GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Mar 12, 2022 at 11:45 AM
    #361
    Bradanglin22
    Bradanglin22 New Member
    Brad
    I’m not currently because I haven’t decided if I have an actual “need” for it, but at some point down the road I’ll probably get a fifth to match. I just need to convince myself it’s a need lol
  2. Mar 12, 2022 at 1:08 PM
    #362
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    Retro fitting some oem TRD wheel caps onto my aftermarket wheels.. what do you guys think? Too tacky and stick with the all-black kmc wheel caps? Or does it look alright?
    Used a dremel to cut out the center.. and epoxy to stick the oem caps on.
    iLDE, LakeLife, MTundra87 and 8 others like this.
  3. Mar 12, 2022 at 1:09 PM
    #363
    Summit72
    Summit72 New Member
    Summit
    2018 Tacoma TRD OR LB
    Comes down to personal preference I think it looks good both ways if you want a stealthier look go with the kmc but if you want a bit of pop go with the TRD but doesn’t look tacky by any means looks oem.
  4. Mar 13, 2022 at 7:31 AM
    #364
    tundradelapat
    tundradelapat New Member
    '22 MGM Limited
    Fair enough man! Any chance you've measured the pocket underneath the truck to see if a full size spare in that size would fit? I'm going for a full set of five straight off the bat, i've had a bad (aka learning) experience with my Taco only having four and a donut so now I don't roll those dice anymore hahaha.
    Had a set of four methods on my truck with the OEM donut as a spare, tore a Wildpeak on a mountain road in the middle of the winter while it was snowing and then realized I didn't have the correct lug nuts (method lug nuts didn't have enough threaded length) to properly secure the donut. Had to limp all the way back to town, 20+ miles, with a loose front wheel. Whoops haha.
    bigjuice likes this.
  5. Mar 13, 2022 at 7:35 AM
    #365
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Looks good either way
    ToyoTundra89[QUOTED] likes this.
  6. Mar 13, 2022 at 7:38 AM
    #366
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Revere Overland has accomplished this and stated a full 35 would fit. He's running a Toyo Open Country At3 35x12.5.
    Judging by the photo.. it'll fit, but from the rear you'll barely see your diff since the 35 covers most of it.
    He also mentions no modifications were made to fit.
  7. Mar 13, 2022 at 8:20 AM
    #367
    Bradanglin22
    Brad
    I will measure when I get home but I don’t think it should be an issue! Regardless it’s better to be safe than sorry lol
  8. Mar 13, 2022 at 10:43 AM
    #368
    Westcoast bruce
    Westcoast bruce New Member
    Bruce
    2022 sr5 offroad (white)
    Congrats on the wheels! These are the ones (17x9 though) I've landed on as well but as I don't have my truck yet and have a trade, so I'm trying not to have them in my posession, so I can walk away from the car/dealer if I don't get what I want for the trade.
    What tires are you planning on putting on? Im Looking at Nokian outpost ATs in 285/70/17 in the non E load version. 41lbs.
    Was also thinking about the 18s and putting the stock tire on till I've burned through them.
    Looking forward to seeing what you decide on!
    Best.
    bigjuice and Medic343[QUOTED] like this.
  9. Mar 13, 2022 at 11:09 AM
    #369
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I appreciate it man. I pretty stoked about it, trucks build date is tomorrow so I'm closer than I ever have been. Can't wait.
    Went with 35 ridge grapplers. Not too concerned about weight lol they are listed at 68 pounds a piece.
  10. Mar 13, 2022 at 11:14 AM
    #370
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Thats awesome that a 35 spare fits, now the weight is considerably more than a factory tire, I hope that little braided cable will hold it….
  11. Mar 13, 2022 at 12:16 PM
    #371
    Westcoast bruce
    Bruce
    Right on, that's some meat! Can't wait to see it all mounted up. Those wheels are just so damn sexy. I'm actually still toying with the gunmetal version too so hoping someone posts some pics of those mounted up too.
    That and or anyone posting a +12mm offset with 11.5 wide tire...
    Congrats again!
    B
    Medic343[QUOTED] likes this.
  12. Mar 13, 2022 at 12:43 PM
    #372
    bigjuice
    WA State
    2024 Terra TRD Pro
    You and I landed on the same exact size/wheel (I must admit not until I saw it here so pardon the imitation as I hadn’t seen them anywhere beforehand).
    Haven’t settled on tire size as yet but going bigger more than likely with these Territory M/Ts at 54lbs (315/70/17) which another member turned me on to
    https://m.tirerack.com/tires/tires....Model=Wrangler+Territory+MT&partnum=17SR7WTMT
    https://m.tirerack.com/tires/Spec.j...Model=Wrangler+Territory+MT&partnum=17SR7WTMT
  13. Mar 13, 2022 at 1:13 PM
    #373
    Westcoast bruce
    Bruce
    Goodyears... I was looking at some duratracs but to be honest I really don't know much about wheels beyond what I'm reading as non of my social group drives trucks / plays with bigger tires etc.
    I'm never going to drive the truck outside of service roads and other terrain to get to fiahingspots so hoping a little beef on the wheels give me some added confidence and sweet looks while not getting killed at the pump.
    Was actually looking at BR stadiums to start but the rapids just speak to me.
  14. Mar 13, 2022 at 1:22 PM
    #374
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    Black Rhino had a few different wheels I was looking at but unfortunately my top 2 were discontinued and I couldn't find them anywhere. The rapids were #3 on my list and the only ones I could find so I guess it was meant to be.
  15. Mar 13, 2022 at 1:45 PM
    #375
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    I tried to look but didn’t find a post. What are these and what size? They look amazing!
    Toyota10s likes this.
  16. Mar 13, 2022 at 1:50 PM
    #376
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    20 inch TRD off-road wheels from the limited trim, also sold from the port as the "adventure wheel and tire combo" in my region
  17. Mar 13, 2022 at 1:56 PM
    #377
    ThePolak
    The wheels that come on the limited trim here in Canada unfortunately look nothing like that. Those are really nice.
  18. Mar 13, 2022 at 2:00 PM
    Westcoast bruce
    Bruce
    Curious what models those were?! one of the things I love about the rapids is the 3 dimensionality with the kink in the spoke, but the thinness of the spoke with a contrasting colour like the bronze is still understated / not too in your face. BR imo also has a nice deep /dark bronze and gunmetal for that matter.
    There's a white ram 1500 in/on the BR gallery/website and that nailed it for me.
  19. Mar 13, 2022 at 2:06 PM
    #379
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    The Cinco was my #1 choice. Also looked into the Ark, Hollister, and Raid.
  20. Mar 13, 2022 at 2:17 PM
    #380
    Westcoast bruce
    Bruce
    Nice! Good variety of different looks!
    I'm a fan of the kmc Mesa (black rim gunmetal spoke) and some fuel wheels too but the weight is a turn off. For me... Especially since the rapid ticks all the boxes for me.
    I'm still not 100% sure about the Nokian outpost in terms of looks but I'm guessing that functionally will be aswesome. Found a shot of a fellow that had a set (exact size I want) put on his wife's ram ... They look pretty good... Kind of medium aggressive as far as ATs go. Thet are a new tire for Nokian so no real reviews that I could find yet... Thoughts?
  21. Mar 14, 2022 at 8:33 AM
    #381
    Tundra plat 22
    Tundra plat 22 New Member
    2022 tundra platinum blue print blue
    1.75 lever , 35x 12.5 x17 mitts ridgegrapper Rims motiv mill 17x9 offset black
    2022 platinum !!! 35/12.5 /17 nitto n 17 x 9 0 offset
    Lever 1.75 rough country n readjust air bag to lever out 6B2630ED-B8FE-4697-BB25-9B1E997174F1.jpgFFE69632-35C6-48E1-89EA-639AF378BEA6.jpg
  22. Mar 14, 2022 at 8:43 AM
    #382
    cvkings1977
    cvkings1977 New Member
    Nice looking truck! Any rubbing with that setup?
    Henry1jg, Summit72 and lonedrake like this.
  23. Mar 14, 2022 at 8:50 AM
    #383
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    It won't be an issue. I posted another thread on the forum about this. I bought a matching spare when I upgraded to 295/70/18 Cooper Evo M/T' a couple of weeks ago. It's mounted on the spare OEM steel rim and tucks under the truck just fine without any modification.
    Even though I always carry a small 12v compressor & plug kit, I didn't want to be stuck on the trail (or anywhere for that matter) with a sidewall puncture. An extra $285 for a little bit of insurance seemed reasonable to me.
    ToyoTundra89 likes this.
  24. Mar 14, 2022 at 9:05 AM
    #384
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Very nice!
    Any idea how wide the steel spare wheel is? I'm going for a full size spare as well. I got a puncture on an old E rated tire once while on the trail.. so not gonna chance it. Decided to go for a full 35x12.5 and if the spare is at least 7.5 inches.. going to try and convince discount tire to mount a full 35".. even though required rim width is 8.5-11.
    Thanks
  25. Mar 14, 2022 at 9:43 AM
    #385
    KroppDuster
    Bilstein 5100s
    Aw
    Unfortunately, I don't. I'm guessing it's the same 18x8 as the OE wheels, but I could be wrong. They might have cheaped out and gone with something smaller like an 18x7. I know my 295/70/18 (which is 11.6" w) mounted just fine.
  26. Mar 14, 2022 at 9:47 AM
    #386
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Sounds good, I'll just drop the spare later today to find out. It'll be good practice :)
  27. Mar 14, 2022 at 9:51 AM
    #387
    1794yota
    1794yota New Member
    I'm curious.......will the 2022 tailgate fit a 2015. I like the lettering better.
  28. Mar 14, 2022 at 10:00 AM
    #388
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Pretty certain it won't. It will not line up.. especially around the tail lights. Not to mention ordering just the tail gate would almost seem impossible now.
    [​IMG][​IMG]
  29. Mar 14, 2022 at 10:02 AM
    #389
    KroppDuster
    Bilstein 5100s
    This question might be best in another thread...only so you could get more responses. I'll give it a shot since I happen to be viewing the thread when you posted.
    It might fit. All 22 tailgates have a backup camera. Rear cameras were optional back in 2015 so one of two things might happen:
    1. Either you have a factory backup camera, in which case the harnesses might be different since the new cameras have a higher resolution output. Not sure if a 2022 camera would be compatible with 2015 equipment.
    2. You don't have a factory backup camera or don't care about having it, then you'd probably have to delete the harness to keep it from interfering with the fitment.
    Fitment aside...the 2022 tailgate carries a body line at the top that ties into the top of the taillights. I don't think that would line up on a 2015 and might look pretty strange.
    My 2 cents. On a side note: I was on the fence at first about the updated tailgate lettering. At first, I thought it was too "in your face" but, like the chrome, it has really grown on me. Especially since I installed the OE black letter inserts.
  30. Mar 14, 2022 at 11:25 AM
    #390
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    Well, I got my wheels in. I ordered on Friday and they came in pretty quickly about an hour or so ago. Not sure what I’m gonna do about tires yet. Any ideas if the current Nitto grapplers 265/70/18 I have on now would look okay until I get a bigger size? Undecided if I’m going 285 or 295. I’m waiting on the TRD LIFT suspension so I may be a while before I lift it. DCF56820-37D4-4270-A546-0D6C99B10814.jpg
    Chapp and ToyoTundra89 like this.
