First oil change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Purerage1, Mar 16, 2022.
  1. Mar 16, 2022 at 6:44 PM
    Purerage1
    Purerage1 [OP] New Member
    James
    Brookfield CT
    2021 tundra limited
    None
    4100 miles first oil change. 8.5 qts.
  2. Mar 16, 2022 at 6:57 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    8.5 quarts is right in my book. And Rhino ramps really make it easy.
    WILLINH and Purerage1[OP] like this.
  3. Mar 16, 2022 at 7:00 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Maybe I'm just blinded by the chrome, but I only see 8 Qts. ;):)
  4. Mar 16, 2022 at 7:00 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Nice, changed mine at 5000 even and had Toyota service the rest. Good choice in oil, I have 6 gallons of it in my garage. Call it bougie oil if you will, I like taking care of my things. Both our vehicles take 0w-20 so it's easier to buy more at once.
    Purerage1[OP] likes this.
  5. Mar 17, 2022 at 5:58 AM
    Tundra2010&60
    Tundra2010&60 New Member
    Northern Maine
    2021 Tundra LTD/TDR Smoked Mesquite/Black Leather
    Running Boards
    So I just had the dealer do my 10k change at 9k. Early in mileage but the truck just hits a year old this week. Seems like a long time for a change.
    So a few weeks ago I checked my oil cause the engine "smelled" hot or something just seemed off to me. Oil was down a quart. Now ususally I am religious about checking my oil but I can't recall how long its been, (getting old I guess),but the dealer just had it in October for the 5K check up and didn't add oil.
    Should it have burned a quart?
    You guys aren't going for the 10k recommended changes?
    Also dealer notes say they put in 9 quarts.
  6. Mar 17, 2022 at 6:17 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Just starting with easy and that's making sure the truck was level side-to-side when you checked it.
    I do 10K OCI and do it myself. 8.5 quarts hits the top line every time. I just did my 8th oil change. My 5.7 flex has never moved from the top line.
  7. Mar 17, 2022 at 6:34 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    I do 5k oil changes. Never noticed the oil level dropping between oil changes. If your going to let just some oil change kid change your oil, and you going to worry about it. Check it when you first get home from the oil change. Then you would know if your loosing oil or if they undefiled it. Then check the oil every 1k or so.
    And to Purerage how much does that oil. Cost per quart?
  8. Mar 18, 2022 at 4:38 AM
    pursuit2550
    pursuit2550 New Member
    If there is one thing I have learned is, the dealer jiffy lube techs suck. My truck is a lease and did the oil change there twice, because it’s free (yeah right). I have decided to keep it with what’s going on with these ridiculous prices. Anyways I did an oil change 5k after the dealer had done it. Took the oil filter out and it seemed pretty black for only 5k. Did pay any attention to it. Fast forward another 5k and the filter is way cleaner than before. Take it for what it is but I was told sometimes they don’t change filter and use them for personal jobs. I will change my oil and do my maintenance till the day that I can’t no more. And yes I do 5k instead of 10k. My personal opinion is that they switch to 10k for EPA reasons. Just like they switched to 0w-20, for EPA/Cafe standards. I stick to 5w-30 and my engine is quieter and has more oil pressure.
  9. Mar 18, 2022 at 4:45 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
  10. Mar 18, 2022 at 7:55 AM
    68rs75z28
    68rs75z28 New Member
    2020 tundra sr5 dc
    I change mine every 5k or 1 year(covid really reduced my driving); but if it used a quart in 10k miles, I really wouldn't be worried about it if I had been driving it hard.
    I like my mobil 1 0w-20 and a mobil 1 filter since you can get them cheap as a bundle from the parts stores.
  11. Mar 18, 2022 at 8:07 AM
    Deacon Blues
    Deacon Blues New Member
    2018 Tundra TRD Off Road
    Good to see it's not just the Tacoma forum that has this trend.
    I personally like to run three catch cans and change my oil every 100 miles.
  12. Mar 18, 2022 at 10:55 AM
    68rs75z28
    2020 tundra sr5 dc
    Dang, can you post a picture of all that oil that your catch cans catch? I feel like mine aren't doing much because it only has a tea spoon of oil in it.
    Deacon Blues[QUOTED] likes this.
  13. Mar 18, 2022 at 11:00 AM
    Wow. Can't believe you would gamble on not having the 4th catch can. To each their own. That oil probably looks like ink after 100 miles. Should be changed with each start and stop of the engine to reduce the amount of metal shavings present. Can't have oil that's too clean or fresh.
    50Shades, des2mtn, Baja Mike and 4 others like this.
  14. Mar 18, 2022 at 4:08 PM
    Rocko9999
    Rocko9999 New Member
    5K for me. Oil/filter is cheap, engines not so much.
    Baja Mike, sask3m and OHwendTrd like this.
  15. Mar 18, 2022 at 6:21 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    I have a 5k, 10k, 15k, 20k, and 25k maintenance check with Toyota care when I bought my truck. Only problem is they only change the oil every 10k. So I just change the oil when they don't, they do everything else including rotate the tires and inspections. Of course, I check everything over before I leave the lot, after 25k miles it will only see the dealer on larger things I don't have the tools for. Who knows, maybe I just need another tool haha.
    Edit: I'm okay with it because I do prefer the Amsoil brand over what the dealer uses.
  16. Mar 19, 2022 at 7:31 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    yeah i do 5 or 6000. 6 Months seems like a good idea. oil change tire rotation
  17. Mar 21, 2022 at 7:27 PM
    Purerage1
    James
    Brookfield CT
    2021 tundra limited
    None
    Had to get another one. Good eye. 8.5qts
  18. Mar 21, 2022 at 7:28 PM
    Purerage1
    James
    Brookfield CT
    2021 tundra limited
    None
  19. Mar 21, 2022 at 7:29 PM
    Purerage1
    James
    Brookfield CT
    2021 tundra limited
    None
    172.00 for a case of 12 and filter. Ouch.
  20. Mar 21, 2022 at 9:00 PM
    Creed777
    Creed777 New Member
    2021 TRD PRO MGM
    8.5 qts is spot on with a good drain. Great choice for oil, you are very good to that motor. Just did my second one at 1600 miles. First was at around 600 miles. Definitely some shiny stuff in the first one but second was super clean. I don’t drive it much so it’s more about time, but when I do drive it, I get on it. That 5.7 is awesome! I am OCD with maintenance and breaking in motors as well. I wanted the Amsoil because I believe it’s the best of the best especially for extended uses and overall hard to beat.IMHO. Spendy though, I went with Mobil 1. I get the appeal of free oil changes but it’s so easy to DIY and the peace of mind is worth a lot. Unfortunately, such a simple task at dealerships can cause owners a lot of grief. Good on you for DIY! Nice truck!
  21. Mar 22, 2022 at 3:16 AM
    Purerage1
    James
    Brookfield CT
    2021 tundra limited
    None
    Thank you! Yeah I figure the maintenance is going to key in this case I plan on 500k miles and up. Won’t be trading in on a third gen ever lol.. LOVE the five 7!
    OHwendTrd likes this.
  22. Mar 22, 2022 at 3:55 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Nice to see another local CT member on here!
    If you’re doing regular scheduled oil changes, I’m sure there are plentiful of threads here that states where using Valvoline, Mobil1, or even Kirkland brand is more than sufficient for 3-5k interval changes.
    Just my .02!
    :thumbsup:
  23. Mar 22, 2022 at 4:38 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Parts stores around here are not the cheapest option for oil. Since the OP never checked his oil I wonder if it was under filled from the factory.
  24. Mar 22, 2022 at 5:02 AM
    parkerbows
    Jack
    wowI would join on amsoil website. i can get 4 gallon jugs for 168
  25. Mar 22, 2022 at 5:57 AM
    Every vehicle I’ve ever owned for an extended period of time has used off the shelf full synthetic (usually Pennzoil) with a quality oil filter and 10k (or 1 year) oil change intervals. I’ve had one vehicle make 455k miles, 3 over 200k miles and 3 over 150k miles with no engine issues at all. Jeeps, GM’s, Yota’s, BMW’s and even a Ford Mustang. Not one engine failure. None of them smoke or have poor performance. All run like new. Paying $10+ a quart for magic oil is not happening for me. Cool product though.
  26. Mar 22, 2022 at 7:06 AM
    Bammer
    Monroe, CT
    Hey Brookfield !!! I'm in Monroe
  27. Mar 22, 2022 at 11:06 AM
    68rs75z28
    2020 tundra sr5 dc
    Oh interesting, usually I can find a deal of 5qts and a filter for 38 bucks. Then I do a walmart order for the rest.
  28. Mar 23, 2022 at 5:59 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Here is some good info for everyone. Great way to get your Amazon carts pumped up and an angry spouse :notsure:
    $168.05 for a case of 4 w/ the membership - Amsoil site. Thats about $84 / change for oil, still pricy but worth the money, IMO. Normal price is $229.30, pretty good savings if you buy for future changes.
    $7.38 for the OEM filter.
    https://www.amazon.com/gp/product/B007369IDE?ie=UTF8
    $12.99 for the drain plugs gaskets.
    https://www.amazon.com/Genuine-Toyo...436488df3c1&pd_rd_wg=CXBzo&pd_rd_i=B007OW6MD6
    $15.99 for a vibration hour meter if you want to track your hours over miles. I just got 2-sided adhesive and slapped it on the top of my motor.
    https://www.amazon.com/gp/product/B081MY6ZWV?ie=UTF8
    $33.98 OEM metal oil filter cap. IMO, much better than the stock option.
    https://www.amazon.com/Genuine-Toyo...a46f38028ec&pd_rd_wg=ael0m&pd_rd_i=B008BHP68A
  29. Mar 23, 2022 at 6:02 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    bougie kit for bougie miles, haha.
  30. Mar 23, 2022 at 7:25 AM
    5 quarts and an OEM filter are $32 at Walmart.
    Rocko9999 likes this.
