Power Steering Pump Part Number..
Discussion in '2nd Gen Tundras (2007-2013)' started by AstroDude, Mar 13, 2022.
  1. Mar 13, 2022 at 6:37 PM
    AstroDude
    AstroDude [OP] New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    So I got this power steering pump from autozone and I noticed some pretty significant differences upon closer inspection.
    Between part A and B, the part where the elbow goes in is different. Different in diameter and depth.
    Also the green lines makes be believe that, that part should not come off.
    So can yall help me with finding out what the OEM part number is? If yall don't know I'll call Toyota tomorrow and ask.
  2. Mar 13, 2022 at 9:38 PM
    AstroDude
    Eddie
