Check Fuel Cap Warning After Fuel Tank Swap
Discussion in '2.5 Gen Tundras (2014-2021)' started by SargeBSA, Mar 16, 2022.
  1. Mar 16, 2022 at 6:55 PM
    SargeBSA
    SargeBSA [OP] Prior Taco Connoisseur
    Snohomish County
    2021 SR5 DC 4WD
    Offgrid Engineering Battery Bracket TRD-Offroad Wheels, LT265 75/r18 General Grabber ATX Tires, 38 Gallon Fuel Tank Swap
    Did the 38 gallon tank swap last week everything went smooth truck runs normal, but the blasted check fuel cap warning comes on and stays on every time I crank the truck except when I start the truck after its warmed up. I went back through the system everything is secured correctly I'm confused. Help!
    Obligatory Pic
  2. Mar 16, 2022 at 6:56 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Checked for codes in the ECU?
    Wonder if you have a EVAP leak detected or not.
    Could occur cold vs hot engine due to the self test parameters. Leak could be detected during the self test chiming a warning upon next restart. Self tests are run engine off.
    tundratoofun likes this.
  3. Mar 24, 2022 at 9:07 AM
    SargeBSA
    Snohomish County
    2021 SR5 DC 4WD
    Typical Toyota it self healed, haven't seen the error message in over 400 miles. (knock on wood) I did check for codes but nothing was showing.
    14burrito[QUOTED] likes this.
