DD SSC2 Pro's as ditch lights?
Discussion in 'Lighting' started by helidave, Feb 28, 2022.
  1. Feb 28, 2022 at 10:52 AM
    helidave
    helidave [OP] Hellacopter
    flagstaff
    2015 DC 4x4
    Anybody run these as ditch lights? Do they put out enough light to actually be useful on a trail at night? I like the smaller size compared to the SS3, but it's half the output.
    @memario1214
  2. Feb 28, 2022 at 11:10 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    We honestly get more people buying/using SSC2s as ditch lights vs SS3s. They are low profile and have impressive specs for their size. If you are using them on trails and what not (especially lower speeds) these will be plenty of light. Many will snag up the sports, but if you are running them as your sole aux light I would recommend the pros though.
  3. Feb 28, 2022 at 11:47 AM
    Goonrideit
    Goonrideit New Member
    Chad
    2018 Inferno CM
    Short build RC 6inch. Bilsteins B8 8125 coilovers, KMC FMJ 20×10 0 offset Nitto M/t 37x12.50r20 SSbuilt Front bumper inferno powder match Dirty Deeds 6inch KnN cold'ish Baja Design Squadron Pro flush, Diode Dynamics SS2 fogs Opt7 rock lights Aux Beam 6 gang switch Throttle Commander Tyger step boards Tyger 5.5 trifold bed cover
    I have the DD SSC2 Pros SAE/DOT FOG Amber model and they are great. They have couple of different options for beam patterns. I would buy them again. I think the flood or spot models would be more than enough light for ditch. Just depends on your speed for application. Faster driving you need to throw light further. The pros are back lit so you can wire them up to your DRLs or wire it separately.
  4. Feb 28, 2022 at 11:59 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I have the SSC2 sports as ditch lights. They are the combo ones and they put out a good amount of light. I imagine I would be happier with the Pros, I hate to admit it, but I’d like a little more light than the sports put out.
  5. Feb 28, 2022 at 12:04 PM
    18" TRD Off Road Wheels
    But have you painted them blue yet? :burp:
    TRDFerguson likes this.
  6. Feb 28, 2022 at 12:12 PM
    BlueRibbon4x4
    Geno
    Oh crap, I knew I was missing something from my to do list.
  7. Feb 28, 2022 at 12:21 PM
    Goonrideit
    Chad
    2018 Inferno CM
    Would never inferno all the way!!
    TRDFerguson and GODZILLA[QUOTED] like this.
  8. Feb 28, 2022 at 12:24 PM
    Not sure if the Inferno would clash with @BlueRibbon4x4's other color matched stuff...
  9. Feb 28, 2022 at 12:29 PM
    BlueRibbon4x4
    Geno
    A little Inferno accent color? :rofl:
    GODZILLA[QUOTED] likes this.
  10. Feb 28, 2022 at 12:32 PM
    Could work. Blue and orange.... You a Denver Broncos fan?
    For an actual accent you could try matching your wheels. You're a damn paint matching wizard, so why not?
  11. Feb 28, 2022 at 12:52 PM
    BlueRibbon4x4
    Geno
    Ha, thanks! But my inability to leave things alone is making me wanna go darker bronze on them.
    But I really didn’t wanna hijack the thread. Are the Pro SSC2s that much brighter than the sports? I have the SS3 for fogs that would be awesome for ditch lights. But they seem so obtrusive on the hood.
  12. Feb 28, 2022 at 12:54 PM
    memario1214
    Colton
    Missoula, MT
    Raw Outputs-
    Sport: 1,130lm
    Pro: 2,898lm
    It's a pretty solid jump, and those are stabilized output numbers.
    GODZILLA and TRDFerguson like this.
  13. Feb 28, 2022 at 12:55 PM
    BlueRibbon4x4
    Geno
    Dang that’s fantastic. Justifies the pro price.
  14. Feb 28, 2022 at 12:56 PM
    memario1214
    Colton
    Missoula, MT
    I'll be right here when you need some :wave:
    Finally stocked up on C2s too... :cool:
  15. Feb 28, 2022 at 12:59 PM
    BlueRibbon4x4
    Geno
    I may swap them out. Do they use the same harness as the sports so I don’t have to rewire the hood? I can use the new harness and sports as chase lights.
    Mater and TRDFerguson like this.
  16. Feb 28, 2022 at 1:18 PM
    memario1214
    Colton
    Missoula, MT
    Same harness. Even the light duty one has enough headroom for the C2 pros.
    BlueRibbon4x4[QUOTED] and Mater like this.
  17. Feb 28, 2022 at 1:19 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    They should all be 4 pin DT connections. My SSC1 Pros work great as chase lights, so the C2s should be even better. You might need to extend the harness to reach the bed, depending on where you're mounting. I used some 18/3 copper stranded wire (SJOOW) to run from the engine bay to the bed, then across the bed between the cab and bed in wire loom.
  18. Feb 28, 2022 at 2:13 PM
    BlueRibbon4x4
    Geno
    Nice! Thanks for the info
  19. Feb 28, 2022 at 4:08 PM
    helidave
    flagstaff
    2015 DC 4x4
    What kind of brackets
    What brackets are you running?
  20. Feb 28, 2022 at 4:56 PM
    BlueRibbon4x4
    Geno
    The Cali-raised low profile ones. They’re a quick order from Amazon.
  21. Feb 28, 2022 at 5:01 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Colton carries those as well…
    HulkSmurf14 likes this.
  22. Feb 28, 2022 at 5:07 PM
    helidave
    flagstaff
    2015 DC 4x4
    Trying to avoid caliraised products if I can
    TRDFerguson and BlueRibbon4x4 like this.
  23. Feb 28, 2022 at 5:07 PM
    BlueRibbon4x4
    Geno
    Whups. @helidave you should order from @memario1214 If I decide on the pros that’s where I’ll order instead of big corporate.
  24. Feb 28, 2022 at 5:08 PM
    helidave
    flagstaff
    2015 DC 4x4
    Planning to
  25. Feb 28, 2022 at 5:08 PM
    BlueRibbon4x4
    Geno
    I hear ya. They got a real bad rap on their lighting.
    memario1214 likes this.
  26. Feb 28, 2022 at 5:08 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    In that case, the SDHQ ones are nice. @BiggHertz has them.
  27. Feb 28, 2022 at 5:50 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  28. Feb 28, 2022 at 6:17 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  29. Feb 28, 2022 at 6:24 PM
    memario1214
    Colton
    Missoula, MT
    I'd never sell ya CR lighting equipment. Their in-house brackets and metal work isn't terrible though for the most part. We personally run SDHQ, but don't sell them. SDHQ won't have us :rofl:
  30. Feb 28, 2022 at 6:30 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    lol, I’ve been doing that a lot lately.
    I have the SDHQ brackets and i love them, the extra point of contact really helps to stabilize them. Even with the weight of the S1 hanging off the side of the XL Racer.
    TRDFerguson[QUOTED] likes this.
