Power steps
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pepe, Mar 9, 2022.
  1. Mar 9, 2022 at 11:24 PM
    Pepe
    Pepe [OP] New Member
    Jose
    2016 Sunset Mica
    I wonder if anyone has adapted a set of Amp Research power steps for a Tacoma or 4Runner, to fit a 2.5 gen Tundra CM?
  2. Mar 9, 2022 at 11:41 PM
    RobertD
    Robert
    DFW, Texas
    Is there a reason you aren't buying the ones that fit the Tundra?
    GODZILLA likes this.
  3. Mar 10, 2022 at 12:48 AM
    18" TRD Off Road Wheels
    Highly doubt it. They probably just buy the ones that are made for a Tundra. :der:
    Seafury and RobertD like this.
  4. Mar 10, 2022 at 5:15 AM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    He probably has a set from the tacoma/4runner hence the ask to save money.
    No idea if its possible or what the size difference is.
    If you do have the tacoma/4runner ones just sell them and buy the correct Tundra ones.
    I sorta regret going with the OBDII PNP version over the hard wire because now my IBDII port is always blocked if I want to use it for other things or add other things there.
    I was just being lazy and did not want to deal with wiring it up myself.
    Still never fixed the drivers door step LED light, it worked off and on for a week after install and has not come back on sense.
    Only issue I have had in 2 years.
  5. Mar 10, 2022 at 5:17 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I would think the motors are the same size and the only thing needed is mounting hardware
    Saltyhero13 likes this.
