2015 5.7 TBI Upgrade
Discussion in 'Performance and Tuning' started by printmonger, Feb 26, 2022.
  1. Feb 26, 2022 at 6:41 AM
    printmonger
    printmonger [OP] New Member
    Mark
    2015 Tundra 5.7
    Bone freaking stock
    I have a customer wanting to put a larger TBI unit on his truck stating he will get better gas mileage out of it. Question; what size is the stock TBI unit (76mm?), is his reasoning correct, what size should he upgrade to, where do I get one from, other upgrades needed with a larger TBI???
  2. Feb 26, 2022 at 7:17 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Unsure of any reason to upgrade that unless he is running a SC. I have not heard of any benefits on a stock motor and don't know of anyone running one on a stock truck. I think there are 90mm TB available. No help on what it may take to make that work, other changes or upgrades needed.
  3. Feb 27, 2022 at 5:40 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    If it helped MPG, Toyota would have put it on the engine.
  4. Feb 28, 2022 at 7:16 PM
    prevent
    prevent New Member
    2014 5.7L Tundra SR5 DC
    TRD Catback Stillen CAI DAP Tune Tow Mirrors Light sensor Dashcam TRD Pro Grill LED Interior lights + DRL’s
    This. Toyota really did everything they could to push MPG as far as it could go, that’s why our oil filter housing is plastic.
  5. Mar 1, 2022 at 10:14 AM
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    All a larger intake will do for N/A is cause it to run lean for a millisecond before the computer uses fuel trims to add fuel back in.
    It may throw a dash light if it consistently sees high positive trims and it's irrelevant to mpg because it's going to always shoot for 14.7 to 1 anyway.
    If he were to correct the MAF table to match the new intake then everything would be the same as stock (fuel trim-wise, fueling wise) with just a slightly better throttle response. Again, no notable change to mileage.
    HulkSmurf14 and nobodyintexas like this.
  6. Mar 1, 2022 at 11:18 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Damn Toyota and their engine management systems!
    That said, I agree 100%. No appreciable advantage other than the mileage gained by reducing weight from a wallet….
    4firemandan[QUOTED] likes this.
  7. Mar 2, 2022 at 4:17 AM
    4firemandan
    SWFL
    Lol. The ol wallet weight reduction. I'm a pro at that one! Haha.
    If it makes you feel any better, GM and Ford and the others would all work pretty much the same way.
    A clean, easy flowing filter and an easy flowing exhaust would be the best bet.
    I guess in that respect a larger intake would technically be less restrictive and theoretically "help"but I think it's not anywhere close to a noticeable improvement. Even a good air filter is minimal and that's probably a much much better help than an intake.
    Once you start talking top end performance the larger intake would matter. That's the real purpose to this kind of upgrade in my opinion.
    10TundraSR5 likes this.
  8. Mar 2, 2022 at 4:40 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    These people pretty much nailed it.
  9. Mar 3, 2022 at 1:44 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Add some LT headers on NA and your client will smile at his 1-2mpg gains...
  10. Mar 3, 2022 at 2:37 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    These two nailed it. i played around with this a few years ago. There was a similar discussion a while back about this, here.
    First attempt was porting and polishing the tb, then looked at the larger one by Prospeed, which requires an adapter.
    Even if you could run a tune/remap for the MAF sensor, the problem is still the intake itself…between the design of the inlet tube and the internal runners. Without a s/c application, a larger tb would be a potential waste, if not a problem for n/a application.
    if you want ‘cooler’ air, consider the tb bypass mod (search the forum for it).
    As mentioned, for n/a applications, one of the best go-to (proven) hp gains is LT headers and @dirtydeeds dual race exhaust.
