Ditch lights
Discussion in '2.5 Gen Builds (2014-2021)' started by AppleFarmer, Mar 13, 2022.
  1. Mar 13, 2022 at 7:02 PM
    AppleFarmer
    AppleFarmer [OP] New Member
    21 Tundra Platinum
    Anyone have recommendations for a good ditch light? I need to look down crop rows. Now the days are longer it’s no big deal but I’d like something by winter.
    I was not impressed by the VLED puddles I bought. I had to re wire both of the harnesses. That is not acceptable when I could have gotten something for 1/4 the price of elsewhere.
  2. Mar 13, 2022 at 7:37 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    You doing to use as ditch lights or forward?
    Ditch you can use flood or diffused.
    Forward facing go with spot.
    alb1k and Black Wolf like this.
  3. Mar 13, 2022 at 7:46 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Send a message to @memario1214 and ask.
    This (my) is the best advice you will ever receive.
  4. Mar 13, 2022 at 7:46 PM
    Kanobi13
    Kanobi13 New Member
    I have caliraised and have had no issues
  5. Mar 13, 2022 at 7:56 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    So do you need something pointed out to the sides? Straight ahead?
    What kind of speeds are you going?
  6. Mar 13, 2022 at 7:57 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Diode dynamics has fantastic ditch lights. @memario1214 has a sale on them coming up.
    TRDFerguson likes this.
  7. Mar 13, 2022 at 7:59 PM
    AppleFarmer
    21 Tundra Platinum
    Side facing. I farm and need to look down crop rows to the sides occasionally after dark. The roads are only ~25’ wide sometimes so it’s hard to turn the truck to use headlights.
  8. Mar 13, 2022 at 8:04 PM
    AppleFarmer
    21 Tundra Platinum
    I’m prob rolling <10MPH when I’m using the lights.
    I’m trying to look down rows low this…
    on about ~4500 acres.
    I’d only use them sporadically but in the fall I did wish I had some.
  9. Mar 13, 2022 at 8:07 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Personally I think a diffused would work well.
    Rigid Diffused Pro would be way overkill but they put out some serious light (have personally run them).
  10. Mar 13, 2022 at 8:11 PM
    AZBoatHauler
    So.Arizona
    I’m running these and have been satisfied.
    jhardy1979 likes this.
  11. Mar 13, 2022 at 8:45 PM
    memario1214
    Colton
    Missoula, MT
    Last question. When you are looking down the rows what are you looking for? I only ask because I am trying to determine how much spread you need. Then I’ll give you some options!
  12. Mar 13, 2022 at 8:56 PM
    Sunnier
    Sunny
    San Diego, CA
    I’m a fan of Baja Designs for this. In my experience Caliraised isn’t light enough. I do love their amber “ditch” lights as chase (dust) lights… just the right color to be visible through heavy dust, whereas BD are too yellow. But as you are looking for light output to see a fair distance, of these 2, I would go BD > Caliraised.
    BlueRibbon4x4 likes this.
  13. Mar 13, 2022 at 9:14 PM
    AppleFarmer
    21 Tundra Platinum
    Generally I’m looking for deer ;)
    and also, to see if the row has fallen over or is leaning. Big things. The rows are 1000’ long. Im not looking to see more than 50 ft.
  14. Mar 13, 2022 at 9:19 PM
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    I installed Baja Designs Squadron Pro for ditch lights on my rig a few hours ago and just got back from my night drive through the country. Outstanding light output. With those and the Tundra LED brights you could almost forget you’re driving at night.
  15. Mar 13, 2022 at 9:21 PM
    Sunnier
    Sunny
    San Diego, CA
    Curious: if the rows are 1,000’ long, why even check the 50’ nearest the road if you don’t mind about the rest-? :monocle:
    Edit: hunting from your truck?
    Hbjeff likes this.
  16. Mar 13, 2022 at 9:26 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I use sdhq brackets because they are low profile and stick out enough so my lights don't shine off the hook and fender, and they are the only ones I've seen with a vibration dampening rubber support.
    I use the baja designs squadron sport with wide cornering lights at 45 degrees. Get the clear lense, they have amber covers for cheap that I keep in the truck.
    It's an amazing setup and I can't imagine anything better.
    NWPirate likes this.
  17. Mar 13, 2022 at 9:29 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
  18. Mar 13, 2022 at 9:33 PM
    memario1214
    Colton
    Missoula, MT
    Sounds good! So for your use case I would probably recommend a combo pattern Baja Designs Squadron or S2 in a combo pattern. Power level and light selection come down to your budget and desired aesthetic. You’ll get some distance and all kinds of width.
    The other option in the same pocket of performance as others have alluded to are the Diode Dynamics SS3 or SSC2. Very similar in looks and we actually have a sale upcoming beginning tomorrow. They’ll come in at a little cheaper with very similar performance characteristics. We personally run mostly DD now on our rigs.
    The differences: Color temp and pattern.
    White Diode Dynamics come in at a cool 6000k color temp whereas the Baja Designs lights are a little warmer at 5000k.
    As for the pattern if you get combo in the Diode Dynamics you will get a punchier driving portion of the pattern allowing you to see further down the rows, but you’ll find a bit of a “dead spot” between the flood portion and the driving portion of the pattern. With all of Baja Designs’ equipment using an open-reflector design you won’t get as much distance, but you will have a smoother transition between patterns.
    We carry all of what I referenced and would be happy to help in that regard as well :thumbsup:
    joseph_womack and Ghost Rider like this.
  19. Mar 13, 2022 at 9:51 PM
    AppleFarmer
    21 Tundra Platinum
    Wow? Thanks!
    Where do I find your website?
    I can’t remember the light temp I have on my LEDs now so I’ll need to look that up. I’m guessing 5000.
    6000 looks more blue, correct?
    I mean, it doesn’t really matter as I’m working but also why not look good doing it
  20. Mar 13, 2022 at 9:53 PM
    AppleFarmer
    21 Tundra Platinum
    That’s an incredible difference. I didn’t think I needed that but now I think I need that!
  21. Mar 13, 2022 at 9:54 PM
    memario1214
    Colton
    Missoula, MT
    I’m known for getting a little wordy :rofl:
    Our website is www.hotshotoffroad.com :thumbsup:
    Are you trying to match the color temp of your OEM LED headlights? They’re closer to the 6000k color output.
  22. Mar 13, 2022 at 10:13 PM
    AppleFarmer
    21 Tundra Platinum
    I can see the sway from the road when a trellis is needing support at 50-100’ and I drive both sides anyway. When a row of trees falls over it’s pretty obvious (and expensive, tens of thousands of dollars. There’s not much you can do about a fallen trellis once the row is down. I’m mostly interested in watching for sway when the crop load is heavy. We will try to get in at daylight and put in more poles, our lighten the crop if we can to take weight off the system. The wind blows in the evening and mid-October is pretty risky. For example, if something looks like it’s seating I might send some crews in to reinforce it I might just harvest it to get the weight off, then reinforce. When you have everything tied together in giant hedges with wire, if one section fails, it can take down a lot of trees.
    Unfortunately we can’t hunt on commercial farming property unless we have tags. It’s one of those situations where it’s not very sporty anyway. The deer take refuge in the trees so you’d be wrapped up by 7AM on the first day. We’re looking at some special control tags this year because of the amount of deer right now which would let us get the doe out too.
    There are a few bucks that are enormous - 12, maybe 14 point. At least two different huge bucks. Mostly it’s just groups of doe and babies, 10-12, maybe as many as 20-ish at a time.
    Ghost Rider and joseph_womack like this.
  23. Mar 13, 2022 at 10:17 PM
    AppleFarmer
    21 Tundra Platinum
    It was a beautiful morning last week when I took this. This property is ~1400 acres over 7 miles end to end.
  24. Mar 14, 2022 at 7:22 AM
    Sunnier
    Sunny
    San Diego, CA
    I love that you gave a detailed answer; I can almost picture it! I’d appreciate a pic in the daytime of any section, from outside the outside-most stand of trees, if it’s ever easy to post one, because now I’m picturing espaliered trees, but I’ve never seen this for a large growing application.
    Thank you!
    I love, about this forum, that I regularly learn about all sorts, not just truck stuff.
  25. Mar 14, 2022 at 7:58 AM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    You should write novels, I mean, just reading that gives me images in my head of what that "looks" like.....
    I know maybe no visitors, but man, that's one hell of a place that I would love to see
  26. Mar 14, 2022 at 12:51 PM
    AppleFarmer
    21 Tundra Platinum
    Boy our farm manager wishes it could be a clean espaliered system but we just can’t afford it. And if we could, we probably couldn’t find the laborers to do it.
    Despite the rising cost of production the produce isn’t bringing in more revenue. And where prices are going up, the retailers are taking that margin.
    There’s no foliage right now but here’s some from last year. There are ~2200 acres like this of apples.
    These are 4th leaf (2 yrs in the ground so -3 from full wall coverage, so baby baby trees).
    And these are a little older:
    Sunnier[QUOTED] and Ghost Rider like this.
  27. Mar 14, 2022 at 12:55 PM
    Sunnier
    Sunny
    San Diego, CA
    Thank you for this! Today, this is my favorite thread on this forum. Great intro thread, even if you didn’t mean it that way; I think others are digging it too!
  28. Mar 14, 2022 at 1:11 PM
    Ghost Rider
    Ian
    Cypress, Texas
    Now I want an apple, or ten, or a hundred.....lol
