3 inch lift, do I need new upper control arms?
Discussion in 'Suspension' started by WhiteTundra04, Sep 3, 2020.
  1. Sep 3, 2020 at 9:25 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Checking it out now.
  2. Sep 4, 2020 at 7:57 AM
    AZTundra
    Paul
    Phoenix, AZ
    If it's not too late...use discount code: HOONIGAN on the pedal commander website for $50 off making it $249.
    the ER kid likes this.
  3. Mar 7, 2022 at 11:38 AM
    wwjdjfl
    wwjdjfl New Member
    2021 Tundra 4x4 SR5
    2/3 lift, tires oversized, bumper, taililights
    Yes. Or probably. I did a cheap readylift 2/3 and it was close but could not alignment could not be done perfectly. They ran out of range for adjustments. So turns out they new upper control arm is necessary. Or possibly just lower would work since I am so close. Techs at SPC were helpful. Techs at readylift where less so, but then again they are the ones who sold this as a compatible lift.
  4. Mar 7, 2022 at 11:43 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    If you are doing the work yourself, you can buy the UCA and wait to install them after you attempt an alignment.
