GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Mar 9, 2022 at 3:04 PM
    #301
    Breathing Borla
    Northern Illinois
    I like those, those are +35 so should be flush. I would go with a smaller tire than that but I dont think you'll have a bubble at all with 8.5 wide
    what is the bolt pattern we need now?
    I ahve KMC now and they have been great wheels.
    Does anyone know what the total stock weight of the platinum truck wheel and tire set is with the 20"?
    TJD1776[QUOTED] likes this.
  2. Mar 9, 2022 at 3:04 PM
    #302
    Breathing Borla
    Northern Illinois
    no
  3. Mar 9, 2022 at 3:13 PM
    #303
    TJD1776
    TJD1776 New Member
    I jumped around between 295/70, 285/75 and 275/70 - looking to fill the wheel well with a 2" level, and thought the 275/70 would look just a tad small. Then again...the 295's may look big in person to me. Time will tell.
    Bolt pattern and bore are the exact specs of those KMC's -
    so 6/5.5(139.7); Bore is 106.10
    Good to know about your current KMC's.
    Have not seen stock weight for the platinum's, I'll keep an eye out.
  4. Mar 9, 2022 at 3:17 PM
    #304
    Breathing Borla
    Northern Illinois
    I think the guys that have 285 look the best, the 295 look like they are stuffed in there, thats totally just my subjective BS.
    I know everyone says level, level , level, but FWIW, I tested a platinum with AVS and it was totally level stock.
    so depending what you get, you may just want to take a look before you order a bunch of leveling stuff.
  5. Mar 9, 2022 at 3:20 PM
    #305
    TJD1776
    TJD1776 New Member
    Not a bad idea. I will have wheels and tires on prior to leveling so I'll give it a go...
  6. Mar 9, 2022 at 3:24 PM
    #306
    Breathing Borla
    Northern Illinois
    ya , don't want a pre-runner bro look I dont think (nose in the air).
  7. Mar 9, 2022 at 4:20 PM
    #307
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Anything with the AVS should be level stock. The AVS is designed to adjust for towing. The only reason non-AVS trucks have a rake is so the truck sits level under a load and doesn't squat while towing. Definitely no need for a leveling kit with AVS. If you have an AVS and want to go bigger tires...you'll need a 3/1 lift kit.
  8. Mar 9, 2022 at 4:27 PM
    #308
    Breathing Borla
    Northern Illinois
    cool, not looking for huge tires, maybe 33”s ish , that will fit just fine i think
    inhave to say I was pretty impressed with the avs during the test drive , dialing in the different rides was pretty sweet
  9. Mar 9, 2022 at 4:29 PM
    #309
    KroppDuster
    Bilstein 5100s
    Yeah. You'll have zero issues fitting 33's at stock (with or without AVS). Good to go!
  10. Mar 9, 2022 at 4:33 PM
    #310
    Breathing Borla
    Northern Illinois
    cool just want a touch bigger than stock and also more sidewall, I will also be color matching the flares so that will help offset the tire size look
    maybe 285/70/18. Which is 33.7 so about 1” ish bigger than stock. I can’t imagine that would be a problem
  11. Mar 10, 2022 at 12:26 PM
    #311
    Benji31
    Benji31 New Member
    Ontario, Canada
    2023 TRD off road
    Weight vs width, which effects fuel mileage more ?
  12. Mar 10, 2022 at 12:35 PM
    #312
    boyders
    boyders New Member
    edit: I take it back. No idea now.
  13. Mar 10, 2022 at 2:24 PM
    #313
    KroppDuster
    Bilstein 5100s
    Caution: Science nerd incoming...
    I think most schools of thought go in this order:
    1. Width - Increases rolling resistance the most by increasing the contact patch with the road thus increases friction. Forces the engine to work harder and hold RPMs longer while accelerating and reduces "coasting" time to maintain the same speed.
    2. Diameter - Increases the vehicle height, thus increases drag (reduces the aerodynamic efficiency of the OE design).
    3. Weight - Definitely has an impact to fuel economy, but not as much as the first two items.
    The reasoning why weight is the lowest on the "impact scale" is like this: Think of your stock setup that gets (let's say) 19 mpg on the highway. If you added 100lbs of weight in the bed, do you think your fuel economy would drop 3-4 mpgs? It might drop some but not that much. From a scientific POV, width is the primary contributor to rolling resistance because it causes greater frictional resistance by putting more "surface area" on the road. Go back in time and think of your days as a boy scout making cars for the pine car derby. Skinny tires = faster car.
    Also...I think I saw a test on YT once (or maybe it was Mythbusters) where they tested a tire that weighed the same, but was just wider vs a tire of the same size that just weighed more. The wider tire impacted fuel economy more than the heavier tire.
    Westcoast bruce, Sean492 and TJD1776 like this.
  14. Mar 10, 2022 at 3:08 PM
    #314
    theripper
    theripper New Member
    Oregon
    2022 MGM Tundra Platinum
    How big do you think you can go before you need to lift an AVS truck? I have AVS Platinum coming next week and I have 295/70R18 with the same wheels that you have ($99 each was too good to pass up).
  15. Mar 10, 2022 at 3:15 PM
    #315
    KroppDuster
    Bilstein 5100s
    With an 18mm offset, probably 35x12.50 or bigger. You should be fine at 295/70/18.
    theripper[QUOTED] likes this.
  16. Mar 10, 2022 at 3:17 PM
    #316
    theripper
    Oregon
    Phew! Thanks for the info man, your truck looks fantastic. :headbang:
    KroppDuster[QUOTED] likes this.
  17. Mar 10, 2022 at 3:19 PM
    #317
    KroppDuster
    Bilstein 5100s
    Thanks man!
    I should amend my statement to also include 285/75/18 along with 35x12.50. I think 285/75 would be a little too much on the stock setup. That's basically a 35x11.5 tire.
    TJD1776 and theripper[QUOTED] like this.
  18. Mar 10, 2022 at 4:02 PM
    #318
    badmeat
    badmeat New Member
    Cincy, OH
    2022 Limited
    Looks good. I'm considering doing 275/60/20 or 275/65/20 when my limited comes in. I'm eyeballing some 20x9 +20 offset wheels and am planning to stay stock height. I'll be towing ~7500 lbs with our boat and trailer so I'm not wanting to make the truck tow a lot worse.
    Have you checked the speedometer via GPS on your phone to see if the larger tires made it match up with real time speed? When I put larger tires on my 2019 the speedo was actually correct instead of reading higher.
  19. Mar 10, 2022 at 4:24 PM
    #319
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    Has anyone put the Matte black Method 316? I’m interested on how it would look on the midnight black.
    Toyota10s likes this.
  20. Mar 10, 2022 at 4:50 PM
    #320
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Not a Midnight Truck (MGM) and not mine but the 316’s are on there
  21. Mar 10, 2022 at 5:00 PM
    #321
    Dmon187
    Dmon187 New Member
    DFW
    Appreciate it, I knew I had seen someone with them installed.
  22. Mar 10, 2022 at 6:16 PM
    #322
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    That looks great! Just right. Flash of aggressiveness but still respectable.
    Rwaters[QUOTED] likes this.
  23. Mar 10, 2022 at 8:20 PM
    #323
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Just got my Method 703 bead grips in today. I ordered them Monday night. They are gloss titanium 17x8.5 +35 for my silver truck. These will be wrapped in 315/70/17 tires. I used the Revere Overland 20% discount, pretty good deal. They are a little concave but in the photo it looks convex somewhat
    MTundra87, ToyoTundra89 and Dmon187 like this.
  24. Mar 10, 2022 at 8:23 PM
    #324
    bigjuice
    WA State
    2024 Terra TRD Pro
    Looking forward to seeing them on the truck
  25. Mar 10, 2022 at 8:28 PM
    #325
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I need to get the truck still! Haha
  26. Mar 10, 2022 at 8:30 PM
    #326
    bigjuice
    WA State
    2024 Terra TRD Pro
    ok :fingerscrossed:
    PapaDave418[QUOTED] likes this.
  27. Mar 10, 2022 at 8:43 PM
    #327
    Dmon187
    Dmon187 New Member
    DFW
    Those are nice
  28. Mar 11, 2022 at 4:25 AM
    #328
    badmeat
    badmeat New Member
    Cincy, OH
    2022 Limited
    My eta is 3/20-3/25 and I’m hoping for the same. Im curious how long after it arrives via rail that it takes to be loaded on a truck.
  29. Mar 11, 2022 at 7:04 AM
    #329
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    can you weight these for us?
  30. Mar 11, 2022 at 8:46 AM
    #330
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    According to my ever reliable bathroom scale they are 27.3 pounds
