Rear passenger wheel sticks out farther
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dustydirt19, Jun 30, 2017.
  1. Jun 27, 2020 at 5:33 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Normal! Look at other manufacturers. Theirs does it too.
    Cpl_Punishment likes this.
  2. Jun 27, 2020 at 5:51 PM
    Tundramoney
    Tundramoney Old school
    Earth
    They do it so when you haul or put a heavy load in back the rear will be centered when you accelerate.
  3. Jun 27, 2020 at 8:28 PM
    SuperWhite20
    Robert
    Georgetown TX
    Explain to me how a fixed solid axle is going to center itself when putting torque to it! It is set on leaf springs. It’s not going to center the axle putting a load in the bed or accelerating. If your axle moved side to side you are going to have one “swaying ride”. I have been a tech for over 45 years. I have measured mine and don’t find anything loose or out of wack. Other manufacturers do the same thing if you look closely at them too.
    This isn’t even affecting the thrust angle when doing an alignment.
  4. Jun 27, 2020 at 8:54 PM
    Tundra newbee
    Tundra newbee New Member
    2020 Tundra TRD
    Toytec Boss 2.0 295-70-18 Toyo ATIII
    Works for me! Thanks superwhite 20!
  5. Jun 28, 2020 at 4:54 AM
    Tundramoney
    Earth
    and not or
  6. Jun 28, 2020 at 6:37 AM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Well, one wheel with a different offset might work at first, but tire rotations would become a real PITA since that rim would have to stay in the same position...
  7. Jun 28, 2020 at 4:58 PM
    Tundra newbee
    2020 Tundra TRD
    I think I’ve seen a 1/2 spaced floating around, that would take away most of the difference instead of a single wheel with a more aggressive offset. I think one of the members here had a post about it too
  8. Mar 7, 2022 at 1:16 PM
    Vermont1
    Vermont1 New Member
    RK
    20 SR5
    Bilstein 5100 level Vision Creep 417
    Just put new wheels and tires on today and this was the first thing I noticed. My OCD is going into hyperdrive drive now. F*$k me in the goat @$$
  9. Mar 7, 2022 at 4:31 PM
    Jernik
    Jernik New Member
    Jeremy
    I noticed that a while back on mine. Convinced myself I just wasn't looking at each side equally straight on. Drives fine.
  10. May 17, 2022 at 7:53 PM
    ostm282
    ostm282 New Member
    Stock 2018 Tundra Limited Silver
    2" leveling kit installed up front
    Because I'm OCD about shit like this, my ultimate solution was to remove the 1.25" Spidertrax spacer (I installed the 1.25" spacers on all 4 corners previously) and replaced it with a 1" spacer on the rear wheel that sticks out more than the other side. It corrected the problem enough that I don't notice it anymore.
