V35A - How much boost?
Discussion in '3rd Gen Tundras (2022+)' started by 4genRunner, Mar 6, 2022.
  1. Mar 6, 2022 at 7:10 AM
    4genRunner
    4genRunner [OP] New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    I’ve done a few quick searches but not found an answer. Wondering how much boost the engine is running stock. Anyone with a 2022 and a scan tool that has looked?
  2. Mar 6, 2022 at 9:05 AM
    Tundra-G
    Tundra-G New Member
    2022 Tundra Ltd 4x4 TRD Off-road
    Here is the result, idling and under power in Sport drive mode.
    The absolute boost is topping at 32.7psi. Taking off the 14.7psi (atmospheric pressure), puts the max boost at around 18psi.
    OnThaLake, ColoradoTJ and landphil like this.
  3. Mar 6, 2022 at 9:30 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Intake manifold pressure numbers you posted are absolute, not gauge. So you have to subtract atmospheric pressure (14.7 psi at sea level) to get gauge pressure.
    I’m pretty sure the boost pressure numbers you posted are absolute as well, but a quick KOEO reading would confirm that.
    The 49% throttle at 203% load doesn’t make a lot of sense to me, but maybe that’s from me sniffing too much diesel. :notsure:
    ColoradoTJ and Darkness like this.
  4. Mar 6, 2022 at 9:35 AM
    Tundra-G
    Tundra-G New Member
    I think you are correct, the psi at idle was 14.7, then 32.7 under load, which puts the boost at 18psi. I’m editing the post above.
    The load value and throttle position does not make sense either. However, I think throttle position is relative to what drive mode you are in.
    landphil[QUOTED] likes this.
  5. Mar 6, 2022 at 1:55 PM
    xc_tc
    xc_tc New Member
    I’ve seen about 10~15 psi boost so 18 makes sense.
    Load and throttle makes sense to me. This seems to be absolute load which means the cylinder is intaking 200% of air mass. The throttle doesn’t need to open all the way because of the boost. If you had maf you could calculate load.
  6. Mar 6, 2022 at 2:16 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Burgertuning dyno a stock 2022 SR5 Tundra and it made peak boost of 10 psi. :confused:
    Blue line is boost. Peaking 10 psi.
  7. Mar 6, 2022 at 2:26 PM
    xc_tc
    xc_tc New Member
    They barely hit 350 lb-ft. They didn’t get WOT until like 4000 rpm. Their accel was at like 45% or less and you can see boost pressure goes up when they hit WOT. Most of the higher boost will be at lower engine speed. At higher engine speed boost will start to taper off.
    Tundra-G and OnThaLake like this.
  8. Mar 6, 2022 at 7:42 PM
    4genRunner
    Southwestern MO
    Thanks for checking. Was guessing it would be somewhere around 1 atmosphere, but looks to be a little higher than that.
