  1. Mar 6, 2022 at 8:48 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Windoor? Is this a southern thing? Is it written in English? I know not what this thing is.
    Edit:never mind. I see the reference now. I do and don’t want a topper with or without windoors
    NUDRAT and FrenchToasty like this.
  2. Mar 6, 2022 at 8:56 AM
    I think I agree
    5N0W808 likes this.
  3. Mar 6, 2022 at 9:25 AM
    Well shit, I guess we may need to make a club out of this then, because I'm definitely in the same boat re: bold/italics sentiment.
    If a good cap in the $200-500 range pops up in white within 90 minutes of ATL, I'm scooping it up.
    That said, I'm conflicted about whether it's going into storage for a while or if I'd install right away or ... ugh.
    I love the utility of it. But I use my truck for other purposes, most noteworthy being mulch and soil mix. Don't want to be removing the lid every 2-4 months.
    Sort of how I ended up with the tri-fold TonnoPro. It's doing the job fine. But I can't stop loving the thought of a cap, especially how they look. @FirstGenVol 's truck looks awesome.
  4. Mar 6, 2022 at 9:48 AM
    Feno
    Feno New Member
    James
    Berkshires, NY
    03 AC SR5
    As I slowly go through this truck getting rid of all the rusted parts the previous owner had bolted up to a new frame :confused:. I did the shocks yesterday and was amazed to see that they had quite a bit of resistance still.
    Had to cut into the rears to stop the shaft spinning as the top bolt needed a sawzall adjustment.
    It seems you replace one thing and it turns into a 5 hour job replacing something else, i.e. replacing backing plates and rear bearings, seals, then I find the brake lines are rust welded onto slave cylinders, so now all the brake lines on the rear need replacing! So then replacing all the break lines all the bolts attaching the lines to the diff snapped off ( using heat and pb blaster).
    It's definitely a war of attrition working on a truck with 'deferred maintenance' :mad:
  5. Mar 6, 2022 at 10:15 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Holy rot! I’m surprised those didn’t pop a leak at a weld
    Is that truck a TRD offroad? If so… I’d be willing to pay shipping my for those springs if your not going to use them
    Jack McCarthy and NUDRAT like this.
  6. Mar 6, 2022 at 10:50 AM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    Damn... I don't miss the days off duct taping holes in my car to pass emissions testing.
  7. Mar 6, 2022 at 10:53 AM
    Casper421
    In the woods
    06 DC
    Everything is off and ready to be rebuilt.
    oscardog86, Darkness, bmf4069 and 4 others like this.
  8. Mar 6, 2022 at 11:00 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I'm 98.375% certain you can just go to a cap place & have them order windoors in to replace your windows & if you're lucky they will buy your old windows.
    oscardog86 and RUSTYNUTS like this.
  9. Mar 6, 2022 at 11:04 AM
    empty_lord
    05 rollover special
    NUDRAT[QUOTED] likes this.
  10. Mar 6, 2022 at 11:07 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    This was 2 weeks ago.
    des2mtn[QUOTED] likes this.
  11. Mar 6, 2022 at 11:09 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Investigating the possibility of an ARB twin under a front seat today.
    des2mtn and FrenchToasty like this.
  12. Mar 6, 2022 at 11:16 AM
    I had never heard the word either until someone else said it here. They are handy though. Much better than the other style. The best I've seen is a hybrid that both pops out and has a sliding portion.
  13. Mar 6, 2022 at 11:18 AM
    The ultimate
    Tundra2 likes this.
  14. Mar 6, 2022 at 11:18 AM
    Ouch. They rape you guys in gas taxes there. $1.18/gallon goes to taxes and fees. Insane.
  15. Mar 6, 2022 at 11:19 AM
    I know someone makes a kit for a 4th gen 4runner……..
    I’m sure it would require removing the seat, but I bet it could happen
    alb1k[QUOTED] likes this.
  16. Mar 6, 2022 at 11:22 AM
    I tried to do this with my Snugtop since it had a broken window anyways, if it’s a older cap, chances are they never made a windoor for that specific model. When I talked to the local dealer, he said they are relatively new, so unless it’s a brand new year model cap, it will be hard to find the correct one
    oscardog86 likes this.
  17. Mar 6, 2022 at 11:24 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yup, I've heard more like $1.50 in taxes now. We just hit 5 bucks yesterday. I'm ready to start going down to Mexico and pay 2 bucks a gal. It's only a 5 mins drive from my job.
    RUSTYNUTS and des2mtn like this.
  18. Mar 6, 2022 at 11:25 AM
    Is it actually gas though?
  19. Mar 6, 2022 at 11:29 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I'm lucky to live near the Rez where not all of that applies and gas is generally a little bit cheaper than everywhere else. Tax free liquor that isn't marked up is cool too.
    The prices do suck though, we've paid them times before but we'll be hitting records before too long.
    KingSequioa007 likes this.
  20. Mar 6, 2022 at 11:29 AM
    des2mtn
    SW
    Tonto cover
    You can always tell when people are running that shit.
  21. Mar 6, 2022 at 11:33 AM
    alb1k
    Left Coast
    It's good
    Driver’s side fits with front seat jackers and rear air duct delete/mod. I’m going to look more closely at the passenger side.
    oscardog86, Darkness, bmf4069 and 3 others like this.
  22. Mar 6, 2022 at 11:35 AM
    How long are the lines to get in and out of Mexico? I've never been to a border crossing.
  23. Mar 6, 2022 at 11:46 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yea for the most part. I would only go to a reputable one that most peeps down here and there use. I also service lots of TJ cars at my shop and about 90% never have issues with gas ⛽️ from there. Plus I would definitely use high octane, not trusting the low 87 kind. Lol.
  24. Mar 6, 2022 at 11:48 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Not long going in during the week. 5-10 mins tops. The way back depends. If you have a Sentry pass (fast pass) then back in tops 15 mins. The real joy is enjoying the 1 dollar amazing tacos down there.
  25. Mar 6, 2022 at 12:04 PM
    Brinkerro
    Brinkerro Phew...that was close!
    VA Beach VA
    2002 Toyota Tundra
    New kicks all 'round.
  26. Mar 6, 2022 at 12:36 PM
    Wife had to go to LA for work on Tuesday, gas near the airport was $5.39/gal when she arrived. When she left today it was $6.59/gal.
    Sounds pretty gougey to me.
  27. Mar 6, 2022 at 12:39 PM
    Goddamn, that’s a lot of rust!!!
    Im used to rust, but those shocks have long outlived their life.
    txagg, des2mtn and FirstGenVol like this.
  28. Mar 6, 2022 at 12:46 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The ARB compressor? In cab space is kinda valuable on crackie, but if it's gonna be a road tripper then I'll need a way to fill up a spare.
    Course, I could just bring my milwaukee tire inflator with me, and be done... but where's the fun in that if I want to run a train horn too down the line
    RUSTYNUTS, alb1k[QUOTED] and des2mtn like this.
  29. Mar 6, 2022 at 1:08 PM
    alb1k
    Left Coast
    It's good
    It’s going in, just navigating bolt access from under the truck.
    des2mtn likes this.
  30. Mar 6, 2022 at 1:21 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yea LA loves to price gouge. Specially downtown and LAX. They capitalize on people with money and don't care who they hurt in the area, aka their workers running the cities.
    Darkness and shifty`[QUOTED] like this.
