  1. Mar 14, 2022 at 10:07 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    I don’t think the skells who crawl underneath to steal cats would know if they were OEM or aftermarket.
  2. Mar 14, 2022 at 11:07 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    I installed my Valhalla's Shields Front and Rear Cat Theft Deterrent Plates. So glad that I upgraded to the 1/4" thick aluminum plates as they are really beefy and heavy duty. They will certainly serve double duty as skids for the type of wheeling that I do which is mainly beach and trails.
    I also used Rock Hard 4x4 Rock Dome Tapered Bolt Head Protectors for the security bolts on the bottom of the skids.
    https://www.northridge4x4.com/part/...UkFBcAHCvAIXKQY47GKdN0-WspfQntRgaAs5tEALw_wcB
    You can see the heavy gauge of the aluminum on this picture of the front plate taken before installation.
  3. Mar 15, 2022 at 6:07 AM
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    Did a bunch of fluid changes this weekend on my 2016. Both differentials and transfer case using Ravenol (https://tinyurl.com/yckkubxc) and a full transmission fluid flush using OEM spec Aisin WS fluid bought from Rock Auto. Trans flush was a pretty simple process overall, except that I live on a giant hill, so I had to park on the sidewalk for level ground. The fluid that was in there wasn't too bad, but certainly was due for a change.
    I also got a BMC done by a friend of mine. I bought the plates from Camburg and he got them welded on for a whopping $100. He also removed my secondary cats (don't tell the EPA!) before I install my Valhalla cat shield to protect the primary cats. The truck sounds even better now with that Carven TR muffler!
  4. Mar 15, 2022 at 6:12 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    Depending on how badly you want it on there, it would be really easy to epoxy it back on. Just sand down the grille side so it's smooth and it would be pretty darn strong. Me, I would install it as-is since other members have stated it's a non-issue and if it somehow is an issue, pull it off and epoxy it on.
    Retired Blue likes this.
  5. Mar 15, 2022 at 6:21 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You didnt get any CEL when you took the cats off?
    equin likes this.
  6. Mar 15, 2022 at 6:28 AM
    Hugemoose
    Philly
    2016 Tundra Crewmax
    Not enough....
    Nope. These are after the downstream O2 sensors so they have truck knows no different. The primary cats are still intact so the truck is happy. Hopefully the guy who does my inspections is also happy with that....
  7. Mar 15, 2022 at 6:48 AM
    MadMaxCanon
    If you have the valhalla sheilds on they wouldnt even see it though right?
  8. Mar 15, 2022 at 7:14 AM
    Hugemoose
    Philly
    2016 Tundra Crewmax
    Not enough....
    I didn't buy the secondary shield he sells. I certainly could have, but I wanted to cut the cats off anyway. It was cheaper to have them cut off, and had been my plan all along.
    I also bought his shield quite a while ago and just haven't gotten around to installing it. I have been waiting to get the secondary cats removed, and finish my trans fluid flush. Now that that's done, I'll be installing the shield soon. It might just take a little work to bolt up with my P&P front skit plate. That plate is pretty beefy and might pose some issues reaching the front bolts.
    MadMaxCanon[QUOTED] likes this.
  9. Mar 15, 2022 at 7:53 AM
    Kung
    KG, VA
    Got the tire fixed that went flat yesterday.
    I can't complain, though; went to Big O Tires and had them take the spare tire and put it on the main rim, then put the repaired tire on the spare. We'd spent about 20 minutes talking about trucks and Tundras and lifts.
    When I went to pay, I asked them what I owed. Guy slapped the counter and said "Have a great day!" and walked off. :D Excellent customer service.
  10. Mar 15, 2022 at 8:54 AM
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    I put some more Meso Customs products in the truck. I had installed the Ultimate Dome and Map Lights about a month ago and they are an awesome upgrade. Continued on with the Meso Chrome Delete Kit for the cup holder and shifter surround. I also repositioned my Vantrue X4S dashcam GPS mount about an inch higher than I had it before to fine tune the install.
  11. Mar 15, 2022 at 9:12 AM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Started removing badges this morning. Got everything but the 5.7 badges off, gonna wait for a warmer day or the heat gun on those.
    jclem65, GarTX526, GAknight and 10 others like this.
  12. Mar 15, 2022 at 10:36 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    First pic of my 2016 with the suspension changes. Eibach Pro Truck 2.0, set at 2 inch lift in front, RAD HD in rear gave an inch of lift. 275/70-18 tires which I was running stock.
  13. Mar 15, 2022 at 10:56 AM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I'm with the others on this. I broke a clip trying to get the grille off the first time and thought I had really screwed-up. Accessing these clips to push up and release is damn near impossible with the bumper in the way. The engineer that came up with this design needs his ass kicked.
    Ernie68, 18DCTRD and RegGex like this.
  14. Mar 15, 2022 at 12:54 PM
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    "Work Truck" Package doesn't come with the bed rail system? Toyota really confuses me sometimes.
  15. Mar 15, 2022 at 1:46 PM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    B6ABDE97-B067-4D46-9D28-04757122CC3A.jpg E0014060-4996-49E8-B975-ABC217795C7C.jpg 9AD8FEB1-E39B-4C92-95C6-700852622FD9.jpg Not all today, but got the ESP rear under seat storage installed. Wasn’t a bad install at all; really liking the extra storage space and organization.
    Also installed the Desert Does It Seat Jackers and a fire extinguisher. Haven’t rode around to see if I like the seat jackers or not, so time will tell.
  16. Mar 15, 2022 at 4:37 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Tyger Star Armor steps installed! Love these things!
  17. Mar 15, 2022 at 5:05 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    did same. Eibach are so smooth. I went 2.5" front to level the truck. I had 3" rake after installing RAS two months ago.IMG_0867.jpg
    mgm16trdpro likes this.
  18. Mar 15, 2022 at 5:14 PM
    Mobeyk
    Mobeyk New Member
    Didn't wait longer and got the Eibachs installed. Went with 2.5" lift at front, 0 at back and levelled the truck out as I had a 3" rake after installing the RAS a while back. Ill probably tighten the RAS fully as I had them set to approx 60% of max tension. Here the truck with a full Trailer. Should be nice and level once I tighten up the RAS.IMG_0872.jpgIMG_0869.jpgIMG_0865.jpg
    Wallygator, RegGex, GAknight and 3 others like this.
  19. Mar 15, 2022 at 5:22 PM
    Brown747
    Brown747 New Member
    2021 Cement Crew Max LTD
    Picked up a set of TRD Pro BBS wheels.
  20. Mar 15, 2022 at 5:25 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    In my quest for LED replacement of everything, I went the cheap route for the cargo lights. They never get used so it wasn't worth the $50 ones from VLED that don't emit RF noise, interering with the key fob range.
    https://www.vleds.com/vehicle-specific/toyota/tundra/2018/cargo-lights/921-36-w-t-2.html
    This is what I ended up buying.
    https://www.amazon.com/gp/product/B074RFY776?ie=UTF8
  21. Mar 15, 2022 at 5:28 PM
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    I forget cuz I had my 3rd brake light off the 1st week I had it. Is it an easy plug n play with just taking it off? Or do you have to drop the headliner & do all that nonsense?
  22. Mar 15, 2022 at 5:30 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    When just replacing the bulbs it's an easy job. Four phillips head screws to take off the outer lens and that gives access to the three bulbs. Replacing the whole brake light assembly is what necessitates dropping the headliner.
    Beer Man[QUOTED] likes this.
  23. Mar 15, 2022 at 5:31 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    Care package from @sdhq
    0D6FC2DC-3597-4ECB-B16B-2089788346F8.jpg 93FF680F-D94D-454B-9B8C-B481B168A9B0.jpg
    Pangaea, SMTundra, GarTX526 and 8 others like this.
  24. Mar 15, 2022 at 5:32 PM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Guys at the track told me they use dental floss to get badges off. Never tried it but it sounds like it should work to remove the badge itself and then can work on the adhesive that's left on the paint.
  25. Mar 15, 2022 at 5:47 PM
    bfunke
    bfunke Tundra Curmudgeon
    Monofilament fishing line works too
    rocsteady, tundrasportinMA and Mobeyk like this.
  26. Mar 15, 2022 at 6:17 PM
    2Tall
    2Tall New Member
    Chance
    South MS
    I used fishing line to saw the badges off and the 3M eraser wheel to remove the adhesive.
  27. Mar 15, 2022 at 6:30 PM
  28. Mar 15, 2022 at 7:40 PM
    The Towse Tundra 2.0
    The Towse Tundra 2.0 New Member
    Loy
    2021 Lunar Rock Tundra TRD Pro Crewmax
    TRD Inlay Package, Spray-in Bedliner, Cargo LED Light, Power Tailgate Lock, Center Console Safe, MX4 Bakflip Tonneau Cover, CaliRaised LED Rock Sliders, Nitto Ridge Grapplers 275/70/18, Rigid Industries Amber Fog Light Covers, Coachbuilder TRD Pro lift kit
    Finally installed my CaliRaised LED rocksliders. I’m just waiting on my Coachbuilder TRD Pro kit next. Should have it all finished before the Toyota Jamboree out here in Texas by the end of April.
  29. Mar 15, 2022 at 7:40 PM
    Beer Man
    Are you going to make some vinyl overlays to cover the chrome?
  30. Mar 15, 2022 at 7:46 PM
    RobertD
    Robert
    DFW, Texas
    I think its a new grille insert
