Light bar wiring advice
Discussion in '2.5 Gen Tundras (2014-2021)' started by 18TRDSport82, Mar 16, 2022.
  1. Mar 16, 2022 at 2:36 PM
    18TRDSport82
    18TRDSport82 [OP] New Member
    Justin
    2018 Trd Sport 4x4
    Bfg ko2s Flowmaster exhaust
    Need a little help with wiring my light bar! Thanks in advance! I’m using an Auxbeem 6 gang system and have everything mounted and wired correctly except for the last red wire that needs to be plugged into the fuse box. It says it needs to be plugged into the ACC fuse and I can’t figure out which one that is. I know there are two different boxes one in the engine bay and one by the driver side Kick panel in the cab. If anyone has any advice it would be appreciated thanks!
  2. Mar 16, 2022 at 2:40 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    If the red wires in the cab, go to that fuse box. If the red wires on the main brain in the engine, go to ACC in the e-box there.
    TucsonTundra1794 likes this.
  3. Mar 16, 2022 at 2:46 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    You can also run off the ignition fuse under the hood if needed. It will get power anytime the vehicle is on.
  4. Mar 16, 2022 at 2:55 PM
    18TRDSport82
    Justin
    2018 Trd Sport 4x4
    The red wire comes off the Auxbeam box in the engine bay and it’s only like a foot or two long. I’m just having a hard time finding the exact acc fuse
  5. Mar 16, 2022 at 2:57 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Take the ebox cover off, look at the diagram under the lid, it literally says ACC IRRC
  6. Mar 16, 2022 at 2:59 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Sorry, says IGN.
    Get an add a fuse.
  7. Mar 16, 2022 at 3:02 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    That's the one I use, get a micro fuse add a fuse off Amazon and run it there.
  8. Mar 16, 2022 at 3:03 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    IGN should be fine, that the fuse I used with my SwitchPro. Just use a tap-a-fuse and put a 5 or 7amp fuse on the top. Just make sure you get the right tap a fuse, its the micro one, the smallest ones available.
    18TRDSport82[OP] and 14burrito like this.
  9. Mar 16, 2022 at 3:03 PM
    MadMaxCanon
    jinx
  10. Mar 16, 2022 at 3:05 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Jinx, buy me some coke.
  11. Mar 16, 2022 at 3:06 PM
    MadMaxCanon
    Which kind of coke? :monocle:
  12. Mar 16, 2022 at 3:08 PM
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    The good kind, with real sugar….
  13. Mar 16, 2022 at 3:09 PM
    MadMaxCanon
    Real sugar and not the booger sugar then, got it ;)
  14. Mar 16, 2022 at 4:10 PM
    18TRDSport82
    Justin
    2018 Trd Sport 4x4
    Great thanks everyone!
