New Guy Looking to Buy - Common Problems?
Discussion in '2nd Gen Tundras (2007-2013)' started by shirleyjp86, Feb 24, 2022.
  1. Feb 24, 2022 at 1:33 AM
    shirleyjp86
    shirleyjp86 [OP] New Member
    Hey guys, I'm looking at a 2008 double-cab SR5 with 64k miles on the clock. The thing looks clean enough to eat off of, but even with such low milage, I know the ol' gal is 14 years old. That said, what are some things I should be looking for? I hear the valve covers like to leak? What else?
    IsaiahCanada and Prostar 190 like this.
  2. Feb 24, 2022 at 2:47 AM
    Welcome from Ohio
  3. Feb 24, 2022 at 3:03 AM
    shirleyjp86
    Thanks man!
  4. Feb 24, 2022 at 3:08 AM
    Rockanock
    Rockanock 21 Chevy 2500
    Welcome!! That shouldn’t be an issue on that truck! I’d probably change the plugs and wires and do a complete fluid flush and service. Might possibly do shocks if they are leaking. Also check under the truck for any places where it could be leaking. Such as, rear end, trans, ect. Other than that your prob gonna be good. Even if you don’t buy it, your welcome here anytime. Cheers
  5. Feb 24, 2022 at 3:14 AM
    shirleyjp86
    Thanks man! Here she is - I really like the color.
  6. Feb 24, 2022 at 3:26 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome, Very clean Rig....Congrats on the new to you Tundra..
  7. Feb 24, 2022 at 4:15 AM
    Welcome from NY.
  8. Feb 24, 2022 at 5:11 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Pretty good youtube video that covers all the problems with the 07-13 Tundras.
    I'll see if i can find it.
    But at 67k you shouldn't have any issues. My water pump went at 90k, but its easy enough to change out.
    Turns out if you search youtube 07-13 tundra issues you'll get a bunch of videos with pretty info.
  9. Feb 24, 2022 at 7:03 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! And that sounds like an awesome find. Very low mileage! Truck looks great!
  10. Feb 24, 2022 at 7:45 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    The things people are on here for most commonly that I would consider common problems:
    1. Cam tower leaks (a pain in the ass an expensive to pay for)
    2. Front diff bearing growl (aftermarket parts solve this inexpensively)
    3. Water pump/starter/alternator/fuel pump going out between 100,000-300,000
    4. SAIS emissions issues (resolved with an aftermarket bypass)
    With the truck you're looking at, I would do #4 immediately after buying and get the Hewitt bypass kit. #2 would be next on my list with the ECGS bushing kit. #1 happens pretty slowly and you may notice the back of the engine getting oily at some point, so you can just wait to see if that one happens, and the items in #3 probably have many years of life left.
    jalam321 likes this.
  11. Feb 24, 2022 at 7:47 AM
    poop_bubbles
    poop_bubbles New Member
    Other than checking wear items (brake pads, tires, filters) I wouldn't worry about anything other than fluid changes until a problem presents itself. Lots of people say that "x, y, or z always fails at xxx mileage" but that is mostly horsesh*t. Things break when they break and it's all relative to use and how the vehicle was driven. Generally speaking, things don't break on Toyotas. Not saying it doesn't happen, just don't stress over parts that aren't currently broken.
    - Cam seals will seep for 400k miles and never leave a drip on the ground, don't fuss over those... that's the most over-hyped issue on this forum
    - Front diff usually doesn't make a sound until you lift the truck. Mine was quiet as a mouse at 200k until I lifted.
    - My factory water pump also lasted 200k miles before I replaced it pre-emptively, and I only replaced it because I had to replace a squealing idler pulley and was in there anyway.
    Again, it's good to keep an eye on everything but unless you're planning a trip to Alaska I wouldn't do anything at all that wasn't absolutely necessary.
  12. Feb 24, 2022 at 7:53 AM
    audiowize
    Paul B.
    So you'd drive cross country on 14-year-old SAIP parts and risk having to fork over $2000-4000 to a Toyota dealer (if there is one close by) rather than putting the $400 bypass on to avoid that entirely?
  13. Feb 24, 2022 at 7:57 AM
    poop_bubbles
    I don't even know WTF an SAIP is. 230k miles and it has never been an issue. Thanks for proving my point.
  14. Feb 24, 2022 at 7:58 AM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    This is a good video to cover common issues.
    https://youtu.be/l2OAHImTgA8
  15. Feb 24, 2022 at 8:01 AM
    audiowize
    Paul B.
    I'm going to go ahead and say you didn't put all 230K on the truck.
  16. Feb 24, 2022 at 8:27 AM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
    Just my opinion but:
    You can also bypass the SAIS (secondary Air Injection System/SAIP (secondary Air injection pump) by installing a DAP tune. But costs as much as bypass kit.
    and the SAIS issues are entirely where you are located. If you live were it rains it could be a problem and before i drove cross country i'd go ahead and take care of it.
    If you live in the desert of AZ I doubt it will every get damaged/wet as i think the location is why it fails.
    I'd be more worried about the frame under a 08 then anything else. These trucks had recalls in the 07-09 timeframe that toyota replaced frames (I think?).
  17. Feb 24, 2022 at 2:44 PM
    poop_bubbles
    Bought at 110k, with all dealer service records. Never been done. No rust either. Colorado truck all it’s life.
  18. Feb 24, 2022 at 2:45 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Welcome. That low mileage Tundra is a nice find. Most of the common issues have been already mentioned above but some people never encounter them. Just keep up with routine maintenance and you should be good!
    IsaiahCanada likes this.
  19. Feb 25, 2022 at 2:30 AM
    RToad
    RToad New Member
    Congrats. I have a similar mileage (63k) '13 I inherited from my father in law when he passed last year. Here's where it started and where it currently is. Always gotta scratch that upgrade itch.
  20. Feb 25, 2022 at 3:49 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    If you are not handy and can't check it yourself, why guess???
    Bring it to Toyota. For like $110 they will tell you everything you need to know. Even down to how many millimeters on the brake pads.
    If service at Toyota, they will have the maintenance history. Cheap insurance if you need a lot of work done to it.
  21. Feb 25, 2022 at 6:59 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Check for bed rust. Especially if it has a liner. The rust starts from under the bed.
  22. Feb 25, 2022 at 7:18 AM
    Landodnal
    Landodnal New Member
    2008 Toyota Tundra Limited Slate Grey 4WD
    2" Leveling Kit
    Welcome! I also have an '08. Mine has 154,000 miles and the 5.7 L motor. The first question I would ask is, does your truck have a lift or a leveling kit?
  23. Feb 27, 2022 at 12:53 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    1.) Any rust
    2.) Cam tower seal
    3.) valley leak
    are the biggest 3 if its been serviced regularly.
    Also get a Pre-Purchase inspection thats about one of the biggest regrets of any bad purchasers choice is doing a post inspection.
    and welcome.
