  1. Mar 12, 2022 at 6:56 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Nice setup. Don’t google klick wrench unless you’ve got a few bucks burning a hole in your wallet.
    TampaRD Pro[QUOTED] likes this.
  2. Mar 12, 2022 at 6:59 AM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    Ok. That’s genius. I might have to order one of those.
    TampaRD Pro likes this.
  3. Mar 12, 2022 at 7:05 AM
    nmjameswilson
    nmjameswilson New Member
    James
    Kansas City
    2021 Limited Nightshade Double Cab
    I have issues with bed bounce in some instances on my 2021. Is the sway bar a fix for that? Thanks
  4. Mar 12, 2022 at 7:08 AM
    nmjameswilson
    James
    Kansas City
    I have had my 2021 Limited DC Nightshade 10 months and just went over 25,000. I storm chase in the spring all over so I fear I will at least double that in the next year.
    SAGE63, RobertD, TrashcanBand and 4 others like this.
  5. Mar 12, 2022 at 7:10 AM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    17 months and 24.6k miles here. There are a few of us on here racking up the miles on ‘21s.
    SAGE63 and nmjameswilson[QUOTED] like this.
  6. Mar 12, 2022 at 7:15 AM
    TFTundra
    TFTundra New Member
    Yep, my battery crapped out at exactly two years too. Went ahead and got the free replacement from Toyota. Your upgrade is probably a better idea, though..
  7. Mar 12, 2022 at 7:31 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I hear bed bounce is worse on the DC vs crew. RSW is a huge improvement in cornering so you don't feel like you are rolling out of the seat. I am not sure if it would help with bed bounce. Do believe firmer shocks help with that. If you have the black shocks, those are pretty soft and may be related. These may help
    https://www.tundras.com/threads/so-...-bed-bounce-embarrassing-highway-ride.100699/
    https://www.tundras.com/threads/bed-bounce-fix.21924/
    nmjameswilson[QUOTED] likes this.
  8. Mar 12, 2022 at 7:34 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Not throwing shade on the idea at all - - I'm a tool hoarder, and not at all in recovery...
    Would it not be better to spend the extra $10 and have a torque wrench with the same or better quality, that you could use for other applications as well?
    Kobalt 1/4-in Drive Click Torque Wrench in the Torque Wrenches department at Lowes.com
    Or you could go USA made and buy-once-cry-once:
    3/8-Inch Torque Wrench Square Drive 14-Inch Length - 57000 | Klein Tools - For Professionals since 1857
    ...and you'd still need to spend $25 on the filter wrench, if you don't already have one:
    Amazon.com: Motivx Tools Oil Filter Wrench for Toyota Camry, Tundra, Tacoma, 4Runner, RAV4 and More - 64mm 14 Flute Precision CNC Machined Aluminum Oil Filter Removal Tool : Automotive
    Filter housing torque: 25Nm (18.5 lb ft) - the application for which KlickWrench will work
    Filter plug torque: 12.5Nm (9.2 lb ft) - KlickWrench will not work for this, and you'll be doing it at the same time
    However; admittedly, you'll still need another torque wrench for the drain plug: Drain plug torque: 40.67Nm (30 lb ft); but then you'll have that for when you re-torque your RSB, change diff fluid, or some other fun project.
    Kobalt 3/8-in Drive Click Torque Wrench (20-ft lb to 100-ft lb) in the Torque Wrenches department at Lowes.com
    Or, you know...
    1/2-Inch Torque Wrench Ratchet Square Drive - 57010 | Klein Tools - For Professionals since 1857
    ...and now that I've suggested you spend more than 10x the cost of KlickWrench, you see how serious my problem is.:)
    Hcreager, raspy87, Enjoihavok and 2 others like this.
  9. Mar 12, 2022 at 7:41 AM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Nice… I hadn’t seen those before. I think I’ll be ok with the Motivx for now as it worked extremely well and not to worried about over tightening with the aluminum oil filter cap. Used my Craftsman torque wrench on both the Motivx and oil drain plug no problem.
    Tundrastruck91 likes this.
  10. Mar 12, 2022 at 7:55 AM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    So went to Houston for a wedding, got my cats stolen, and spent over half a day getting that resolved….
    1794TX likes this.
  11. Mar 12, 2022 at 7:57 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    That sucks. Sorry to hear it. Getting a full skid to solve future attempts?
  12. Mar 12, 2022 at 7:57 AM
    1794TX
    Steven
    N.TX
    '20 1794
    AggiePhil likes this.
  13. Mar 12, 2022 at 8:29 AM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    So you were able to get new cats that day?
  14. Mar 12, 2022 at 8:56 AM
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    Nice! Ok yeah I’m sold
  15. Mar 12, 2022 at 8:59 AM
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    i wrapped it with matte black, but I did it with some eBay brand vinyl I had from before, looked good when I first did it but now the corners are starting to shrink/rip. Ordered some 3m vinyl
    YotaTruckLtd[QUOTED] likes this.
  16. Mar 12, 2022 at 9:22 AM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    High mileage brotherhood.
  17. Mar 12, 2022 at 10:41 AM
    wiltech
    wiltech New Member
    Tony
    Lafayette, IN
    2018 Inferno Limited
  18. Mar 12, 2022 at 10:56 AM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    used double sided Gorilla tape and just taped the complete holder on cause I might cut the metal holder much smaller to hide behind the camera once temperatures are less annoying.
    wiltech[QUOTED] likes this.
  19. Mar 12, 2022 at 11:43 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    In the process of finishing up installing my Molle front panel from Victory 4x4.
    I have a bed rug in the truck, so having to perform minor surgery on the rug to make it fit. But so far so good and can’t even tell I had to cut the rug a bit!
  20. Mar 12, 2022 at 11:58 AM
    Dantdodge
    Dantdodge New Member
    Danny
    Tampa
    2018 tundra sr5 crewmax trd 4x4
    Stock trd off road
    20220312_144837.jpg 20220312_144812.jpg 20220312_144837.jpgnew shoes! Today was worried about the look but turned out good I think.
  21. Mar 12, 2022 at 12:22 PM
    Did you have to use longer screws to put the rail system back on or did you cut around it?
  22. Mar 12, 2022 at 12:27 PM
    RustyShackle323
    Stewart
    NC
    Nope, I used the factory bolts. Just folded the top of bed rug down so it fit flush up against bed rail as shown in the picture. I made a small cut at each end of the rail so the rug would sit back flat again. (Shown in the last picture from my post above). I used the Velcro that was originally in place at the top of the rug as additional support with it folded over. Had to use some 3M Adhesive spray for those.
    Here are comparison pictures showing across the bed working my way over.
  23. Mar 12, 2022 at 12:28 PM
    :thumbsup:
  24. Mar 12, 2022 at 12:58 PM
    PapaSmurf20
    PapaSmurf20 New Member
    Alex
    2020 Cavalry Blue TRD Sport
    Fox 2.5 remote reservoir DSC Icon tubular UCA Morimoto gen 2 amber DRL headlights ESP long box under seat storage Meso Customs Cabin/Dome lights HRS tail lights
    AE28F0B4-0257-4033-8D4A-88C2ED6808D2.jpg 95E2CF01-90A4-4A17-9B0E-87187F7C6FCF.jpg
    Had the HIREV tails sitting in the box for a while finally had the time to put them on. Got them because I wanted a sequential turn signal to match the morimotos.
    Cl8NL, GarTX526, WawaLunar and 12 others like this.
  25. Mar 12, 2022 at 1:17 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    I don’t like any aftermarket taillights….until now. Those look fantastic! I had to look them up. Which model are those?
  26. Mar 12, 2022 at 1:38 PM
    PapaSmurf20
    Alex
    JAMES and FISHN43[QUOTED] like this.
  27. Mar 12, 2022 at 2:06 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Those look great. Where did you buy from?
    Looks like you have a proper garage!
  28. Mar 12, 2022 at 2:17 PM
    Ó Brádaigh
    Ó Brádaigh New Member
    S. Polychronopolous
    21MGT
    Patiently waiting...
    13 months, 27k.
  29. Mar 12, 2022 at 2:40 PM
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    I was the same way, and I couldn't be happier with mine. They look so good.
    [​IMG] [​IMG]
  30. Mar 12, 2022 at 3:11 PM
    TrashcanBand
    CenTex
    Tundra
    Application approved. Carry on.
