Life span on synthetic line?
Discussion in 'Recovery & Gear' started by smslavin, Mar 20, 2021.
  1. Mar 20, 2021 at 12:07 PM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    sun’s out so, i was just outside making a little inspection on the winch line as it’s been wound up all winter. also wanted to try and figure out what got it stuck when i tried to help the neighbor during snowmageddon.
    it’s dated 2016 and color is a bit faded but most of it appears in good shape. there are a couple of spots at the eyelet (metal) that i need to keep an eye on. looks like stress area/rub while it’s spooled up.
    what’s the lifespan on synthetic line?
  2. Mar 20, 2021 at 12:22 PM
    Mine is 9 years and going strong.
    I can't remember if you park your bad ass truck in a garage? When synthetic rope is exposed to UV, it will degrade faster. I have seen people make plastic "covers" from something that fit tightly around the drum to protect the rope from the elements.
    smslavin[OP] and BravoDeltaRomeo like this.
  3. Mar 20, 2021 at 1:51 PM
    timsp8
    NY
    Mine just broke first time trying to use it on my smittybilt x20. I now have a warn winch sitting in my garage that I’m waiting to install. It came with the spydura rope. No comment on it yet, but I don’t trust the x20 anymore.
  4. Mar 20, 2021 at 2:10 PM
    smslavin
    Hudson Valley
    Some stuff
    nice one. you’re funny. 1945 garage + tundra on 35s = no f’ing way.
    winch is down in the bumper. the nylon wrap on the last 10’ or so covers the entire line when it’s wound up. there isn’t any rope showing to daylight.
    most of the line looks okay. just a few small frays at the eyelet. i’ll take a pic later.
  5. Mar 20, 2021 at 2:15 PM
    Well, one can be hopeful.
    smslavin[QUOTED][OP] likes this.
  6. Mar 20, 2021 at 2:18 PM
    TheBeast
    TheBeast The Beach
    probably similar or a bit more than climbing ropes ?
    smslavin[OP] likes this.
  7. May 29, 2021 at 3:46 PM
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Steel cable won’t fade ‍♂️
  8. Sep 30, 2021 at 5:33 PM
    chrispick
    chrispick New Member
    chris
    Use the expensive sailing rope made with Aramid and kevlar fibers. No issue with UV on the sailboats. It actually might be too strong and not have any stretch. This is what I use on my winch
  9. Mar 6, 2022 at 6:15 PM
    captjeff
    captjeff New Member
    Jeff
    2018 Tundra
    Stock
    To properly check this line you have to look how the inside of it looks. Check out Sampson Rope for more information on it
