Suspension Ideas
Discussion in '1st Gen Tundras (2000-2006)' started by Walker-Wheels, Mar 15, 2022.
  1. Mar 15, 2022 at 12:28 PM
    Walker-Wheels
    Walker-Wheels [OP] New Member
    Bryce
    2006 Silver DC Tundra TRD off-road 4x4
    Hey Guys, I just picked up a leer shell yesterday and after driving with the shell on the bed I've come to realize its definitely time to replace the rear leaf's and shocks. I do a bit of towing here and there so I'm thinking of looking towards getting some heavier leaf's any ideas?
  2. Mar 16, 2022 at 6:34 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    check out Deever, Alcan, Dobinsons, OME. Or if you want to keep a lighter spring for better ride, replace with factory leafs and then add RAS to address hauling/towing loads and squat
    bmf4069, Mobeyk and Sunnier like this.
  3. Mar 16, 2022 at 6:40 AM
    Sunnier
    Sunny
    San Diego, CA
    Yep, ^ this covers about every option. If you plan to carry a bunch of gear in the bed under that shell, it’s worth getting your truck weighed before you call Deaver or Alcan, because they could make springs that meet your specific load requirements.
  4. Mar 17, 2022 at 2:41 AM
    Aerindel
    Aerindel New Member
    Montana
    Air bags are another option, cheaper, easier and you can leave things soft when not carrying a load.
    ATV25 likes this.
  5. Mar 17, 2022 at 1:37 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Dannydirtyfingers likes this.
  6. Mar 17, 2022 at 6:21 PM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    I just got min installed the other day. ( only had em 4 months. They definitely ride better than the original springs I had. And 1.5 was spot on for me. I had about 600 lbs I. The bed the other day , and I lost about an inch, and I could still stuff my tires way up in the fender well. Ie decent axle flex ( drove one side in the front on a ramp, and the other side at the rear.). I might actually tear my old springs apart and use the bottom leaf as an add a leaf, and see what that does
  7. Mar 17, 2022 at 6:35 PM
    Sunnier
    Sunny
    San Diego, CA
    Why are you wanting to add a leaf?
  8. Mar 18, 2022 at 2:26 AM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    Possibly to raise the rear some more. I’ve got new front struts and coils on the way, to accommodate my bumper, winch and sliders. We’ll see once i get it all installed and let the dust settle
