Sunroof issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by fortiz619, Mar 4, 2022.
  1. Mar 4, 2022 at 4:40 PM
    fortiz619
    fortiz619 [OP] Mall crawler
    SoCal (SD)
    2017 crewCab 4x4
    3 inch lift
    Searched everywhere with no avail and just my luck , sunroofs been stuck open and it’s pouring in SoCal , had to tape it up , been busy trying to figure out the issue and I’m guessing it’s the motor but There is absolutely NO noise clicking or grinding when pressing the buttons , to my surprise after removing switch console there is no way to access the motor like the older models , looks like someone has been in here? , anyways I’m guessing the headliner has to come down ? Any help
  2. Mar 4, 2022 at 4:42 PM
    fortiz619
    SoCal (SD)
    2017 crewCab 4x4
    3 inch lift
    Another pic
  3. Mar 4, 2022 at 5:19 PM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    Have you looked up the fuse that powers the sunroof and confirm not blown?
    fortiz619[OP] likes this.
  4. Mar 4, 2022 at 5:31 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    There's a thread somewhere that goes over how to replace the motor. I'll try and find it.
  5. Mar 4, 2022 at 5:32 PM
    fortiz619
    SoCal (SD)
    2017 crewCab 4x4
    3 inch lift
    Fuse checks out fine
  6. Mar 4, 2022 at 5:33 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Doesn't it have a mechanical method to close with a supplied tool or an Allen wrench?
    HulkSmurf14 likes this.
  7. Mar 4, 2022 at 5:36 PM
    fortiz619
    SoCal (SD)
    2017 crewCab 4x4
    3 inch lift
    No ,from the info I’ve gathered these tundras do not have manual way of closing them ,that was my first thought
  8. Mar 5, 2022 at 10:13 PM
    fortiz619
    SoCal (SD)
    2017 crewCab 4x4
    3 inch lift
    Little update , after my wife slammed the passenger door the sunroof began to work again wtf?:confused::confused::confused:, I removed fuse after closing it , motor isn’t cheap will wait to fix
    Njmike13 and MT Madman like this.
  9. Mar 6, 2022 at 2:41 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Sure wish I didn't have the sunroof, I never use it.
    ackthresher likes this.
  10. Mar 6, 2022 at 3:41 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Note taken. If i have problem with mine i will piss off my wife so she slams the door. Thanks!
    It closed with the fuse removed? After it closed did you attempt to operate it again?
    MT Madman likes this.
  11. Mar 6, 2022 at 8:11 AM
    fortiz619
    SoCal (SD)
    2017 crewCab 4x4
    3 inch lift
    I removed the fuse to stop any power to the sunroof AFTER I closed it
    Njmike13[QUOTED] likes this.
  12. Mar 6, 2022 at 8:15 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Damn that was funny!!!
