  1. Mar 1, 2022 at 11:56 AM
    Hey, I just realized, this almost looks like the front end of the 2022 Tundras.
    bmf4069, NUDRAT and alb1k like this.
  2. Mar 1, 2022 at 12:00 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Hell, I've never sat back there.
    I've never seen the inside from that angle.
    shifty`[QUOTED] likes this.
  3. Mar 1, 2022 at 12:28 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    My baby looking clean at my favorite Taco truck in all San Diego. 20220301_122329.jpg
    RUSTYNUTS, Darkness, bmf4069 and 4 others like this.
  4. Mar 1, 2022 at 1:19 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Omg! Lol
    Darkness likes this.
  5. Mar 1, 2022 at 1:21 PM
    alb1k
    Left Coast
    It's good
    Did the near impossible. Removed the side mirror covers to paint and did not break any of the 12 tabs.
    RUSTYNUTS, Darkness, bmf4069 and 7 others like this.
  6. Mar 1, 2022 at 1:26 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If you're manual, you've got a v6 most likely. Do the 4.88's.
    Do it.
    Lotto ticket time? Gimme a cut if you win.
  7. Mar 1, 2022 at 1:29 PM
    oscardog86
    oscardog86 New Member
    Southern California
    Yes my manual is a V6. Thanks for the input, from what ive been reading its seems like 4.88 is the way to go! Now I gotta wait until I wear my current tires out some more, haha
  8. Mar 1, 2022 at 1:32 PM
    oscardog86
    Southern California
    Also, ive been looking at the Cooper Discoverer St maxx tires, and the last time i looked I think they were around $250 a piece for 255/ 85 r16. Now it looks like they are around $320 a tire! Thanks to inflation or what?! Damn!
    RUSTYNUTS, txagg and Rheywood456 like this.
  9. Mar 1, 2022 at 1:34 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Inflation
    Cost of raw materials
    Cost of labor
    Cost of shipping
    It all adds up and the consumer foots the bill.
  10. Mar 1, 2022 at 2:04 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    is that the r150f? Cause .83 OD isnt the .71 us slushbox guys are working with.
  11. Mar 1, 2022 at 2:18 PM
    oscardog86
    Southern California
    You are speaking a foreign language to me, haha. Sorry I have no idea. Please elaborate, im always open to learning something new!
  12. Mar 1, 2022 at 2:24 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    The manual transmission code. Sorry, i dont know which trans was attached to the 5vz.
    gear ratio spread plays a toll in drivability, but for a truck that sees a highway, a shorter overdrive and taller axle gears would spin the engine faster and possibly generate more heat and wear in the transmission. Between 456 and 488 might not be enough difference to make a difference, 4.10 and 4.88 might? Maybe add a 12v pump and a cooler to the pan?
    oscardog86 and chrisb like this.
  13. Mar 1, 2022 at 2:39 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I've always thought it looked like Robot-Dog Face
    dinosaur, txagg, Rheywood456 and 3 others like this.
  14. Mar 1, 2022 at 8:40 PM
    alb1k
    Left Coast
    It's good
    I haven't had them in for a day and I love them. They are not drink holders, they are saddle bags. Put whatever you want in there. Baby trash bag, all your loose change, whatever.
  15. Mar 1, 2022 at 8:46 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Replaced the belt and tensioner assembly at 178k. I had a crazy squeak at start up.it would last till the battery got up till the 14v on the dash. Turns out I had a bad tensioner. Went with oem parts
    Darkness, txagg, FrenchToasty and 6 others like this.
  16. Mar 1, 2022 at 8:47 PM
    alb1k
    Left Coast
    It's good
    That squeak happened to me, one of the easier noises to track down. That was 90K
  17. Mar 1, 2022 at 9:48 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Where are your foam inserts for the cup holders? You need them! They are a necessity, or maybe not
  18. Mar 1, 2022 at 10:05 PM
    alb1k
    Left Coast
    It's good
    I need them. I heard ebay has them. OEM are probably reasonable if the dealer carries them.
  19. Mar 1, 2022 at 10:13 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I have the eBay ones. Bought them 2 or 3 years ago. They turned a bit purple so not crazy about them. Wonder if there are better ones out there
  20. Mar 2, 2022 at 4:03 AM
    His and hers! I like it.
    Darkness, chrisb and FrenchToasty like this.
  21. Mar 2, 2022 at 5:04 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    My center console has large slots on each side that get used for a very similar purpose.
    Darkness and FrenchToasty like this.
  22. Mar 2, 2022 at 5:13 AM
    You can't just buy OEM, sadly. But I will say, new ones came with my cupholder assembly when I went with wood grain.
    That said, @CodyP has a point - we should probably figure out which ones are fading. Can you check which seller you bought yours from? There are two main sellers I've seen, and you're not the only one whose went purple.
    Before switching to wood grain, I bought my cupholder foams from eptech (eptech2003) who supposedly makes their own, domestically? It was fleaBay item number 323809743677.
    I only had them in for 6 months and I wasn't out in the sun a lot, so I won't be a good reference. They're still dark grey. I actually still have my OEM cupholder, was just saving it in case someone on here was, like, "Damn, I need to replace my cupholder with a low-mile one that has replacement foams!"
    I'm also curious about these rubber inserts and potentially moving to these. They're the drop-ins you see in the later models and they're notched for our center console, but I'm not sure how it'd look ... I'm fairly certain the cupholder on the '00-'07 Sequoia is same as our 1GT. Search fleaBay for 392089777571
    alb1k[QUOTED] likes this.
  23. Mar 2, 2022 at 6:37 AM
    Can you even drive around like that in LA? Thought it was nearly impossible to get a carry permit in that county.
  24. Mar 2, 2022 at 6:38 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I read that as, "Thought it was nearly impossible to get a carry permit in that country."
    I think both are acceptable.
    RUSTYNUTS, shifty` and Jack McCarthy like this.
  25. Mar 2, 2022 at 6:39 AM
    oscardog86
    Southern California
    Interesting, well my next question would be to ask how involved and whats involved in adding that pump and cooler? Thanks for this information!
  26. Mar 2, 2022 at 7:02 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    might not need it, factory trans cooler might work fine? I got my talls and shorts confuddled, but theres bound to be a buncha 4runner or taco guys running shorter rear gear and big tires. Pushing as much or more wind. But ive seen 12v aftermarket fuel pumps circulating pan fluid on manual trucks. One that comes to mind was a 5.0 ford with the mazda 5 speed and i think the guy said he was running 4.56s.
    oscardog86[QUOTED] likes this.
  27. Mar 2, 2022 at 8:52 AM
    alb1k
    Left Coast
    It's good
    Nearly is the key word there.
  28. Mar 2, 2022 at 9:40 AM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    One of my friends was telling me it is actually pretty easy right now to get a permit. I think you just need a reason why you want to carry, but if you say you go hiking or something it would be fine. Not really sure how true that is though.
    Darkness and FirstGenVol[QUOTED] like this.
  29. Mar 2, 2022 at 10:34 AM
    Just put a deposit down on this:
  30. Mar 2, 2022 at 10:36 AM
    Orracle
    Orracle New Member
    Canton, GA
    Congrats ! So jealous
    bmf4069[QUOTED] likes this.
