Seat latch removal
Discussion in '1st Gen Tundras (2000-2006)' started by TravisJr, Mar 1, 2022.
  1. Mar 1, 2022 at 7:42 AM
    TravisJr
    TravisJr [OP] New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    I’ve got a 2001 AC that I’m tinkering with. Did a stereo upgrade and had to go with a floor-mount Stinger subwoofer box. It’a currently riding behind the passenger seat, which doesn’t allow the seat much rearward travel. There’s a foot release on the right of the seat which is intended to give a rear seat passenger an easy way to slide the seat forward. It protrudes from the passenger seat frame, and removing it would give the seat some more rear travel.
    That said, I can’t figure out how to access the mechanism it’s connected to. I found two screws holding the trim: One concealed behind the seat back adjuster latch, and a second behind the seat. Removing both of these didn’t seem to free anything up, and when the trim didn’t pop free with reasonable pressure, I decided to stop before I broke something.
    So I guess my question is two fold: How does the seat trim come off, and has anyone attempted to remove this lever before? I’m hoping it’s just a bolted-on arm I can remove, but I’m not against cutting it if there’s no other option.
    Thanks for any advice.
  2. Mar 1, 2022 at 12:47 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    There should be a 3rd screw hidden by the seat back. The shell should then unsnap but may require a plastic putty knife or similar to help unsnap. The plastic tools linked below to Amazon are very helpful when working on any of our plastic trim and can be also picked up at local Auto parts stores.
    the drawing below is from 2003 FSM but most of our 1st Gens are the same or close to the same as far as your seat project. The red rectangle are the 2 screws you found and the circled red is the 3rd screw.
    The picture is showing where the inner screw is on my 04.
    Amazon.com: Tresalto Auto Trim Removal Tool Set (No Scratch Pry Tool Kit) Fastener Removal Tool - Auto Trim Kit Car Tools - Easy Removal of Car Door Panels, Fasteners, Molding, Dashboards, Wheel Hubs (5 Pack) : Automotive
    daveeasa likes this.
  3. Mar 1, 2022 at 1:19 PM
    TravisJr
    Lots o’ mods
    That’s a huge help. Thanks a ton, man.
    BubbaW likes this.
