  1. Mar 2, 2022 at 4:22 AM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Fair question. It breaks the 12 VDC battery power (positive lead) close to the battery. Just added safety so power isn't hot at the control box (for me, on the other side of the engine bay) until the solenoid switch turns it on. I temp. mounted the switch near the battery but I think many mount the switch in the cab on the dash or other places. It can also be used to supply power to other aux., devices like fog lights, etc. Best.
  2. Mar 2, 2022 at 4:29 AM
    Badknees
    Badknees New Member
    I'm not sure I would have committed and bought everything retail as the total costs are way up there. I was lucky enough to get most everything I needed from a good member on this site at a much lower price. However, I think you get what you pay for and no doubt this is a sweet set-up...if I do say so myself! :D
  3. Mar 2, 2022 at 6:50 AM
    AggiePhil
    College Station, TX
    Oh so it’s like a solenoid breaker? What’s the concern about having constant power to the winch?
  4. Mar 2, 2022 at 7:07 AM
    Badknees
    Badknees New Member
    More like a contactor I suppose than a breaker since the solenoid doesn't trip-out based on current load. It's not a huge concern, but I needed a new power connection anyhow and decided to build-in a little safety. I like it better so I don't have to disconnect the winch power directly from the battery if I ever need to do any work. Also, I don't like over 8 feet of hot battery power cable running across my engine bay when I don't need it. Even in a minor accident, since my hot wire travels in front of the radiator, there's a chance for the 12 VDC wire to be cut/short as well. It also helps assure I kill the control box power so I don't accidentally drain the battery. Lastly, if something weird ever happens with my alternator/battery, the winch control box will be isolated from that event.
    AggiePhil[QUOTED] likes this.
  5. Mar 2, 2022 at 7:16 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Synthetic oil and filter change, and VA state inspection. Thought I may need front brake pads but they passed inspection. Shop did say I should do a bunch of flushes to the tune of $700+, I passed. They wanted to flush PS fluid, coolant, replace serpentine belt, and more. Typical try at a sell, their recommendations were basically all labor changes. Not needed, just did diffs, xfer case fluids 5k miles ago. Belt has 55k miles on it and I see no issues or cracks with it.
    Hoping to get RAS installed this weekend when I am off!
    Mobeyk likes this.
  6. Mar 2, 2022 at 7:20 AM
    I'm still debating on one with my lift and the Alcans.
  7. Mar 2, 2022 at 8:25 AM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    HUD(heads up display) made use of the dash space. Set my screen to time and mph with chirp at 65 and 10 mph after that…not that I speed all the time…hehe
    Njmike13, GAknight, AggiePhil and 2 others like this.
  8. Mar 2, 2022 at 11:54 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    From that perspective, at first glance it looked like you had the whole building in your truck bed! THAT would have been IMPRESSIVE!
  9. Mar 2, 2022 at 11:55 AM
    vanthesupreme
    vanthesupreme I'm Batman
    OKlahoma
    2014 Tundra
    Finally washed and waxed the truck
  10. Mar 2, 2022 at 11:59 AM
    Taco-Spike
    Two Trucks
  11. Mar 2, 2022 at 12:01 PM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    I feel like getting rid of all the shiny chrome makes a big difference without too much tearing apart. CDEC543C-A923-459C-8FA8-79A3F431CF38.jpgB0913E97-5544-4D4D-9050-588BD25CBF15.jpg
    woods, nhw544, BlueRibbon4x4 and 9 others like this.
  12. Mar 2, 2022 at 2:12 PM
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    Lookin good! Is this the Meso stuff?
  13. Mar 2, 2022 at 2:48 PM
    Orracle
    Orracle New Member
    Canton, GA
    Installed the ESP under seat storage
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Anomalos7, nhw544, PaulROahu and 12 others like this.
  14. Mar 2, 2022 at 3:13 PM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    Thanks again for the heads up on that deal @PNW_Husky :cheers: These have way better coverage up front than the WT.
  15. Mar 2, 2022 at 3:14 PM
    Radarninja
    Radarninja New Member
    Ca
    What are your first impressions?
  16. Mar 2, 2022 at 3:21 PM
    Orracle
    Orracle New Member
    Canton, GA
    Very happy with how it turned out. The fit and finish looks OEM. Great place for tow and ratchet straps.
    Purchased mine off Amazon
    GELCW and Radarninja[QUOTED] like this.
  17. Mar 2, 2022 at 3:39 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    Who is the dealer for husky up here in Canada?
  18. Mar 2, 2022 at 4:05 PM
    JerryH
    SOMD
    Yes, MESO kit and eBay emblem cover.
  19. Mar 2, 2022 at 4:23 PM
    FireCpt
    FireCpt New Member
    Michael
    Vine Grove, KY
    2020 SR5 TRD
    TRD Pro grill swap. TRD Pro wheel swap. Go Rhino RB20 running boards.
    3D printed a console badge replacement today. I could customize it to say whatever but thought I'd keep it simple. I did the vent chrome rings yesterday.
  20. Mar 2, 2022 at 5:20 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    Finished the raptor line on my toyota letters, putting it on tonight
    Also got my mob armor phone mount with wireless (kind of) charging. Love this thing.
  21. Mar 2, 2022 at 5:46 PM
    WawaLunar
    WawaLunar New Member
    2021 TRD Pro Lunar Rock
    I got mine at tdotperformance.ca
    Canadian Army TRD Pro likes this.
  22. Mar 2, 2022 at 6:16 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Partsengine.ca and Action Car and Truck accessories have them too.
  23. Mar 2, 2022 at 6:32 PM
    Deacon Blues
    Deacon Blues New Member
    2018 Tundra TRD Off Road
    Debadged and swapped the OEM mats for Husky.
  24. Mar 3, 2022 at 3:13 AM
    D3VA
    D3VA New Member
    NoVA
    2021 TRD Pro in the MGM Master Race!
    I did that to my Tacoma and the stealership took them during one of my service trips. I didn't notice until it was too late. Lost the 2mpg it added to the TACO.
    THORYOTA and Njmike13[QUOTED] like this.
  25. Mar 3, 2022 at 4:21 AM
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
  26. Mar 3, 2022 at 4:45 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I say we put a team together and go get them back. :quickdraw:
  27. Mar 3, 2022 at 6:27 AM
    Taco-Spike
    Two Trucks
    I let my fiancee take Tundra for the first time (her first time driving it) to go to work. :(
    I was rotating her tires on her car last night (ford focus) and found a nail so I took it in for a fix. I stood at the window watched her leave.... was going to happen eventually..
  28. Mar 3, 2022 at 6:34 AM
    RobertD
    Robert
    DFW, Texas
    The true test of the fiancée has begun
    :fingerscrossed:
    Hope she passes the test hahaha
    raspy87, welshmike, SAGE63 and 2 others like this.
  29. Mar 3, 2022 at 6:55 AM
    Taco-Spike
    Two Trucks
    I hope so too
    Maybe I'm just over thinking it
  30. Mar 3, 2022 at 7:22 AM
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    DAMN! That thing is NOOOIIICE!
    Can you share lift, wheel and tire specs?
    Thanks!!!
    the ER kid likes this.
