Moisture in Blinker Housing
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, Mar 12, 2022.
  1. Mar 12, 2022 at 7:19 AM
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    The light bulb socket my passenger side doesn't have the protective rubber boot. Maybe that caused water to get into my blinker housing. Or I damaged the seal somehow after I pried it off to change out the bulbs. Yes, pried it. I'm not as smart as you guys. But it's not visibly damaged.
    More importantly, how do I get this moisture out?
  2. Mar 12, 2022 at 7:25 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Take it apart and leave it in the sun, or the oven as low as it will go. Maybe a hairdryer would work?
    DarkMint[OP] likes this.
  3. Mar 12, 2022 at 7:27 AM
    DarkMint
    Ben
    Any tips on preventing moisture intrusion without the OEM rubber boot?
  4. Mar 12, 2022 at 7:33 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Hot glue?
    electrical tape and a ziptie?
  5. Mar 12, 2022 at 9:23 AM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    find the silica packets that are tossed in in packaging when goods are shipped or in shoe boxes. Put one in there, it sucks up moisture till you get the new rubber boot.
  6. Mar 12, 2022 at 9:34 AM
    Normal. That’s just the blinker fluid evaporating.
  7. Mar 12, 2022 at 9:42 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    The glue on my motorcycle light came apart @90*, but the tube of gorilla construction adhesive i had (probably over a year old) has held up well since the deer strike in sept (knocked the lens halfway off, but didnt break any of the mounts, and i peeled it off the rest of the way on an hot day). Before i reglued, it was nice to clean out all the amber lens film that had piled up. I polished on the inside housing, but it doesnt look any different than the driver side.
    i erred on the side of too much glue, and really only have squeeze out on the back corner.
  8. Mar 12, 2022 at 10:19 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Had a condensation problem on a headlight on my '06. The real solution is to replace. My solution was to drill a 1/8" hole as close to the bottom as I could (on the back side of the unit, not the lens). It didn't help alleviate condensation more than a smidge, but prevented it collecting in a puddle inside the lens. I'm in North Texas, so YMMV.
  9. Mar 12, 2022 at 2:38 PM
    Mikon
    Mikon New Member
    Michael
    1995 T100 & 2000 & 2006 Tundras
    Headlight LEDs
    Had the same problem on my left front blinker housing a couple of years ago. I drilled four 1/16 inch holes along the bottom front for drainage and air flow. No problems with corrosion, discoloration, or other since. I believe the small holes prevents any substantial penetration of water, even when blasting from a water hose during washing. And the allowed air access keeps it dried out.
    Aerindel likes this.
  10. Mar 14, 2022 at 6:08 PM
    Aerindel
    Aerindel New Member
    Montana
    1/8" drill bit solved that problem for me.
