Do you run a locking gas cap?
Discussion in 'General Tundra Discussion' started by IowaGuy, Mar 6, 2022.
  1. Mar 7, 2022 at 8:07 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    Did mythbusters cover that one and did it do anything to the vehicle?
  2. Mar 7, 2022 at 8:33 AM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Jokes on then, with my embarrassing 26 tank and single digit mpg, there is rarely anything but hopes and dreams in my fuel tank
    :oops:
  3. Mar 7, 2022 at 8:34 AM
    Seafury
    Agent K
    SC Low Country
    Seen it done irl, and seen the results.
    Full fuel system replacement and engine flush and several oil changes.
    Several thousand dollars in costs if you catch it in time, otherwise, blown motor, new car.
  4. Mar 7, 2022 at 9:27 AM
    Sugar doesn't mix with gas; you need to put in the "brine" of sugars....fructose from a soda drink.
    A bottle of mountain dew should wreak havoc.
  5. Mar 7, 2022 at 9:42 AM
    Can the RCI tank skid be modded with additional plates to close it off? I haven't seen how much the RCI covers.
  6. Mar 7, 2022 at 11:19 AM
    2mchfun
    Another reason for zero deductible on comprehensive. Check into it folks, very little difference in premiums.:thumbsup:
    RitcheyRch and TTund16 like this.
  7. Mar 7, 2022 at 11:53 AM
    TTund16
    TTund16 New Member
    @Jim LE 1301 posted it. the part number is 10504.
    I have a 2016. Search for Stant locking gas cap on Amazon. Looks like prices gone up to $18. I think I paid $12.
  8. Mar 7, 2022 at 11:59 AM
    IowaGuy
    In Process
    Many of the reviews on the stant cap said if caused a CEL?
    RitcheyRch likes this.
  9. Mar 7, 2022 at 12:09 PM
    TTund16
    TTund16 New Member
    I keep the oem gas cap in the car just in case but so far no issues.
  10. Mar 7, 2022 at 12:11 PM
    2mchfun
    Yep! I have one, it does about every third drive cycle. Scan guage 2 takes care of that with the push of a few buttons.
  11. Mar 7, 2022 at 12:46 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Has anyone installed a locking fuel door on their truck with flares? I'm thinking it won't fit.
    Ely010606 likes this.
  12. Mar 7, 2022 at 12:59 PM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    @Jim LE 1301
    Dang Jim, when are you going to clean out the garage?
  13. Mar 7, 2022 at 1:01 PM
    2mchfun
    Depends on the flares. I have both on my truck.
    Edit: the locking fuel door is pretty useless for security, a simple pry tool slightly stronger than an ink pen will pop the hinges.
    TTund16 likes this.
  14. Mar 7, 2022 at 1:44 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Try to siphon or pump out through the filler neck. It’s not easy. If I were going to drain my tank I’d use the pump (which is not easy for a thief) or drill a hole in the plastic tank (easy, more efficient, and you’ll get more fuel out). Bottom line I won’t bother with a locking cap.
    I also don’t have a locking cap on my work truck or in bed transfer tank. If someone is determined enough to steal it they’ll figure out a way. I’d rather just refill the tank than have to buy a new one because it got destroyed.
  15. Mar 7, 2022 at 2:03 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I don't see why it wouldn't fit.
    131C28E3-753D-44DC-ABE1-E54233F6AD4B_zps_e65509a3a41e53c285ed6519addceaf1291cceef.jpg
    https://youtu.be/eeU3o1cO-qY
    Ely010606, 2mchfun and Black Wolf like this.
  16. Mar 7, 2022 at 2:21 PM
    That picture is about 2 years old.:rofl:
    marc32[QUOTED] likes this.
  17. Mar 7, 2022 at 2:22 PM
    That's why I didn't go with the cap.
  18. Mar 7, 2022 at 2:22 PM
    Warreng
    Warreng New Member
    I helped an older fella remove his frozen locking gas cap this winter. I made a not to never own a locking gas cap.
  19. Mar 7, 2022 at 2:24 PM
    It fits.
    And yes George @Tundra234 I used PPF under the flares.:thumbsup:
    2mchfun and texasrho83[QUOTED] like this.
  20. Mar 7, 2022 at 2:36 PM
    #50
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Jim LE 1301 likes this.
  21. Mar 7, 2022 at 2:56 PM
    #51
    :hattip:
  22. Mar 7, 2022 at 3:14 PM
    #52
    Not allowed in my state. $300 min is as low as you can go.
    2mchfun[QUOTED] likes this.
  23. Mar 7, 2022 at 4:13 PM
    #53
    I remember when diesel hit 5.00 a gallon in 2007 (?). I replaced so many tanks it was ridiculous. Most had some kind of locking cap/door.
    texasrho83 likes this.
  24. Mar 7, 2022 at 6:26 PM
    #54
    Randy Morton
    Randy
    Deepinahearta, Texas
    I've run a locking gas cap off and on for years, and on different vehicles. The gas crisis in the 70's, A gas thief in the 80's (I put the locking cap on my pickup, but the thief wasn't deterred. He simply siphoned from my wife's car. It turned out it was the kid across the street and his little Mustang didn't run well on the diesel from my wife's car), I put a locking cap on the Tundra during COVID when many were out of work, and now with prices jumping I'll leave it there . As has been said, it won't stop the pro, but it'll make the amateur move on to an easier target. It's a Stant 10504 and there have been no Check Engine Light problems so far.
    WVI likes this.
  25. Mar 8, 2022 at 9:23 AM
    #55
    Maddog94
    Maddog94 New Member
    $27 now!
    TTund16[QUOTED] likes this.
  26. Mar 8, 2022 at 9:35 AM
    #56
    Maddog94
    Maddog94 New Member
  27. Mar 8, 2022 at 9:53 AM
    #57
    KillerBeee12
    KillerBeee12 New Member
    Brandon
    Gilbert, AZ
    2020 Tundra Crewmax TRD Sport
    Front and rear TRD sway bars - Tyger T1 bed cover
    Gloss black, imo
  28. Mar 8, 2022 at 10:44 AM
    #58
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well, after doing an extensive search (limited to my lunch break) I decided on CarID's RBP locking lid. 10% vet discount. Thanks for the info y'all.
    Spoke to a buddy of mine who had a 'shady past' and he mentioned he'd cut a cross slit into the rubber fill hose and siphon gas that way. He mentioned a deterrent for that would be some aluminized flex pipe at the local parts store. Think I'll do that this weekend.
    Yes, they can still drill the tank and pry the door but the longer they have to spend getting anything from me, the better the chance they get caught.
  29. Mar 8, 2022 at 10:45 AM
    #59
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Matte black
  30. Mar 8, 2022 at 11:07 AM
    #60
    1lowlife
    DADA
    2014 MGM DC SR5
    I would think flat/matte black.
    I tried to buy one about 6 months ago and couldn't find one in stock anywhere..
    I'd rather have one like @Jim LE 1301 has that doesn't have the RPB 'R' and star on it like the pic above.
    He has an MGM and his matte black looks good.
