Gauge says low oil pressure
Discussion in '2.5 Gen Tundras (2014-2021)' started by Big_Ed, Feb 17, 2022.
  1. Feb 17, 2022 at 4:58 PM
    Big_Ed
    Big_Ed [OP] New Member
    Spring, Tx
    2016 Tundra
    2016 5.7 flex Crewcab, 104K miles.
    The oil pressure is normally just a bit below the center of the gauge. Today I am driving and see that it's almost at the very bottom. When I shut off the engine, it drops a bit more. When I restart the motor it comes up a bit but only to a level that is way too low, just barely above nothing. Engine sounds and drives normally.
    Checked the oil level it's fine. No dash lights are on when driving. (check engine, oil light, etc)
    I assume it's an electrical issue. But need advice on how to diagnose that.
    Is this an issue that any of you have experience with?
    Thanks.
  2. Feb 17, 2022 at 5:30 PM
    Rocko9999
    Rocko9999 New Member
    It could be oil pressure sending unit, bad oil pump, etc. I would swap out sending unit-not too expensive.
    MT Madman likes this.
  3. Feb 19, 2022 at 5:08 PM
    Big_Ed
    Spring, Tx
    2016 Tundra
    Well, new sensor reads the same thing. I could not find a manual pressure gauge that would fit.
    I would think that if I really had no oil pressure that the engine would be clacking like crazy. Anyone with an opinion on that?
    There are no warning lights or messages at all on the dash. If the computer saw no oil pressure, wouldn't there be some sort of alarm going off?
  4. Feb 22, 2022 at 11:21 AM
    Rocko9999
    You need to hook up manual gauge to confirm pressure is low.
  5. Mar 5, 2022 at 7:08 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    First thing I would check is the oil filter, make sure it still has the metal tube inside it and isn't collapsed. Easy and rules out a failure point seen here before.
    An engine may not clatter right away when low on pressure. I was riding in my friend's Avalon when he ran it just about out of oil. The light kept popping on and off until we got it off the road and it still sounded as smooth as ever. Thankfully the motor survived that one without issue.
  6. Mar 5, 2022 at 7:27 PM
    Big_Ed
    Spring, Tx
    2016 Tundra
    Checked the oil filter, all OK there.
    The truck has been driving fine this whole time, so I am confident that the truck has oil pressure. Both old and new sending units are working and they do show oil pressure when the truck is running (I checked resistance with a multimeter while on the truck with the engine off and running.)
    Still no codes of any kind, not sure there would be any though. The wiring diagram shows the sensor going to the instrument cluster directly and even running the engine with the sensor unplugged doesn't cause any codes. Surely it takes a reading somewhere for oil pressure, maybe in the variable valve timing circuit (?).
    I got a month subscription to alldata. I need to test the resistance in the circuit from the sender to the back of the cluster. If that's OK then I guess I need to repair or get a new instrument cluster.
  7. Mar 5, 2022 at 8:43 PM
    Txexplorer23
    Txexplorer23 New Member
    2020 Tundra Crewmax Platinum 4x4
    Have tried a obd reader that you can read the oil pressure on?
  8. Mar 6, 2022 at 5:08 AM
    timsp8
    NY
    Does the gauge move up when you floor it? Maybe the needle is stuck or can’t go higher. Mine moves a little when I give it gas then drops back down.
  9. Mar 10, 2022 at 7:07 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    What were the resistance values of the sensor when the engine was off vs when it was running and should show normal oil pressure?
    The cluster should just read the resistance value from the sender, factor in the RPM signal and this powers the gauge.
    On other thought its to unhook the battery or unplug the cluster from the harness to let all the power drain out and reset it. Maybe the programming in your cluster glitched out. Worth trying I would think.
  10. Mar 10, 2022 at 10:05 PM
    Big_Ed
    Spring, Tx
    2016 Tundra
    The resistance on the sender with the truck running was 35.2 ohms, I think. Regardless, if I actually had no oil pressure I am pretty sure the engine would have seized up by now. I will check the circuit between the sender and the cluster to make sure it's not an open circuit and that it's not grounded along the way. If that is all good, then I probably need a new cluster. Maybe I can send mine off to a repair place, if there is such a thing for Toyota clusters.
    The gauge does not move at all with engine RPM. I have not tried an OBD reader to see if i can find an oil pressure number.
    Jeff_5_7 likes this.
  11. Mar 11, 2022 at 8:56 AM
    Rocko9999
    Manual gauge. Stop relying on the electric. And you can have insanely low oil pressure and still have the engine run.
    hagrid likes this.
  12. Mar 11, 2022 at 9:13 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Spraynard agrees. Pressure is analogous to volume although it is an assumption. Low pressure can result in the components furthest from the pump starving. Personally, if I had to guess, i would say that the piston rings would be the most starved since they rely on a spray; not a splash.
    Rocko9999[QUOTED] likes this.
  13. Mar 21, 2022 at 7:52 AM
    Big_Ed
    Spring, Tx
    2016 Tundra
    Mystery solved. Mouse chewed a wire.
    Baconbuild likes this.
  14. Aug 30, 2023 at 5:03 PM
    Baconbuild
    Baconbuild New Member
    Brett
    Tundra
    I think I have the same problem. Big Ed, where did you find the chewed wire?
  15. Aug 31, 2023 at 5:22 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Also have that question. Manual gauge check is always the best if possible.
  16. Aug 31, 2023 at 7:47 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    @Big_Ed
