Leaking Shock - 2021 TSS
Discussion in 'Suspension' started by sphen, Mar 15, 2022.
  1. Mar 15, 2022 at 11:06 AM
    sphen
    sphen [OP] New Member
    Noticed a little oil on the ground and traces it back to this. Rear passenger side.
    Going to take it to the dealer under warranty, but posting up bc I have a 2” spacer on there, and wondering if the dealer is likely to give me grief over voided warranty. Any experience with such?
    doesn’t seem to me the lift would cause such a leak …?
  2. Mar 15, 2022 at 11:10 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    The lift could cause the leak because the shock is designed to work at a certain working height. I would guess the dealer would say you overextended and caused the damage. 2 inches is alot, even bilstein 5160 are only rated at 1.5" of lift.
  3. Mar 15, 2022 at 11:12 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    They are gonna deny it. You probably over extended the shock and broke something inside. Yes the spacer block will do that
    14burrito likes this.
  4. Mar 15, 2022 at 11:13 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    The shocks are likely over extended. I have a 1 inch lift in the rear and got bilstein 5100's rated for 0-"1". the rear shocks are extremely easy to replace.
    TheBeast and 14burrito like this.
  5. Mar 15, 2022 at 11:24 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Dealer install the block?
    Oey12 and Hbjeff like this.
  6. Mar 15, 2022 at 11:25 AM
    TundraMidwesterner
    Northern Illinois
    I dont have exp with skyjacker for anything other than an old CJ I had a long time ago but it is a cheap option:
    https://www.extremeterrain.com/skyj...r-shock-absorber-for-0-2-inch-lift-b8562.html
    OME would be a better brand:
    https://www.bilsteinlifts.com/shop/...me-rear-sport-shocks-2007-2014-toyota-tundra/
    if you want to go to a reservoir shock the bilstein 5160's would be good or fox or king both make options. some of which can be hard to find right now.
    did you do a carrier bearing spacer for the 2 inch lift in the back? Curious if you have vibration going away from a stop under moderate acceleration.
  7. Mar 15, 2022 at 11:44 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This is a fantastic question. The front a arms are pretty steep too. Something to keep an eye on
  8. Mar 15, 2022 at 11:50 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I ran those skyjackers on my Tundra and they were a cheap and definite upgrade from the stock black shocks.
  9. Mar 15, 2022 at 11:58 AM
    sphen
    No the dealer didn’t do the install
    it’s a readylift 3/2.
    the spacer can be seen in the photo in the OP.
    Sounds like I need to replace those rears, which shouldn’t be too bad. I’ll have a look and see what will work for me.
  10. Mar 15, 2022 at 11:59 AM
    MadMaxCanon
    toytecs rear shocks are good up to 3" I think. you might be able to get away with 5160s.
  11. Mar 15, 2022 at 12:02 PM
    TundraMidwesterner
    Northern Illinois
    I see the two inch block in the rear. I have the 1 inch block. Did the kit come with a carrier bearing drop spacer? I know some people do and some people do not get the vibrations after lifting the back from the driveshaft angles being off.
  12. Mar 15, 2022 at 12:04 PM
    sphen
    I’m not real sure, I had someone else do the install. Lemme look it up.
    might roll with those skyjackers seems to be bang for buck.
  13. Mar 15, 2022 at 12:05 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    To much lift for the stock shocks. Time to upgrade :thumbsup:
    sphen[OP] likes this.
  14. Mar 15, 2022 at 12:05 PM
    sphen
    Haven’t had any vibration or driving issues thus far.
    I did 2” back to leave a little rake for towing. Perhaps I shoulda stuck with 1”?
  15. Mar 15, 2022 at 12:06 PM
    TundraMidwesterner
    Northern Illinois
    i only ask because if i turn off ALL the nannies and stomp on it from a stop i can feel a VERY slight vibration. Although, I may be hyper aware of it after messing with it for so long on the lift I had on my tacoma.
  16. Mar 15, 2022 at 12:08 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Yes, 1 inch you should’ve been ok. Count your lucky stars you got no vibs. Vibrations after lifting are annoying AF
  17. Mar 15, 2022 at 12:09 PM
    sphen
    Should I be concerned about the front now?
  18. Mar 15, 2022 at 12:12 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Do you ever leave the pavement?
  19. Mar 15, 2022 at 12:22 PM
    sphen
    Nah. No heavy off-roading.
    Occasional dirt road/trail just to get somewhere to camp etc
  20. Mar 15, 2022 at 12:25 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    If your taking bumps/dips easy I wouldn’t worry to much. How does your alignment look? That’s what I’d me most concerned about. Tires are expensive
  21. Mar 15, 2022 at 12:27 PM
    sphen
    I had it aligned right after the lift, if that’s what ur asking. I keep an eye on the tread and don’t see any odd wear as of yet.
    Side note - any idea offhand what the torque specs are for the shocks, and the lug nuts?
  22. Mar 15, 2022 at 12:29 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    I don’t but just Google tundras.com torque specs. Someone posted all the specs on here
  23. Mar 15, 2022 at 12:46 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    They might "goodwill", but expect to buy out of pocket. They have zero reason to warranty that.
  24. Mar 15, 2022 at 12:48 PM
    TundraMidwesterner
    Northern Illinois
    I believe the TSS wheels are 98ft lbs. That's what I set mine to 6k miles ago and they haven't fallen off yet.
    Install lower Shock bolts @64 ft lb.
    Install nut on top of shock at @15 ft lb.
  25. Mar 15, 2022 at 12:50 PM
    You don't want the shocks replaced with more incorrect for application shocks. 2” of lift requires a new, and different shock than what’s on there. Easily solved. Buy appropriate shocks to replace. This thread is missing one thing. Pics of the truck!
  26. Mar 18, 2022 at 4:57 PM
    sphen
    So I got the SkySlicer 5000 shocks installed no prob. They didn’t come with any kind of instructions or stacking diagramme, so I’ve had a little trouble keeping the dust boots up. Any clue how they are supposed to attach? See photo.
    Related note - is there a way to remove and transfer the stock dust covers from the original shocks? On mine they seemed fairly well attached.
  27. Mar 18, 2022 at 5:12 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Top of the boot there is a groove, that groove goes around the "washer" welded base of the shock stem.
    Different shock, same idea.
  28. Mar 18, 2022 at 5:24 PM
    TundraMidwesterner
    Northern Illinois
    If the boot won't stay up I'd reach out to the place you bought it and see if you can get another one.
  29. Mar 18, 2022 at 6:31 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    6112s are not a reservoir shock and for the front.
  30. Mar 18, 2022 at 6:34 PM
    TundraMidwesterner
    Northern Illinois
    You are right, they are 5160's I was looking at a whole kit and for some reason the kit was labeled 6112, I will correct my earlier post
