    Edit- there is one gray area where the 05 book may matter mechanically. The master cylinder and brake booster may be different on an 04. I'm not 100% sure but it may. Everything else should match an 03 mechanically.
  11. Mar 17, 2022 at 4:00 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  12. Mar 17, 2022 at 4:05 PM
    DarkMint
    Ben
    :rocket:
    Tundra2 likes this.
  13. Mar 17, 2022 at 4:14 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Be glad to provide you all the pdf's saved in their respective directories from TIS on a flash drive if interested. If anyone knows how to combine, Please let me know.
  14. Mar 17, 2022 at 4:38 PM
    DarkMint
    Ben
    I'm in PNW Seattle area. Open to meeting up or paying shipping and flashdrive cost!
  15. Mar 17, 2022 at 4:48 PM
    Adobe Acrobat Pro will do that for you. I have it at work though, not home. I think there’s websites that will combine the pages, but I don’t think it can handle that output and you really don’t want to be doing that with copyright material.
    From a quick check online, there are several free Linux tools that will do that as well. PDF chain, PDF Arranger, PDF jumbled and PDF mix tool.
    None that I’ve played around with though.
    BubbaW[QUOTED] likes this.
  16. Mar 17, 2022 at 5:07 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Yeah, that won't happen, I'm in great state of Tennessee....I'll PM you :)
    Yeah, I've used it before for other things and have that as my go to when I decide to devote the time with their 7 day free trial. Been reading up on how to do it but want to be sure once I get started. There's a way to do table of contents and will take a bit for this ole brain to totally grasp how. Unless I can get some whooper snapper to offer !
  17. Mar 17, 2022 at 5:14 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    03 should be pretty much identical
    You’ll just be missing double cab info
  18. Mar 17, 2022 at 5:25 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Yeah, for the most part it is and the additions for DC are the RSES/RSAS(Rear Seat Audio System/Rear Seat Entertainment System), Power Windows and few other things.
  19. Mar 17, 2022 at 5:35 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    LOL - the beers I drink, only about 4 for $25...
    I can't answer on the FSM. But for sure the EWD linked earlier is legit. :thumbsup:
    BubbaW likes this.
  20. Mar 17, 2022 at 5:36 PM
    empty_lord
    05 rollover special
    The EWD is pretty different body side for a DC.
  21. Mar 17, 2022 at 5:40 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Yeah, posted link to EWD earlier, so he's at least got that or did you mean something else ?
  22. Mar 17, 2022 at 5:40 PM
    I thought all the EWD had breakouts for RC/AC and DC, separately?
  23. Mar 17, 2022 at 5:46 PM
    empty_lord
    05 rollover special
    yea. The DC stuff in the ewd is seperate: the main manual stuff is all mixed in. Tis is terrible to navigate these older ones sometimes
    shifty`[QUOTED] likes this.
  24. Mar 17, 2022 at 5:46 PM
    empty_lord
    05 rollover special
    I totally missed that you did. I’m still at work on my phone lol
  25. Mar 17, 2022 at 5:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    you need a (typically) paid PDF editing software. I have one I use through work (Bluebeam).
    the other part about combining them is that you'll likely end up larger in file size than the max single-file upload size here. That's why many of the later EWD's I assembled I had to actually split up to be able to post here.
    des2mtn and shifty` like this.
  26. Mar 18, 2022 at 2:45 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I have an 04, and am equally frustrated by not being able to find a FSM. Mechanically, most everything is the same as an 03. However some systems I've found are like the 05 (Evap system, for example). I also have the Haynes manual. While it tends to be more generic, it does offer some better "how to" information. Their BW pictures are useless for the most part (poor resolution) , and often just plain wrong. YouTube is often helpful. Tundras.com is the best resource!
    As a non-professional (I once was...but a LONG TIME ago) DIY mechanic, I'll spend as much time researching/preparing for a project as it takes to perform the work...sometimes longer. Identifying Toyota PNs is often challenging! I just replaced the center pipe/resonator, and I decided to buy OEM (stainless steel) vs aftermarket (chinesium, as we say) at 2.5X the cost. There's an unusual Toyota style clamp (Toyota 9008046263) that I identified along with the other components. But when it all arrived I discovered that the clamp required a bolt that WAS NOT INCLUDED (this is a very annoying Toyotaism...required parts are ordered separately. Shame on me for not checking). No problem, I'll just head to Ace is the place and get one. But nooo...it was some weird ass size (M7 x 1.25) not to be found. So I ordered it at the dealer $1.76.
    Back on track, my exhaust system is the same for 2002-2004. The evap system is the only thing (so far) that comes up 2004-2006.
  27. Mar 18, 2022 at 3:03 AM
  28. Mar 18, 2022 at 6:18 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Correct, the 03 and 05 pdf's I have are approx 45 and 80 MB in size respectively. They contain the Repair Manual and EWD which is why they have to be found on a Google file share or similar. The combined size of 1461 files for an 04 FSM is 80MB.
  29. Apr 13, 2023 at 1:49 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    poof
    DarkMint[OP], w666, Mustanley and 2 others like this.
  30. Jan 17, 2025 at 5:50 PM
    Brentc1111
    Brentc1111 New Member
    Brent
    Is there anyway you can send me that 2005 repair manual via email folder of pdfs please BubbaW.
    brentc1111@gmail.com
