Lift HELP Please
Discussion in '2.5 Gen Tundras (2014-2021)' started by skipetex, Mar 7, 2022.
  1. Mar 7, 2022 at 6:44 PM
    skipetex
    skipetex [OP] New Member
    scott
    17 TSS
    I am a newbie and this is my first post. I own a 17 TSS with Bilstein 5100's on all four corners with 1 inch blocks in rear. I would like to raise this truck 3 inches qith the hope of keeping the shocks I have. My budget is hopefully no more that 1500. Any help or suggestions will be appreciated. Thank you in advance.
  2. Mar 7, 2022 at 6:50 PM
    Okierunner
    Okierunner New Member
    2020 TRD Offroad Crewmax
    Icon UCA Bilstein 6112/5100 Method 17s Ridge Grappler 35x12.50 Trd Dual exhaust
    Westcott designs makes a collar that fits your shocks to give you 3” then you can choose a size rear block or shackle to get the front to rear stance you like.
  3. Mar 7, 2022 at 6:51 PM
    skipetex
    scott
    17 TSS
    Awesome ill check them out. Thanks
  4. Mar 7, 2022 at 6:56 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! What setting do you have your front 5100s currently set at?
  5. Mar 7, 2022 at 6:57 PM
    skipetex
    scott
    17 TSS
    They are set on top groove
  6. Mar 7, 2022 at 7:03 PM
    RobertD
    Robert
    DFW, Texas
    Are you trying to get a 3" lift from stock height or add 3" to your maxed out 5100? Just know that around 3" from stock height you normally need new upper control arms. So if you are wanting maxed 5100 plus 3" you will definitely need new UCAs
    joseph_womack and Seafury like this.
  7. Mar 7, 2022 at 7:07 PM
    skipetex
    scott
    17 TSS
    I would like to have 3 more from where it is now. Uca change is fi e if needed. I just don't know which kit to even start with
  8. Mar 7, 2022 at 7:58 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    If you are maxed on the 5100s that puts you around 2.5” of current lift. You can not get another three inches out of that suspension setup without doing a drop bracket kit assuming that you have 4wd. Your CV axles will get destroyed and you will never be able to get it aligned. You can realistically get maybe 1 more inch with some spacers but the ride will suck.
    Edit: here is a starting point but search the site. There is lots of good info.
    https://www.roughcountry.com/toyota-suspension-lift-kit-75130c.html?gclid=EAIaIQobChMIivTJ98-19gIVURbUAR3LrwENEAQYByABEgJ0bPD_BwE#278=516&266=734&utm_source=google&utm_medium=cpcs&utm_campaign=16171210782|140021931744&utm_content=581577623749&utm_term=|pla-1616642480139|m||75130
    2mchfun likes this.
  9. Mar 7, 2022 at 8:03 PM
    Blueknights75
    Ron
    Clayton, NC
    Not going to happen with those shocks….
    joseph_womack likes this.
  10. Mar 8, 2022 at 4:32 AM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    ^^^ This is on point.
  11. Mar 8, 2022 at 4:34 AM
    Seafury
    Agent K
    SC Low Country
    ^^^^This is also on point.
    If you want to go 3" above your 2.5/1 level, you need a normal lift kit with all that goes with it.
    Your talking LOTS more money.
    Search the suspension section and that link above.
  12. Mar 8, 2022 at 4:49 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Pay once, cry once... Plenty of options to achieve that lift your looking for... Eibach or Toytec Coilovers is a solid choice, not bottom shelf, not top shelves like Kings or Fox, but affordable and solid set-up...Good luck.
  13. Mar 8, 2022 at 6:16 AM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    @skipetex, please, PLEASE, don't waste your money going cheap. If you buy a cheap lift, you will get crap for ride quality, crap for off-road ability, and crap for safety. Not to mention the fact that you will probably end up breaking stuff on your truck and you will end up spending more money than you would have if you just saved up and got something good.
    When you lift, don't forget to budget extended brake lines, extended wheel speed sensor lines, upper control arms, and all the other things that come with changing the geometry of the suspension.
    Do a lot more research and save up more money so you don't waste it.
    StockedUp, 2mchfun and Seafury like this.
  14. Mar 8, 2022 at 1:18 PM
    StockedUp
    StockedUp If you come to a fork in the road, take it.
    Carrollton, TX
    2018 Black 1794 4x4
    TBD
    I concur with Great Basin and everyone else here. I put on 6112's on top setting and added anther 1/4" riser to get me true 3". While I did do the drop kit at the time, I did not put on UCA's because 1. I didn't have enough cash hidden from my wife at the time and 2. the shop told me they could (but barely) get me aligned. For the last six months, until last week, my truck rode like total crap. My steering sucked, the truck would tend to dart around at high speeds after any decent bump in the road. It was bad. I just installed the Total Chaos UCA's and out of all I've done to my truck, this was the single best and most noticeable change.
    I know money burns holes in our pockets for our trucks, but take their advice and wait until you can do it right, with the parts that will last. Otherwise, you're going to get something you're going to end up hating or changing in the near future. Good luck!
    Seafury likes this.
