Fuel gauge off?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra18overland, Mar 2, 2022.
  1. Mar 2, 2022 at 7:50 AM
    Tundra18overland
    Tundra18overland [OP] Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    I recently d/c’d my battery to clean the terminals. I know this throws the computer off when it comes to tank range bc the computer has to relearn everything, however, I recently filled my tank to full and reset my trip stick after filling. As you can see I’m approaching half a tank and my trip stick is only showing a meager 115 miles, which means I’ll have only gotten roughly 250 miles out of this full tank by the time I’m empty. (Yes I know we have 6-8 gal reserve when the light comes on) but I’ve been consistently getting 350-380 miles out of a full tank (from full to until E-light comes on)
    As you can see my range is showing 324 miles (obviously this is wrong if I’m almost at half a tank, but this is proof of the computer having to “re-learn.”)
    It’s as if my fuel gauge is off…
    FWIW I did just move up to 35” tires, but I shouldn’t have lost 100 miles on a tank. (Computer still shows 10-12mpg)
    Does the computer also have to “re-learn” the fuel gauge?
    Would the speedo being off by ~5mph now with larger tires ALSO throw the odo or fuel gauge off?
    Thoughts?
  2. Mar 2, 2022 at 8:23 AM
    timsp8
    NY
    I’d give it a few more fill ups. Mine does the same thing when I disconnect the battery. Normally it shows 410 DTE but goes up to 600+ when I disconnect the battery. It takes it a few tanks to relearn. 115 for a half tank would be low, even for 35s.
    Fill it up now and see how much it takes. I think mine takes about 15 gallons at half a tank. If it’s much less, then your gauge might be off.
    Tundra18overland[OP] likes this.
  3. Mar 2, 2022 at 8:37 AM
    Tundra18overland
    Jesse
    GA
    Thanks Tim, I’ll update after a few more fill ups.
  4. Mar 2, 2022 at 9:14 AM
    BlueLighting
    BlueLighting New Member
    Rick
    California
    2015 Platinum
    4.5 RC Lift, fuel wheels, RC front bumper & front struts
    I get 16 mpg with 35.1 tires. It takes about 300 to 500 miles on my truck for it to relearn after battery is disconnected.
  5. Mar 2, 2022 at 10:03 AM
    Tundra18overland
    Jesse
    GA
    Yeah I’m clear the tank range or distance to empty takes some driving to normalize, my concern is the fuel gauge being “off”
    Have you ever felt like your fuel gauge/needle was off after disconnecting battery?
  6. Mar 2, 2022 at 10:05 AM
    BlueLighting
    Rick
    California
    2015 Platinum
  7. Mar 2, 2022 at 11:59 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Also No.
    Give it a few more fill up cycles and then assess.
  8. Mar 2, 2022 at 12:03 PM
    Tundra18overland
    Jesse
    GA
    Will do, thanks.
  9. Mar 5, 2022 at 4:28 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    yeah whatever % your speedometer being off say 10% your odometer will also be off by same amount since it reads distance traveled based on stock height wheels and basically counts rotations. So larger wheels make it go further than it thinks it is
  10. Mar 5, 2022 at 5:42 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Fuek gauge operates ona direct line to the fuel tank and sender. The sender is a variable resistor that increase the resistance on the direct line as the fuel level drops. If can only be off if your float is stuck or broken, not from disconnecting the battery.
    Speedometer, Odometer, Trip will all be off as they are calibrated to the wheel speed sensors and stocks tire size. The ABS/Stability control ecu monitors the pulses from the wheel speed sensors and calculates a speed, distance moved and sends these values to the cluster. Fastest way to check this is with a free speed/distance app on your phone. It will use GPS to show your actual speed and distance moved.
    Avg. MPG and Range calculations are all done inside the cluster. The engine ecu sends it a signal of fuel burned at a certain rate, it then does the math to get the MPG. Most people report it takes some driving to get all this values to balance back out after resetting them.
  11. Mar 5, 2022 at 1:46 PM
    Tundra18overland
    Jesse
    GA
    thank you. I’ll report back after some more fill ups.
  12. Mar 5, 2022 at 1:46 PM
    Tundra18overland
    Jesse
    GA
    So in essence I would be accruing miles 10% slower?
  13. Mar 5, 2022 at 3:04 PM
    Doxiedad
    James
    Charleston, SC
    yeah
  14. Mar 6, 2022 at 6:50 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Its more like 8% with a 35 inch tire.
    Think of it in amount of wheel rotations per mile, the tall 35 inch tire has to do less rotations to travel a mile compared to the stock tire which the odometer is programmed it. When the odometer increment's 1 mile, your bigger tires have already traveled a mile and then some. If you go on a trip and your trip odometer says you travel 100 miles in reality you have traveled 108 miles, the odometer is just lagging behind because it thinks your tires are smaller.
    How far is your speedo off at highway speed? Say 70Mph on the gauge mean you are really going like 76, check with one of those GPS Speed apps?
  15. Mar 6, 2022 at 7:03 AM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    damn bro did you get the 2016 hybrid V8.
  16. Mar 6, 2022 at 9:45 AM
    Tundra18overland
    Jesse
    GA
    Makes perfect sense, thanks man. Yeah my speedo is off by 5 mph at 80 mph on the highway. Tryin to decide if i should do the hypertech recalibration?
  17. Mar 6, 2022 at 5:40 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Hypertech and Rough Country both only sell inline programmers I believe. These plug inline between your Engine ECU and Cluster, they read the incorrect factory speed signal coming in, apply the correction factor and send the new signal to the cluster. I know they correct the Speed signal but I am not sure if it reads and corrects the distance signal also, I would assume so.
    I have heard rumors some Toyota Dealers can reprogram the speedo. I believe they have a way to get into the ECU and reset the number of Pulses from the wheelspeed sensors to equal a mile. This is the proper way to fix it but harder to do. I assume Toyota is setting this value for the factory as some trucks comes with factory 20 inch wheels while others have 18 inch wheels. Each would have a different amount of pulses from the wheel speed sensor per mile.
    I would love to find a dealer who does this so I can see what software they are using ect. I believe it requires a Toyota ECU flasher, maybe can be done with something like HP Tuners.
  18. Mar 11, 2022 at 5:06 AM
    Tundra18overland
    Jesse
    GA
    that would be really awesome and convenient if the Toyota dealership could reprogram for us.
  19. Mar 11, 2022 at 5:22 AM
    Tundra18overland
    Jesse
    GA
    Thanks for all the responses. After refilling the tank once after this post was made, I am now inclined to believe the fuel gauge also has to “re-learn” just like the tank range does. I am attaching 3 pics. One is the original picture showing a measley 115 miles at nearly half a tank. Second picture is showing the needle at nearly the same position, however, this time I attained 159 miles. In between pics I refilled the tank from
    Half back to full. 3rd pic is showing I’ve attained 175 miles at a half tank, which will hopefully put me at, or close to 350 miles on a full tank (trip stick at 350 miles when gas light comes on and range is 0). Also to be clear, the driving I did between fill ups (the 115 mile trip stick and 159 mile trip stick) I drove with the same driving behavior and same city driving. Also, as you can see the tank range is still re-learning. The stock days of 450 miles+ on a tank was nice, but since then I’ve upgraded my truck substantially to include 35x12.50 tires, steel bumper, steel skids, sliders, camper shell (all the heavy stuff lol).
